Community Member
unable to call in after SRST was active
I'm running CUCM7.0 and on remote offices are Voicegateways (IOS 12.4(22)T) with SRST.
When WAN is down, the phones are working correctly in SRST mode, but when the WAN comes backup and the phones are registered back to CUCM. it isn't possible to call in. I'm hearing a busy tone. As it generates a dial-peer in SRST mode for the directory numbers, the auto-generated dial-peers has a higher match, than the dial-peer I configured. So I have to delete all the ephone-dn that it will be possible to call in. See below the relevant configuration.
dial-peer voice 10 voip
preference 1
destination-pattern 9942[6-9]..
voice-class codec 10
voice-class h323 11
session target ipv4:10.21.1.2
dtmf-relay h245-alphanumeric
no vad
telephony-service
srst mode auto-provision all
srst ephone template 1
srst dn line-mode dual
em logout 0:0 0:0 0:0
max-ephones 58
max-dn 192
ip source-address 10.70.10.3 port 2000
system message NOTSZENARIO
cnf-file location flash:
user-locale DE
time-zone 23
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 99426.. extension-length 4
dialplan-pattern 2 99427.. extension-length 4
dialplan-pattern 3 99428.. extension-length 4
dialplan-pattern 4 99429.. extension-length 4
max-conferences 8 gain -6
hunt-group logout HLog
moh music-on-hold.au
multicast moh 239.1.1.1 port 2000
web admin system name admin password cisco
dn-webedit
transfer-system full-consult
secondary-dialtone 0
fac standard
Is there a way or a command that it will put the automatic generated dial-peer as second preference?
Peter
1 REPLY
Silver
Re: unable to call in after SRST was active
The preference order for the VoIP dial peers to be created has a range from 0 to 10. Default is 0, which is the highest preference.
231
