06-10-2012 05:06 AM - edited 03-16-2019 11:35 AM
Dear All
After a 250Gb Harddisk crash i purchased two new 500 Gb HDD each, I am trying to install the 6.1.2 CUCM application with unity
using the media provided with the MCS 7828 H Series server.
But the Installation fails with "Exception Occured" afther the Partitioning and during the communication manager installation process.
File "/usr/libanaconda/gui.py", line 768, in nextClicked
sell dispatch.gotoNext()
File......
Attached are the Images of the error,
If any one has the workaround for this kindly let me know at the earliest. I tried to search for such a failure in CUCM but not found.
This server was running with the same version for the past 4 years and now i faced the problem after the Harddisk failure.
Solved! Go to Solution.
08-31-2012 08:48 AM
Hi there, i finally solved the issue. In my case, we had a faulty dvd drive on the 7828H3 and figured using a usb dvd drive would help.
It didn't and kept coming up with your error and screenshots. Trying to use a bootable usb drive also gives you errors. We eventually replaced the dvd drive and it booted to dvd and installed normally without bringing up the red hat gui.
The moment you run into the red hat gui, thats the first sign of trouble. Hope this helps?
08-30-2012 08:40 AM
Hi there, I just ran into the same issue! Been battling it for days. Have you been able to resolve this? Please share
08-31-2012 08:48 AM
09-17-2012 11:03 PM
Hi Williams
The problem is not yet fixed, presently i am running CME In my case the problem of the DVD drive was similar to yours and i was using the external USB drive but the problem still continued. I had contacted a Cisco Vendor and they said the problem is with the motherboard. i will give a try and order for the internal drive.
Thanks for your advice i will try it and reply back. Hope it will resolve the issue.
regards
Manoj
01-29-2013 10:15 PM
Sorry i could not get the time to update the forum, As Mr Williams has adviced the the problem was with the faulty dvd drive on the 7828H3.
Once replaced the setup went on smoothly, no one can guess the problem could be from the DVD Drive as the error on the screen does not suggest the problem is because of DVD Drive.
It is a must to use Internal DVD Drive for installation, Using a External USB DVD Drive for installation of CUCM can provide errors like "Exception Occured".
Thanks Williams
