Community Member
Unable to Change IP address on my Cisco 7960 phone
I had a new Cisco 7960, and I want to change his IP address, but I am unable to do it. The new IP that I assign to the PC is not saved on the phones config, it got baks the IP that was defined by factory.
The steps I do are the following:
- Menu "Network Configuration"
- **# to allow changes on the config
- DHCP Enabled = No
- IP Address = 192.168.1.189
- Subnet Mask = 255.255.255.0
- TFTP Server = 192.168.1.89
Save and Exit
When I come back to the config, the IP has not changed. It still has the original value IP Address = 10.13.102.74 and Subnet Mask=255.255.252.0.
Any hint ? What I am missing ?
Community Member
Re: Unable to Change IP address on my Cisco 7960 phone
Try to do the factory defaults procedure first.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a00800941bb.shtml#t2
After, you can try again.
tks
Silver
Dont do a Factory reset now, do the following:
setting->Network Configuration->33 (delete configuration) yes and save, then do the same changes above, it should work, if not do a factory reset.
139
