Unable to complete call to/from FXS device
I am labbing the following scenario:
IP Phone <--> UCM6.1 <--> 2801 <--> VG200 <--> FXS <--> Analog Phone
I my goal is to route to an analog device using h.323 dialpeers. All devices are connected to the same LAN switch and are on the same VLAN. I have the 2801 configured as an H.323 gateway within CallManager but not the VG200. I have IP Phones configured in CallManager and FXS configured on the VG200 for the analog phones. The IP Phones can call each other and the analog phones can complete calls to each other.
I have configured a dial-peer on the 2801 with a destination-pattern sending the call to the VG200 and a dial-peer on the VG200 pointing back to the 2801.
*** 2801 Config ***
voice call send-alert
voice rtp send-recv
voice service voip
voice class codec 1
codec preference 1 g711ulaw
voice class h323 1
h225 timeout tcp establish 3
interface FastEthernet0/0
description SC Voice LAN
ip address 10.254.0.253 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.254.0.253
dial-peer voice 200 voip
description dial-peer to CallManager
destination-pattern 2...
progress_ind setup enable 3
voice-class codec 1
voice-class h323 1
session target ipv4:10.254.0.250
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
dial-peer voice 201 voip
description dial-peer to VG200
destination-pattern 3...
voice-class codec 1
voice-class h323 1
session target ipv4:10.254.0.251
incoming called-number .
*** End ***
*** VG200 Config ***
call rsvp-sync
voice rtp send-recv
voice service voip
h323 call start fast
voice class codec 1
voice class h323 1
ip address 10.254.0.251 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.254.0.251
voice-port 1/1/0
description ** FXS **
station-id number 3001
voice-port 1/1/1
station-id number 3002
dial-peer voice 9 voip
voice-class codec 1
voice-class h323 1
session target ipv4:10.254.0.253
no vad
dial-peer voice 10 pots
destination-pattern 3001
port 1/1/0
dial-peer voice 11 pots
destination-pattern 3002
port 1/1/1
*** End ***
The issue I'm seeing is thus:
1) IP Phone can ring Analog Device
2) Analog Device rings
3) No ringback to IP Phone
4) When Analog Device goes off-hook, dead air, IP Phone times out to busy
1) Analog Device can ring IP Phone
2) IP Phone rings
3) I hear ringback on the Analog Device
4) When IP Phone goes off-hook, I continue to hear ringback on Analog Device until it times out to busy.
Any suggestions to config or what to troubleshoot are much appreciated.
Thanks!
132
