07-12-2013 09:36 AM - edited 03-16-2019 06:21 PM
Hi Guys,
I have a CME router 2911. The router has two PVDM cards. One card is a PVDM 64 on slot 0 and the other card is a PVDM 32 on slot 1.
I am configuring two E1 lines to be used on the router. On the first E1 controller I can configure primary pri-group timeslots 1-31 but on the other E1 controller, when I try to do the same, it tells me I have insufficient resources and therefore I am only able to configure pri-group timeslots 1-16.
I thought with two PVDM resources (64 and 32) I would be able to configure 30 channels on both E1 controllers.
What could be issue? Is it PVDM related? When I do the show voice dsp voice group all, below is the output I get. I can see that there are no DSP groups on slot 1 where the PVDM 32 is connected. How do I activate DSPs on this PVDM?
CMS_VG#show voice dsp group all
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 33.1.0
Max signal/voice channel: 32/32
Max credits: 480, Voice credits: 480, Video credits: 0
num_of_sig_chnls_allocated: 32
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 480, reserved credits: 0
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 2:
num_of_sig_chnls_allocated: 17
Shared credits: 288, reserved credits: 0
Group: FLEX_GROUP_CONF, complexity: CONFERENCE
Shared credits: 0, reserved credits: 192
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 7:
num_of_sig_chnls_allocated: 0
Shared credits: 0, reserved credits: 480
Slot: 0
Device idx: 0
PVDM Slot: 1
Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
0 DSP resource allocation failure
Below is the show run for the router.
aaa session-id common
clock timezone EAT 3 0
network-clock-participate wic 1
ip cef
no ip domain lookup
ip domain name catalystprincipal.com
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711alaw
codec preference 4 g711ulaw
voice iec syslog
voice register global
mode cme
source-address 192.168.10.1 port 5060
max-dn 5
max-pool 5
dialplan-pattern 1 9.T extension-length 3
dialplan-pattern 2 8.T extension-length 3
tftp-path flash:
create profile sync 0001884471822112
voice register dn 1
number 100
name ATA
label 100
mwi
voice register dn 2
number 101
name ATA
label 101
mwi
voice register pool 1
id mac C062.6B62.A3C7
type ATA-187
number 1 dn 1
number 2 dn 2
codec g711ulaw
voice translation-rule 1
rule 1 /^730142/ //
rule 2 /^4296/ //
voice translation-profile INCOMING-E1
translate called 1
license udi pid CISCO2911/K9 sn FCZ161370N2
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
file privilege 0
username catalyst privilege 15 secret 4 zlHhRXnglmT4VQW9BZtAYpfuLXYE6B6GmalIBPH2I0k
redundancy
controller E1 0/1/0
framing NO-CRC4
description AIRTEL ISDN
controller E1 0/1/1
description ORANGE ISDN
ip ftp password 7 03065002041A2645
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description LINK_TO_CAT3560_SWITCH
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description CMS_VG INTERFACE FOR VOICE VLAN
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/0.20
description CMS_VG INTERFACE FOR DATA VLAN
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
interface Serial0/1/1:15
no ip address
encapsulation hdlc
no cdp enable
interface SM1/0
description "Unity Express Module"
ip unnumbered GigabitEthernet0/0.10
ip virtual-reassembly in
service-module ip address 192.168.10.2 255.255.255.0
!Application: CUE Running on SM
service-module ip default-gateway 192.168.10.1
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
no ip http secure-server
ip http path flash:GUI
ip route 0.0.0.0 0.0.0.0 192.168.20.254
ip route 192.168.10.2 255.255.255.255 SM1/0
ip route 192.168.30.3 255.255.255.255 192.168.10.254
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0:15
translation-profile incoming INCOMING-E1
voice-port 0/1/1:15
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0.10
sccp ccm 192.168.10.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0.10
associate ccm 1 priority 1
associate profile 1 register conf_dsp_1
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 7
associate application SCCP
dial-peer cor custom
name Airtel_Mobile
name Safcom_Mobile
name Airtel_PSTN
name Telkom_PSTN
name None_PSTN
dial-peer cor list AirtelMobile
member Airtel_Mobile
dial-peer cor list SafcomMobile
member Safcom_Mobile
dial-peer cor list AirtelPSTN
member Airtel_PSTN
dial-peer cor list TelkomPSTN
member Telkom_PSTN
dial-peer cor list NonePSTN
member None_PSTN
dial-peer voice 500 voip
description "Voicemail Dialpeer"
destination-pattern 5..
session protocol sipv2
session target ipv4:192.168.10.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1 voip
corlist outgoing SafcomMobile
description "Safaricom GSM Dialpeer"
destination-pattern 907[0-2].......
session target ipv4:192.168.30.3
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2 voip
corlist outgoing AirtelMobile
description "Airtel GSM Dialpeer"
destination-pattern 907[3,8].......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 4 pots
corlist outgoing AirtelPSTN
description "Airtel PSTN Dial Peer"
destination-pattern 8.T
incoming called-number 9T
direct-inward-dial
port 0/1/0:15
dial-peer voice 5 pots
corlist outgoing TelkomPSTN
description "Telkom PSTN Dialpeer"
destination-pattern 9T
incoming called-number 9.T
direct-inward-dial
port 0/1/1:15
sip-ua
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on *1 mute-off *2
sdspfarm units 5
sdspfarm tag 1 conf_dsp_1
no privacy
conference hardware
no auto-reg-ephone
max-ephones 50
max-dn 100
ip source-address 192.168.10.1 port 2000
no service directed-pickup
system message Catalyst Management Services
cnf-file location flash:
load 7915-12 B015-1-0-4.SBN
load 7915-24 B015-1-0-4.SBN
load ata ATA187.9-2-3-1.loads
time-zone 31
date-format dd-mm-yy
voicemail 500
mwi relay
max-conferences 8 gain -6
moh "music-on-hold.au"
web admin system name cmsadmin password admin
dn-webedit
transfer-system full-consult
transfer-pattern 9.T
transfer-pattern ...
after-hours block pattern 1 9T 7-24
after-hours block pattern 2 9 7-24
after-hours block pattern 3 907[0-2]....... 7-24
after-hours block pattern 4 907[3,8]....... 7-24
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
directory entry 1 000 name Reception
directory entry 2 001 name Paul Kavuma
directory entry 3 002 name Biniam Yohannes
directory entry 4 003 name Rajal Upadhyaya
directory entry 5 004 name Marlene Ngoyi
directory entry 6 005 name Vaishal Shah
directory entry 7 006 name Rosemary Ngure
directory entry 8 007 name Nixon Muthangya
directory entry 9 008 name Nyawira Gitau
directory entry 10 009 name Stephen Macharia
directory entry 12 011 name Bernard Ouma
directory entry 13 030 name Main Boardroom
directory entry 14 016 name Server Room
directory entry 15 020 name Vincent Rague
directory entry 16 021 name Seeta Shah
directory entry 17 030 name Main Boardroom
directory entry 18 031 name Meeting Room
directory entry 19 032 name Cubby Hole
directory entry 11 010 name Martha Osier
create cnf-files version-stamp 7960 Jul 01 2013 21:37:23
ephone-template 1
softkeys hold Resume Newcall
softkeys idle Redial Newcall Cfwdall Dnd
softkeys seized Endcall Meetme
softkeys alerting Callback Endcall
softkeys connected Hold Trnsfer Endcall Confrn
softkeys ringing Answer Dnd
ephone-template 2
softkeys idle Redial Newcall Cfwdall Dnd Pickup
softkeys connected Hold Endcall Trnsfer Confrn
after-hours exempt
type 7942
ephone-template 3
ephone-dn 1 dual-line
number 000
pickup-group 10
label Reception - 000
description Reception
name Reception
ephone-dn 2 dual-line
number 001
pickup-group 10
label Paul Kavuma - 001
description Paul Kavuma
name Paul Kavuma
ephone-dn 3 dual-line
number 002
pickup-group 10
label Biniam Yohannes - 002
description Biniam Yohannes
ephone-dn 4 dual-line
number 003
pickup-group 10
label Rajal Upadhyaya - 003
description Rajal Upadhyaya
ephone-dn 5 dual-line
number 004
pickup-group 10
label Marlene Ngoyi - 004
description Marlene Ngoyi
name Marlene Ngoyi
ephone-dn 6 dual-line
number 005
pickup-group 10
label Vaishal Shah - 005
description Vaishal Shah
name Vaishal Shah
ephone-dn 7 dual-line
number 006
pickup-group 10
label Rosemary Ngure - 006
description Rosemary Ngure
name Rosemary Ngure
ephone-dn 8 dual-line
number 007
pickup-group 10
label Nixon Muthangya - 007
description Nixon Muthangya
ephone-dn 9 dual-line
number 008
pickup-group 10
label Nyawira Gitau - 008
description Nyawira Gitau
name Nyawira Gitau
ephone-dn 10 dual-line
number 009
pickup-group 10
label Stephen Macharia - 009
description Stephen Macharia
ephone-dn 21 dual-line
number 101
label Main Boardroom - 101
description Main Boardroom
name Main Boardroom
ephone-dn 22
number 501..
mwi-type visual
mwi on
ephone-dn 23
number 502..
mwi-type visual
mwi off
ephone-dn 24 octo-line
number 200
description Meet-Me Conference Number
conference meetme
no huntstop
ephone-dn 25 octo-line
number 201
conference meetme
no huntstop
ephone-dn 26 octo-line
number 202
conference meetme
no huntstop
ephone-dn 27 octo-line
number 203
conference meetme
preference 1
no huntstop
ephone-dn 28 octo-line
number 204
conference meetme
preference 2
ephone-dn 29 octo-line
number 205
conference meetme
no huntstop
ephone-dn 30 dual-line
number A000
description Ad-Hoc Conference Number
conference ad-hoc
no huntstop
ephone-dn 31 dual-line
number A000
conference ad-hoc
preference 1
no huntstop
ephone-dn 32 dual-line
number A000
conference ad-hoc
preference 2
no huntstop
ephone-dn 33 dual-line
number A000
conference ad-hoc
preference 3
no huntstop
ephone-dn 34 dual-line
number A000
conference ad-hoc
preference 4
ephone-dn 35 dual-line
number 106
pickup-group 10
label Lounge - 106
description Lounge Phone
name Lounge
ephone 1
mac-address C8F9.F9D6.0259
ephone-template 1
after-hours exempt
type 7962 addon 1 7915-24
button 1:1 7m2 8m3 9m4
button 10m5 11m6 12m7 13m8
button 14m9 15m10 16m11 17m15
button 18m16 19m13 20m21 21m14
button 22m20
ephone 2
mac-address A418.7529.8391
ephone-template 2
after-hours exempt
type 7942
button 1:2
ephone 3
mac-address A418.758A.10F2
ephone-template 2
after-hours exempt
type 7942
button 1:3
ephone 4
mac-address A418.758A.2F76
ephone-template 2
after-hours exempt
type 7942
button 1:4
ephone 5
mac-address A418.7529.8386
ephone-template 2
after-hours exempt
type 7942
button 1:5
ephone 6
mac-address A418.7529.8441
ephone-template 2
after-hours exempt
type 7942
button 1:6
ephone 7
mac-address A418.7529.8450
ephone-template 2
after-hours exempt
type 7942
button 1:7
ephone 8
mac-address A418.7529.83AC
ephone-template 2
after-hours exempt
type 7942
button 1:8
ephone 9
mac-address A418.7529.8462
ephone-template 2
after-hours exempt
type 7942
button 1:9
ephone 10
mac-address F4EA.6749.B07D
ephone-template 2
after-hours exempt
type 7942
button 1:10
Solved! Go to Solution.
07-13-2013 12:50 AM
Hi Andrew,
You can use the DSP calculator to callcuate teh requirement.
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
regds,
aman
07-12-2013 09:42 AM
Hi Guys,
Below is the error I am getting:
Not enough DSP resources available to configure pri-group on controller E1 0/1/1
% The remaining dsp resources are enough for 17 time slots.
% For current codec complexity, 1 extra dsp(s) are required to create this voice port.
07-12-2013 09:53 AM
Hi Andrew,
On PVDM3-64 , u can have max. 960 credits while with PVDM3-32, u can have total 480 credits.
In the output, u have shared they all are consumed.
regds,
aman
07-12-2013 11:42 PM
Is there any way I can distribute more resources to the E1 line?
Andrew
07-12-2013 08:34 PM
Shutdown the Conference Profile, then try again.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
07-12-2013 11:51 PM
Hi Jorge,
I disabled the conference profile and then I was able to configure the full 30 channels on the E1 line.
My concern is this: The client still needs to be able to conference. Is it possible to still have the conference profile and still be able to configure the E1 line?
07-13-2013 12:50 AM
Hi Andrew,
regds,
aman
07-13-2013 12:52 AM
Thanks everyone for your help.
I now understand better DSP resourcing and utilization.
