unable to connect cli voicemail, #4 directory voicemail number?..
Hello Guys,
     I have the next scenario, we have a 3925 router working has a CME, on this appliance we also have a voicemail (SM), now, we have next 2      doubt/toruble,the first one is, why we can not connect to the cli of the voicemail?....voicemail has configurated 172.24.8.10, but when we use the      command:CME#service−module service−engine x/x session cme tries to connect unsucessfully to the ip address 172.24.8.6  (172.24.8.6 is the cme      ip address!) when the ip address of the voicemail in fact is 172.24.8.10. Error tell us "trying to connect to 172.24.8.6 , port-number"
     why CME tries to connect to himself instead of ip voicemail address?...
     This is the part of the configuration:
interface GigabitEthernet0/0
ip address 172.24.8.6 255.255.255.0
duplex auto
speed auto
no mop enabled
interface SM1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 172.24.8.10 255.255.255.0
!Application: CUE Running on SM
service-module ip default-gateway 172.24.8.1
no cdp enable
The second question is, is posible that this voicemail can has the "#4"  as an directory number?...
Everyone's tags (3)
If not already added, add the below static route:
ip route 172.24.8.10 255.255.255.255 SM1/0
-Terry
Hi Terry,
     The command is on CME, thats very strange..
Could you please pos the config and show ip int brief from the CME?
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Re: unable to connect cli voicemail, #4 directory voicemail numb
voice iec syslog
voice register global
mode cme
source-address 172.24.8.6 port 5060
max-dn 600
max-pool 265
load 3905 CP3905.9-2-2-0
authenticate register
olsontimezone Mx version 1
timezone 9
date-format D/M/Y
mwi stutter
mwi reg-e164
voicemail 4430
file text
create profile sync 3253061835069937
ntp-server 172.24.8.6 mode directedbroadcast
interface Loopback20
description = VoIP =
ip address 10.10.10.1 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
no cdp enable
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 192.168.10.254 255.255.255.0
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface SM1/0
no cdp enable
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
shutdown
no cdp enable
interface Vlan1
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 172.24.8.1
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 5
sdspfarm tag 1 xcoder
max-ephones 250
max-dn 250
ip source-address 172.24.8.6 port 2000
max-redirect 5
system message Johnson Electric
url services http://172.24.8.10/voiceview/common/login.do
url authentication http://172.24.8.6/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
load 7942 SCCP42.9-2-1S
load 7965 SCCP45.9-3-1SR1-1S
time-zone 9
date-format dd-mm-yy
keepalive 90
voicemail 4430
max-conferences 8 gain -6
moh "music-on-hold.au"
multicast moh 224.1.1.1 port 2000
web admin system name Admin password J0hn50n*
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern ....
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
dial-peer voice 5890 voip
description ++CUE++
destination-pattern 443.
session protocol sipv2
session target ipv4:172.24.8.10
dtmf-relay sip-notify
codec g711ulaw
no vad
This is part of the config
can you please check the status of this service module with command
show ip int brief
Service-Engine2/0          142.1.66.154    YES TFTP   up                    up
send me the output of
service-module service-Engine 1/0 status
and also try run this command on cme on privillege mode and check
service-module service-Engine 2/0 reset
Br,
Nadeem
Change default gateway under int SM to:
interface SM1/0
service-module ip default-gateway 172.24.8.6
Right now you have .1
-Terry
255
