Green
Unable to delete user - Unity Connection
When I try to delete a specific user in Unity Connection (2.1.2.1000-380) I get the following error.
"Operation cannot be completed because the object is in use"
I cannot find any reference to it anywhere.
Tried the solution in this document...
http://www.cisco.com/en/US/products/ps6509/products_tech_note09186a0080b35d01.shtml
But when I run the "run cuc dbquery.." command all I get is
Can't load driver java.lang.reflect.InvocationTargetException
Command failed
Is this standalone CUC or CUMBE?
By the fact you can't even run the qry maybe a restart would help.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Green
Sorry this is business edition. I'll try a reboot if I have a chance.
OK, since this is BE deleting users is not done via CUC Admin, but CUCM Admin
Modifying or Deleting Individual User  Accounts
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/connection/2x/user_mac_cmbe/guide/6xcucmbemac110.html
In Cisco Unified Communications Manager Business Edition (CMBE), you  delete Cisco Unity Connection user accounts in Cisco Unified CM  Administration. (Use the applicable User Management page to find the  user or application user, then delete.)
To learn more about deleting Connection accounts in Cisco Unified CM  Administration, see the online Help, or the "End User Configuration" and  "Application User Configuration" chapters of the Cisco  Unified Communications Manager Administration Guide.
Note the following considerations for deleting an account:
If a user account is referenced  by other objects in the Cisco Unity Connection (for example, if the user  is set to be a recipient of messages left in an interview handler, or  if a call handler is set to transfer incoming calls to the user phone),  you will not be allowed to delete the user account until you have  changed settings on the other objects to remove references to the user  account you want to delete. If you try to delete a user account without  first changing settings on objects that reference the user account, the  delete operation will fail.
An administrator is prohibited  from deleting his or her own account.
When you delete the account of a  user with a voice mailbox, that user will be automatically deleted from  the All Voice Mail Users distribution list.
java
java
Green
The user was deleted from the CUCM admin. The problem is it still shows in the Unity admin and won't let me delete it and I get.
Green
Bump. Any help?
1205
