Hi Team,
I have installed CUCM cluster 6.1.5 and 7942 phones. I found one uncommon issue, When I pressed misscall and then try to redial by using EditDial soft key, I was not getting through. Call is not hitting gateway itself. Let me put an example:
I called from my mobile (9823498342) to IP Phone but did not answer. I can see the number in Misscall list (9823498234). Now I have to add prefix 9. I am pressing EditDIal button and press 9 then press dial button. The IP Phone is showing 99823498234 but call is not getting through. If I dial 99823498234 from the same phone it is getting through.
Could you plesae help me on this regards,
It is really urgent..
Thanks in advance.
Nirmal
