Unable to Dial Users in Corporate Directory
hi,
i have a CUCM v 8.6 and its users sync with Microsoft Active Directory. I am now having an issue where when someone searches the Corporate Directory and the try to dial, nothing happens.
When i go to end users and looking into the profiles, there are no telephone numbers associated with the users. i believe this is the root cause, since all the telephone Number fields are in fact populated in Active Directory.
this was working before. i have tried re-sync LDAP, reboot the CUCM, but nothing works. i also tried pinging my AD server from CUCM and it was successful, so I know my CUCM can reach my AD
not sure if this is some kinda of bug. please assist.
1 ACCEPTED SOLUTION
Are you pointing to the right
Are you pointing to the right LDAP field for the phone number??
java
if this helps, please rate
www.cisco.com/go/pdi
java
Thanks Jaime. i just figured
Thanks Jaime. i just figured it out. you are right as well.
The Directory was Pointing to IP Phone and not Telephone Number.
66
