Unable to download CCMServRtmtPlugin.exe from CUCM 7.1.3
For some strange reason, I can no longer download the  CCMServRTMTPlugin.exe from our CUCM 7.1.3 cluster (any of the servers). What I end up with is a file with a name that is the IP address of the publisher that I can't do anything with.
I 've been able to get the file from my development server so its not a total disaster. Question is, "can I upload (tftp) the good copy of the file to live cluster and if so, which directory does it need to reside in or do I require assistance from TAC".
Of course the other burning question is what caused this to happen in the first place and that remains to be seen.
Thanks in advance
Richard
1 ACCEPTED SOLUTION
Green
Can you try opening a fresh browser
Url to:-
https:// IP ADD>/plugins/CcmServRtmtPlugin.exe
Does this help
Alex
Regards, Alex. Please rate useful posts.
No, you cannot upload plugins to CUCM.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Green
Url to:-
Does this help
Alex
Hi Alex
Brilliant! That works just fine. So is it a browser config issue that I have overlooked?
Best regards
Richard
Hi Javalenc
I thought as much but it doesn't hurt to ask.
Thanks anyway
Richard
Hi All
Well I've got to the bottom of the "why"
I noticed that if I clicked on the Plugin Name (Cisco Unified CM Real-Time Monitoring Tool - Windows) as opposed to "Download", the custom URL box had the IP address of the publisher entered. The other plugins all had the custom URL box blank.
Removing the custom URL entry has resolved the issue.
Thanks Java and Alex for your contributions.
Best regards
Richard
943
