Unable to DSP services for Conferencing
I cannot start DSPFARM services for conferencing on my gateway.  Everything appears to be configured correctly.  Any thoughts?
Thanky you
1 ACCEPTED SOLUTION
VIP Super Bronze
You're out of DSPs.
Bringing up the 23 channels of a PRI and the four FXO ports fully consumed your PVDM3-32. You would need an additional DSP chip before you can configure a conference bridge. The DSP Calculator can help you properly size the DSPs.
Another note I have another Gateway same HW specs and it works correctly.  I can upload my config for reference
Exactly at what config step and what error are you getting?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Cannot configure max sessions on the dsp profile for conferencing.
VIP Super Bronze
Let's see the config as well as an output of 'show inventory' and 'show voice dsp detailed'. Typically the reason why it won't allow you to allocate DSPs to conferencing is if they have already been used up elsewhere.
Config:
boot-start-marker
boot-end-marker
card type t1 0 0
logging buffered 1000000
enable secret 5 $1$jWC0$TjEpeJ3CtLWrb.ZE8ApX4.
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
--More--         no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name
isdn switch-type primary-ni
trunk group 911TRUNK
trunk group SRSTTRUNK
--More--         trunk group SRST
crypto pki trustpoint TP-self-signed-3532275378
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3532275378
revocation-check none
rsakeypair TP-self-signed-3532275378
crypto pki certificate chain TP-self-signed-3532275378
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33353332 32373533 3738301E 170D3131 30333132 30313435
  35365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 35333232
  37353337 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B0D1 891FDB2D EF671A64 C6ECCB12 3AE009B0 A949EB9A D6B77131 CC3004D8
  0166C70E 0BBFC118 DEF67963 E756C601 D14B2B39 C83937C2 71174047 D69940FB
  2DE200DB 99BC7D49 99B95AB4 99B9A625 A8C79E25 E4A95660 45BA2047 84238539
  CCD56D16 9EE00208 5AAC60AF 458E6863 4159AC14 127051A0 11FBBED1 14566B26
  44310203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
--More--           551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 141E1C39 1829EEAF C9021DF8 ED460B62 4F676C8F
  A3301D06 03551D0E 04160414 1E1C3918 29EEAFC9 021DF8ED 460B624F 676C8FA3
  300D0609 2A864886 F70D0101 04050003 81810079 B01A8369 42EB8240 87394A41
  8298B799 E545324A 586459B9 08B67543 4A1BB40C 646B66F2 73C38D4D 060D529D
  E013AB05 D498093C B6729BB4 F65C6240 8877C6FC CB916AAE 974C74AD BDE5F6BD
  6F47AEB5 975A2ACA 84C5190D 3191BCDB BD7E4D64 D3DC6185 518C069B 702945D9
  1BA6E648 489569EF 49C34388 A7C2A91B 4AB2BA
            quit
voice-card 0
dspfarm
dsp services dspfarm
license udi pid CISCO2921/K9 sn FTX1511AMLU
hw-module pvdm 0/0
--More--         username SJ-admin privilege 15 password 7 15212105143E
redundancy
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24 service mgcp
description =
interface GigabitEthernet0/0
description Uplink to
ip address 10.81.54.2 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
--More--          duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
router eigrp 1
network 10.81.0.0 0.0.255.255
passive-interface default
no passive-interface GigabitEthernet0/0
--More--         ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
control-plane
voice-port 0/0/0:23
echo-cancel coverage 64
voice-port 0/1/0
trunk-group 911TRUNK
voice-port 0/1/1
trunk-group SRSTTRUNK
--More--         !
voice-port 0/1/2
voice-port 0/1/3
trunk-group SRST
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.80.51.100
ccm-manager config
mgcp
mgcp call-agent 10.80.51.100 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
--More--         no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.80.51.100 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 10 register 1216_Bay_CONF
associate profile 20 register 1216_Bay_TRAN
switchback method graceful
sccp ccm group 999
dspfarm profile 20 transcode
--More--          codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g722-64
maximum sessions 1
associate application SCCP
dspfarm profile 10 conference
description conferencing
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec g722-64
shutdown
dial-peer voice 1 pots
description ***Incoming Calls on Port 0/0/0:23***
--More--          incoming called-number .
direct-inward-dial
dial-peer voice 91101 pots
description ***Outbound 911 Calls on Port 0/0/0:23***
destination-pattern 911
forward-digits 3
dial-peer voice 91102 pots
trunkgroup SRSTTRUNKGROUP
trunkgroup 911TRUNK 1
trunkgroup SRSTTRUNK 2
description ***Outbound 911 Calls on FXO Trunk Group***
forward-digits 3
dial-peer voice 991101 pots
description ***Outbound 9911 Calls on Port 0/0/0:23***
destination-pattern 9911
forward-digits 3
dial-peer voice 991102 pots
--More--          trunkgroup SRSTTRUNK 2
description ***Outbound 9911 Calls on FXO Trunk Group***
forward-digits 3
dial-peer voice 10001 pots
description ***Outbound Local Calls on Port 0/0/0:23***
destination-pattern 9718[2-9]..[2-9]......
port 0/0/0:23
forward-digits 10
dial-peer voice 10002 pots
description ***Outbound Local Calls on FXO Trunk Group***
forward-digits 10
dial-peer voice 30001 pots
description ***Outbound Long Distance Calls on Port 0/0/0:23***
destination-pattern 91[2-9]..[2-9]......
port 0/0/0:23
forward-digits 11
--More--         dial-peer voice 30002 pots
description ***Outbound Long Distance Calls on FXO Trunk Group***
forward-digits 11
dial-peer voice 40001 pots
description ***Outbound International Calls on Port 0/0/0:23***
destination-pattern 9011T
port 0/0/0:23
prefix 011
dial-peer voice 40002 pots
description ***Outbound International Calls on FXO Trunk Group***
prefix 011
gatekeeper
shutdown
--More--         !
call-manager-fallback
secondary-dialtone 9
max-conferences 6 gain -6
transfer-system full-consult
ip source-address 10.81.54.2 port 2000
max-ephones 110
max-dn 300
system message primary Call Manager Failover
transfer-pattern ....
VGW_01#sho dsp         voice de   sp detailed
DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
edsp 0001 01 g711ulaw  0.1 IDLE  50/0/1.1
edsp 0002 01 g711ulaw  0.1 IDLE  50/0/2.1
edsp 0003 01 g711ulaw  0.1 IDLE  50/0/3.1
edsp 0004 01 g711ulaw  0.1 IDLE  50/0/4.1
edsp 0005 01 g729r8 p  0.1 IDLE  50/0/5.1
edsp 0006 01 g711ulaw  0.1 IDLE  50/0/6.1
edsp 0007 01 g729r8 p  0.1 IDLE  50/0/7.1
edsp 0008 01 g711ulaw  0.1 IDLE  50/0/8.1
edsp 0009 01 g729r8 p  0.1 IDLE  50/0/9.1
edsp 0010 01 g711ulaw  0.1 IDLE  50/0/10.1
edsp 0011 01 g711ulaw  0.1 IDLE  50/0/11.1
edsp 0012 01 g711ulaw  0.1 IDLE  50/0/12.1
edsp 0013 01 g711ulaw  0.1 IDLE  50/0/13.1
edsp 0014 01 g711ulaw  0.1 IDLE  50/0/14.1
edsp 0015 01 g711ulaw  0.1 IDLE  50/0/15.1
edsp 0016 01 g711ulaw  0.1 IDLE  50/0/16.1
edsp 0017 01 g711ulaw  0.1 IDLE  50/0/17.1
edsp 0018 01 g711ulaw  0.1 IDLE  50/0/18.1
edsp 0019 01 g711ulaw  0.1 IDLE  50/0/19.1
edsp 0020 01 g711ulaw  0.1 IDLE  50/0/20.1
edsp 0021 01 g711ulaw  0.1 IDLE  50/0/21.1
edsp 0022 01 g711ulaw  0.1 IDLE  50/0/22.1
edsp 0023 01 g729r8 p  0.1 IDLE  50/0/23.1
--More--                           edsp 0024 01 g711ulaw  0.1 IDLE  50/0/24.1
edsp 0025 01 g729r8 p  0.1 IDLE  50/0/25.1
edsp 0026 01 g729r8 p  0.1 IDLE  50/0/26.1
edsp 0027 01 g711ulaw  0.1 IDLE  50/0/27.1
edsp 0028 01 g711ulaw  0.1 IDLE  50/0/28.1
edsp 0029 01 g711ulaw  0.1 IDLE  50/0/29.1
edsp 0030 01 g711ulaw  0.1 IDLE  50/0/30.1
edsp 0031 01 g729r8 p  0.1 IDLE  50/0/31.1
edsp 0032 01 g729r8 p  0.1 IDLE  50/0/32.1
edsp 0033 01 g729r8 p  0.1 IDLE  50/0/33.1
edsp 0034 01 g729r8 p  0.1 IDLE  50/0/34.1
edsp 0035 01 g729r8 p  0.1 IDLE  50/0/35.1
edsp 0036 01 g729r8 p  0.1 IDLE  50/0/36.1
edsp 0037 01 g729r8 p  0.1 IDLE  50/0/37.1
edsp 0038 01 g729r8 p  0.1 IDLE  50/0/38.1
edsp 0039 01 g729r8 p  0.1 IDLE  50/0/39.1
edsp 0040 01 g729r8 p  0.1 IDLE  50/0/40.1
edsp 0041 01 g729r8 p  0.1 IDLE  50/0/41.1
edsp 0042 01 g729r8 p  0.1 IDLE  50/0/42.1
edsp 0043 01 g729r8 p  0.1 IDLE  50/0/43.1
edsp 0044 01 g729r8 p  0.1 IDLE  50/0/44.1
edsp 0045 01 g729r8 p  0.1 IDLE  50/0/45.1
edsp 0046 01 g729r8 p  0.1 IDLE  50/0/46.1
--More--                           edsp 0047 01 g729r8 p  0.1 IDLE  50/0/47.1
edsp 0048 01 g729r8 p  0.1 IDLE  50/0/48.1
edsp 0049 01 g729r8 p  0.1 IDLE  50/0/49.1
edsp 0050 01 g729r8 p  0.1 IDLE  50/0/50.1
edsp 0051 01 g729r8 p  0.1 IDLE  50/0/51.1
edsp 0052 01 g729r8 p  0.1 IDLE  50/0/52.1
edsp 0053 01 g729r8 p  0.1 IDLE  50/0/53.1
edsp 0054 01 g729r8 p  0.1 IDLE  50/0/54.1
edsp 0055 01 g729r8 p  0.1 IDLE  50/0/55.1
edsp 0056 01 g729r8 p  0.1 IDLE  50/0/56.1
edsp 0057 01 g729r8 p  0.1 IDLE  50/0/57.1
edsp 0058 01 g729r8 p  0.1 IDLE  50/0/58.1
edsp 0059 01 g729r8 p  0.1 IDLE  50/0/59.1
edsp 0060 01 g729r8 p  0.1 IDLE  50/0/60.1
edsp 0061 01 g729r8 p  0.1 IDLE  50/0/61.1
edsp 0062 01 g729r8 p  0.1 IDLE  50/0/62.1
edsp 0063 01 g729r8 p  0.1 IDLE  50/0/63.1
edsp 0064 01 g729r8 p  0.1 IDLE  50/0/64.1
edsp 0065 01 g729r8 p  0.1 IDLE  50/0/65.1
edsp 0066 01 g729r8 p  0.1 IDLE  50/0/66.1
edsp 0067 01 g729r8 p  0.1 IDLE  50/0/67.1
edsp 0068 01 g729r8 p  0.1 IDLE  50/0/68.1
edsp 0069 01 g729r8 p  0.1 IDLE  50/0/69.1
--More--                           edsp 0070 01 g729r8 p  0.1 IDLE  50/0/70.1
edsp 0071 01 g729r8 p  0.1 IDLE  50/0/71.1
edsp 0072 01 g729r8 p  0.1 IDLE  50/0/72.1
edsp 0073 01 g729r8 p  0.1 IDLE  50/0/73.1
edsp 0074 01 g729r8 p  0.1 IDLE  50/0/74.1
edsp 0075 01 g729r8 p  0.1 IDLE  50/0/75.1
edsp 0076 01 g729r8 p  0.1 IDLE  50/0/76.1
edsp 0077 01 g729r8 p  0.1 IDLE  50/0/77.1
edsp 0078 01 g729r8 p  0.1 IDLE  50/0/78.1
edsp 0079 01 g729r8 p  0.1 IDLE  50/0/79.1
edsp 0080 01 g729r8 p  0.1 IDLE  50/0/80.1
edsp 0081 01 g729r8 p  0.1 IDLE  50/0/81.1
edsp 0082 01 g729r8 p  0.1 IDLE  50/0/82.1
edsp 0083 01 g729r8 p  0.1 IDLE  50/0/83.1
edsp 0084 01 g729r8 p  0.1 IDLE  50/0/84.1
edsp 0085 01 g729r8 p  0.1 IDLE  50/0/85.1
edsp 0086 01 g729r8 p  0.1 IDLE  50/0/86.1
edsp 0087 01 g729r8 p  0.1 IDLE  50/0/87.1
edsp 0088 01 g729r8 p  0.1 IDLE  50/0/88.1
edsp 0089 01 g729r8 p  0.1 IDLE  50/0/89.1
edsp 0090 01 g729r8 p  0.1 IDLE  50/0/90.1
edsp 0091 01 g729r8 p  0.1 IDLE  50/0/91.1
edsp 0092 01 g729r8 p  0.1 IDLE  50/0/92.1
--More--                           edsp 0093 01 g729r8 p  0.1 IDLE  50/0/93.1
edsp 0094 01 g729r8 p  0.1 IDLE  50/0/94.1
edsp 0095 01 g729r8 p  0.1 IDLE  50/0/95.1
edsp 0096 01 g729r8 p  0.1 IDLE  50/0/96.1
edsp 0097 01 g729r8 p  0.1 IDLE  50/0/97.1
edsp 0098 01 g729r8 p  0.1 IDLE  50/0/98.1
edsp 0099 01 g729r8 p  0.1 IDLE  50/0/99.1
edsp 0100 01 g729r8 p  0.1 IDLE  50/0/100.1
edsp 0101 01 g729r8 p  0.1 IDLE  50/0/101.1
edsp 0102 01 g729r8 p  0.1 IDLE  50/0/102.1
edsp 0103 01 g729r8 p  0.1 IDLE  50/0/103.1
edsp 0104 01 g729r8 p  0.1 IDLE  50/0/104.1
edsp 0105 01 g729r8 p  0.1 IDLE  50/0/105.1
edsp 0106 01 g729r8 p  0.1 IDLE  50/0/106.1
edsp 0107 01 g729r8 p  0.1 IDLE  50/0/107.1
edsp 0108 01 g729r8 p  0.1 IDLE  50/0/108.1
edsp 0109 01 g729r8 p  0.1 IDLE  50/0/109.1
edsp 0110 01 g729r8 p  0.1 IDLE  50/0/110.1
edsp 0111 01 g729r8 p  0.1 IDLE  50/0/111.1
edsp 0112 01 g729r8 p  0.1 IDLE  50/0/112.1
edsp 0113 01 g729r8 p  0.1 IDLE  50/0/113.1
edsp 0114 01 g729r8 p  0.1 IDLE  50/0/114.1
edsp 0115 01 g729r8 p  0.1 IDLE  50/0/115.1
--More--                           edsp 0116 01 g729r8 p  0.1 IDLE  50/0/116.1
edsp 0117 01 g729r8 p  0.1 IDLE  50/0/117.1
edsp 0118 01 g729r8 p  0.1 IDLE  50/0/118.1
edsp 0119 01 g729r8 p  0.1 IDLE  50/0/119.1
edsp 0120 01 g729r8 p  0.1 IDLE  50/0/120.1
edsp 0121 01 g729r8 p  0.1 IDLE  50/0/121.1
edsp 0122 01 g729r8 p  0.1 IDLE  50/0/122.1
edsp 0123 01 g729r8 p  0.1 IDLE  50/0/123.1
edsp 0124 01 g729r8 p  0.1 IDLE  50/0/124.1
edsp 0125 01 g729r8 p  0.1 IDLE  50/0/125.1
edsp 0126 01 g729r8 p  0.1 IDLE  50/0/126.1
edsp 0127 01 g729r8 p  0.1 IDLE  50/0/127.1
edsp 0128 01 g729r8 p  0.1 IDLE  50/0/128.1
edsp 0129 01 g729r8 p  0.1 IDLE  50/0/129.1
edsp 0130 01 g729r8 p  0.1 IDLE  50/0/130.1
edsp 0131 01 g729r8 p  0.1 IDLE  50/0/131.1
edsp 0132 01 g729r8 p  0.1 IDLE  50/0/132.1
edsp 0133 01 g729r8 p  0.1 IDLE  50/0/133.1
edsp 0134 01 g729r8 p  0.1 IDLE  50/0/134.1
edsp 0135 01 g729r8 p  0.1 IDLE  50/0/135.1
edsp 0136 01 g729r8 p  0.1 IDLE  50/0/136.1
edsp 0137 01 g729r8 p  0.1 IDLE  50/0/137.1
edsp 0138 01 g729r8 p  0.1 IDLE  50/0/138.1
--More--                           edsp 0139 01 g729r8 p  0.1 IDLE  50/0/139.1
edsp 0140 01 g729r8 p  0.1 IDLE  50/0/140.1
edsp 0141 01 g729r8 p  0.1 IDLE  50/0/141.1
edsp 0142 01 g729r8 p  0.1 IDLE  50/0/142.1
edsp 0143 01 g729r8 p  0.1 IDLE  50/0/143.1
edsp 0144 01 g729r8 p  0.1 IDLE  50/0/144.1
edsp 0145 01 g729r8 p  0.1 IDLE  50/0/145.1
edsp 0146 01 g729r8 p  0.1 IDLE  50/0/146.1
edsp 0147 01 g729r8 p  0.1 IDLE  50/0/147.1
edsp 0148 01 g729r8 p  0.1 IDLE  50/0/148.1
edsp 0149 01 g729r8 p  0.1 IDLE  50/0/149.1
edsp 0150 01 g729r8 p  0.1 IDLE  50/0/150.1
edsp 0151 01 g729r8 p  0.1 IDLE  50/0/151.1
edsp 0152 01 g729r8 p  0.1 IDLE  50/0/152.1
edsp 0153 01 g729r8 p  0.1 IDLE  50/0/153.1
edsp 0154 01 g729r8 p  0.1 IDLE  50/0/154.1
edsp 0155 01 g729r8 p  0.1 IDLE  50/0/155.1
edsp 0156 01 g729r8 p  0.1 IDLE  50/0/156.1
edsp 0157 01 g729r8 p  0.1 IDLE  50/0/157.1
edsp 0158 01 g729r8 p  0.1 IDLE  50/0/158.1
edsp 0159 01 g729r8 p  0.1 IDLE  50/0/159.1
edsp 0160 01 g729r8 p  0.1 IDLE  50/0/160.1
edsp 0161 01 g729r8 p  0.1 IDLE  50/0/161.1
--More--                           edsp 0162 01 g729r8 p  0.1 IDLE  50/0/162.1
edsp 0163 01 g729r8 p  0.1 IDLE  50/0/163.1
edsp 0164 01 g729r8 p  0.1 IDLE  50/0/164.1
edsp 0165 01 g729r8 p  0.1 IDLE  50/0/165.1
edsp 0166 01 g729r8 p  0.1 IDLE  50/0/166.1
edsp 0167 01 g729r8 p  0.1 IDLE  50/0/167.1
edsp 0168 01 g729r8 p  0.1 IDLE  50/0/168.1
edsp 0169 01 g729r8 p  0.1 IDLE  50/0/169.1
edsp 0170 01 g729r8 p  0.1 IDLE  50/0/170.1
edsp 0171 01 g729r8 p  0.1 IDLE  50/0/171.1
edsp 0172 01 g729r8 p  0.1 IDLE  50/0/172.1
edsp 0173 01 g729r8 p  0.1 IDLE  50/0/173.1
edsp 0174 01 g729r8 p  0.1 IDLE  50/0/174.1
edsp 0175 01 g729r8 p  0.1 IDLE  50/0/175.1
edsp 0176 01 g729r8 p  0.1 IDLE  50/0/176.1
edsp 0177 01 g729r8 p  0.1 IDLE  50/0/177.1
edsp 0178 01 g729r8 p  0.1 IDLE  50/0/178.1
edsp 0179 01 g729r8 p  0.1 IDLE  50/0/179.1
edsp 0180 01 g729r8 p  0.1 IDLE  50/0/180.1
edsp 0181 01 g729r8 p  0.1 IDLE  50/0/181.1
edsp 0182 01 g729r8 p  0.1 IDLE  50/0/182.1
edsp 0183 01 g729r8 p  0.1 IDLE  50/0/183.1
edsp 0184 01 g729r8 p  0.1 IDLE  50/0/184.1
--More--                           edsp 0185 01 g729r8 p  0.1 IDLE  50/0/185.1
edsp 0186 01 g729r8 p  0.1 IDLE  50/0/186.1
edsp 0187 01 g729r8 p  0.1 IDLE  50/0/187.1
edsp 0188 01 g729r8 p  0.1 IDLE  50/0/188.1
edsp 0189 01 g729r8 p  0.1 IDLE  50/0/189.1
edsp 0190 01 g729r8 p  0.1 IDLE  50/0/190.1
edsp 0191 01 g729r8 p  0.1 IDLE  50/0/191.1
edsp 0192 01 g729r8 p  0.1 IDLE  50/0/192.1
edsp 0193 01 g729r8 p  0.1 IDLE  50/0/193.1
edsp 0194 01 g729r8 p  0.1 IDLE  50/0/194.1
edsp 0195 01 g729r8 p  0.1 IDLE  50/0/195.1
edsp 0196 01 g729r8 p  0.1 IDLE  50/0/196.1
edsp 0197 01 g729r8 p  0.1 IDLE  50/0/197.1
edsp 0198 01 g729r8 p  0.1 IDLE  50/0/198.1
edsp 0199 01 g729r8 p  0.1 IDLE  50/0/199.1
edsp 0200 01 g729r8 p  0.1 IDLE  50/0/200.1
edsp 0201 01 g729r8 p  0.1 IDLE  50/0/201.1
edsp 0202 01 g729r8 p  0.1 IDLE  50/0/202.1
edsp 0203 01 g729r8 p  0.1 IDLE  50/0/203.1
edsp 0204 01 g729r8 p  0.1 IDLE  50/0/204.1
edsp 0205 01 g729r8 p  0.1 IDLE  50/0/205.1
edsp 0206 01 g729r8 p  0.1 IDLE  50/0/206.1
edsp 0207 01 g729r8 p  0.1 IDLE  50/0/207.1
--More--                           edsp 0208 01 g729r8 p  0.1 IDLE  50/0/208.1
edsp 0209 01 g729r8 p  0.1 IDLE  50/0/209.1
edsp 0210 01 g729r8 p  0.1 IDLE  50/0/210.1
edsp 0211 01 g729r8 p  0.1 IDLE  50/0/211.1
edsp 0212 01 g729r8 p  0.1 IDLE  50/0/212.1
edsp 0213 01 g729r8 p  0.1 IDLE  50/0/213.1
edsp 0214 01 g729r8 p  0.1 IDLE  50/0/214.1
edsp 0215 01 g729r8 p  0.1 IDLE  50/0/215.1
edsp 0216 01 g729r8 p  0.1 IDLE  50/0/216.1
edsp 0217 01 g729r8 p  0.1 IDLE  50/0/217.1
edsp 0218 01 g729r8 p  0.1 IDLE  50/0/218.1
edsp 0219 01 g729r8 p  0.1 IDLE  50/0/219.1
edsp 0220 01 g729r8 p  0.1 IDLE  50/0/220.1
edsp 0221 01 g729r8 p  0.1 IDLE  50/0/221.1
edsp 0222 01 g729r8 p  0.1 IDLE  50/0/222.1
edsp 0223 01 g729r8 p  0.1 IDLE  50/0/223.1
edsp 0224 01 g729r8 p  0.1 IDLE  50/0/224.1
edsp 0225 01 g729r8 p  0.1 IDLE  50/0/225.1
edsp 0226 01 g729r8 p  0.1 IDLE  50/0/226.1
edsp 0227 01 g729r8 p  0.1 IDLE  50/0/227.1
edsp 0228 01 g729r8 p  0.1 IDLE  50/0/228.1
edsp 0229 01 g729r8 p  0.1 IDLE  50/0/229.1
edsp 0230 01 g729r8 p  0.1 IDLE  50/0/230.1
--More--                           edsp 0231 01 g729r8 p  0.1 IDLE  50/0/231.1
edsp 0232 01 g729r8 p  0.1 IDLE  50/0/232.1
edsp 0233 01 g729r8 p  0.1 IDLE  50/0/233.1
edsp 0234 01 g729r8 p  0.1 IDLE  50/0/234.1
edsp 0235 01 g729r8 p  0.1 IDLE  50/0/235.1
edsp 0236 01 g729r8 p  0.1 IDLE  50/0/236.1
edsp 0237 01 g729r8 p  0.1 IDLE  50/0/237.1
edsp 0238 01 g729r8 p  0.1 IDLE  50/0/238.1
edsp 0239 01 g729r8 p  0.1 IDLE  50/0/239.1
edsp 0240 01 g729r8 p  0.1 IDLE  50/0/240.1
edsp 0241 01 g729r8 p  0.1 IDLE  50/0/241.1
edsp 0242 01 g729r8 p  0.1 IDLE  50/0/242.1
edsp 0243 01 g729r8 p  0.1 IDLE  50/0/243.1
edsp 0244 01 g729r8 p  0.1 IDLE  50/0/244.1
edsp 0245 01 g729r8 p  0.1 IDLE  50/0/245.1
edsp 0246 01 g729r8 p  0.1 IDLE  50/0/246.1
edsp 0247 01 g729r8 p  0.1 IDLE  50/0/247.1
edsp 0248 01 g729r8 p  0.1 IDLE  50/0/248.1
edsp 0249 01 g729r8 p  0.1 IDLE  50/0/249.1
edsp 0250 01 g729r8 p  0.1 IDLE  50/0/250.1
edsp 0251 01 g729r8 p  0.1 IDLE  50/0/251.1
edsp 0252 01 g729r8 p  0.1 IDLE  50/0/252.1
edsp 0253 01 g729r8 p  0.1 IDLE  50/0/253.1
--More--                           edsp 0254 01 g729r8 p  0.1 IDLE  50/0/254.1
edsp 0255 01 g729r8 p  0.1 IDLE  50/0/255.1
edsp 0256 01 g729r8 p  0.1 IDLE  50/0/256.1
edsp 0257 01 g729r8 p  0.1 IDLE  50/0/257.1
edsp 0258 01 g729r8 p  0.1 IDLE  50/0/258.1
edsp 0259 01 g729r8 p  0.1 IDLE  50/0/259.1
edsp 0260 01 g729r8 p  0.1 IDLE  50/0/260.1
edsp 0261 01 g729r8 p  0.1 IDLE  50/0/261.1
edsp 0262 01 g729r8 p  0.1 IDLE  50/0/262.1
edsp 0263 01 g729r8 p  0.1 IDLE  50/0/263.1
edsp 0264 01 g729r8 p  0.1 IDLE  50/0/264.1
edsp 0265 01 g729r8 p  0.1 IDLE  50/0/265.1
edsp 0266 01 g729r8 p  0.1 IDLE  50/0/266.1
edsp 0267 01 g729r8 p  0.1 IDLE  50/0/267.1
edsp 0268 01 g729r8 p  0.1 IDLE  50/0/268.1
edsp 0269 01 g729r8 p  0.1 IDLE  50/0/269.1
edsp 0270 01 g729r8 p  0.1 IDLE  50/0/270.1
edsp 0271 01 g729r8 p  0.1 IDLE  50/0/271.1
edsp 0272 01 g729r8 p  0.1 IDLE  50/0/272.1
edsp 0273 01 g729r8 p  0.1 IDLE  50/0/273.1
edsp 0274 01 g729r8 p  0.1 IDLE  50/0/274.1
edsp 0275 01 g729r8 p  0.1 IDLE  50/0/275.1
edsp 0276 01 g729r8 p  0.1 IDLE  50/0/276.1
--More--                           edsp 0277 01 g729r8 p  0.1 IDLE  50/0/277.1
edsp 0278 01 g729r8 p  0.1 IDLE  50/0/278.1
edsp 0279 01 g729r8 p  0.1 IDLE  50/0/279.1
edsp 0280 01 g729r8 p  0.1 IDLE  50/0/280.1
edsp 0281 01 g729r8 p  0.1 IDLE  50/0/281.1
edsp 0282 01 g729r8 p  0.1 IDLE  50/0/282.1
edsp 0283 01 g729r8 p  0.1 IDLE  50/0/283.1
edsp 0284 01 g729r8 p  0.1 IDLE  50/0/284.1
edsp 0285 01 g729r8 p  0.1 IDLE  50/0/285.1
edsp 0286 01 g729r8 p  0.1 IDLE  50/0/286.1
edsp 0287 01 g729r8 p  0.1 IDLE  50/0/287.1
edsp 0288 01 g729r8 p  0.1 IDLE  50/0/288.1
edsp 0289 01 g729r8 p  0.1 IDLE  50/0/289.1
edsp 0290 01 g729r8 p  0.1 IDLE  50/0/290.1
edsp 0291 01 g729r8 p  0.1 IDLE  50/0/291.1
edsp 0292 01 g729r8 p  0.1 IDLE  50/0/292.1
edsp 0293 01 g729r8 p  0.1 IDLE  50/0/293.1
edsp 0294 01 g729r8 p  0.1 IDLE  50/0/294.1
edsp 0295 01 g729r8 p  0.1 IDLE  50/0/295.1
edsp 0296 01 g729r8 p  0.1 IDLE  50/0/296.1
edsp 0297 01 g729r8 p  0.1 IDLE  50/0/297.1
edsp 0298 01 g729r8 p  0.1 IDLE  50/0/298.1
edsp 0299 01 g729r8 p  0.1 IDLE  50/0/299.1
--More--                           edsp 0300 01 g729r8 p  0.1 IDLE  50/0/300.1
----------------------------FLEX VOICE CARD 0 -----------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
SP2600 001 01 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 02 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 03 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 04 None          26.3.8 idle  idle      0  0                 0          0/0
--More--                           SP2600 001 05 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 06 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 07 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 08 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 09 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 10 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 11 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 12 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 13 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 14 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 15 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 16 None          26.3.8 idle  idle      0  0                 0          0/0
--More--                           SP2600 001 17 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 18 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 19 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 20 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 21 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 22 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 23 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 24 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 25 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 26 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 27 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 28 None          26.3.8 idle  idle      0  0                 0          0/0
--More--                           SP2600 001 29 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 30 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 31 None          26.3.8 idle  idle      0  0                 0          0/0
SP2600 001 32 None          26.3.8 idle  idle      0  0                 0          0/0
                           *DSP SIGNALING CHANNELS*
SP2600 001 01 {flex}        26.3.8 alloc idle      0  0 0/1/0     02    0         36/0
SP2600 001 02 {flex}        26.3.8 alloc idle      0  0 0/1/1     06    0        144/0
SP2600 001 03 {flex}        26.3.8 alloc idle      0  0 0/1/2     10    0         36/0
SP2600 001 04 {flex}        26.3.8 alloc idle      0  0 0/1/3     14    0         53/0
--More--                           ------------------------END OF FLEX VOICE CARD 0 ----------------------------
VGW_01#sho inventory
NAME: "CISCO2921/K9 chassis", DESCR: "CISCO2921/K9 chassis"
PID: CISCO2921/K9      , VID: V03 , SN: FTX1511AMLU
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1  , VID: V01 , SN: FOC150703P5
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V03 , SN: FOC15083VFD
NAME: "PVDM3 DSP DIMM with 32 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 32 Channels"
PID: PVDM3-32          , VID: V01 , SN: FOC15094TCP
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V02 , SN: QCS1508H0ZJ
_VGW_01#
VIP Super Bronze
You're out of DSPs.
If I reduce the channels on the PRI.  I do not believe we need all channels because it is only approximately 25 phones 12 of which are DiD's.  FXO is being used for SRST.  What are you thoughts?  I would like to avoid purchasing additional hardware.
VIP Super Bronze
That should work as long as you use low complexity codecs and/or shutdown enough timeslots. Spend some time in the calculator to get comfortable. The problem is that CUCM doesn't support fractional PRIs with MGCP. You would need to change the router to H.323/SIP to manually control the channel-group timeslots. You would also want to place an order with your carrier to have the CO switch match whatever timeslots you choose to leave up.
Please rate helpful replies.
Jon,
Thanks for the replies.  I do not think I want to convert to SIP.  I am new to the VoIP configuration and appreciate all the help.
One more question.  By looking at the DSP calculator I cannot determine if a PVDM3-16 or PVDM3-32 will be needed.  Any assistance is appreciated.
VIP Super Bronze
The answer depends on how many channels you intend to shutdown and how many conferences you want to support.
I do not need to have more than 4 conference's at one time.  Let make the assumption I do not shut any channels down
VIP Super Bronze
You would need to add a PVDM3-32 for a total of -64 in this case. Again, this assumes you only use low complexity codecs.
596
