Unable to find 32 bit TAPI Installer UC or CME
Steve Davis
For the 64 bit machines, I am successfully able to use the following:
TSPSingleLInex64-2-2-0-8.exe
I have been unable to find the 32 bit version. Can anyone direct me to the right link please?
thanks,
Steve Davis
The above is a Cisco site.
The released CallConnector 32bit for ISR routers also works.
Please remember to rate useful post clicking on the stars below.
6 Replies 6
Steve Davis
I see in documentation that the download is possibly CiscoUnifiedCME_TSPSetup201.exe, but I cannot find it on the Cisco site....
Hi Steve,
This file TSPSingleLInex64-2-2-0-8.exe is for 32 and 64 bit version. Just name is confusing. You cna use it for 32 bits also.
Ronak patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Ronak, I had to use an older version for 32 bit. I get an error when installing he TSPx64 on a 32 bit. Is this not typical?
Steve Davis
You cannot install TAPI 64 on a 32 bit system.
You can use the CUE "toolbar"
https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi?CONTYPES=UC500
Just ignore the incompatibility message, the popup is not needed for TAPI to work.
So you are saying that Cisco no longer releases TAPI software for a 32 bit OS?
Steve Davis
