Unable to Find CUE Script Editor on Cisco's Website
I have got an environment using Cisco Unified Communications Express version 7.0 but I am not able to find the following software:
Cisco Unity Express Auto Attendant Scripts Editor
Cisco Unity Express Script Validate Tool
I would need the software to create a new call flow for the environment. Any help would be very much appreciated. Thanks.
Mohammed Noor
Everyone's tags (6)
Re: Unable to Find CUE Script Editor on Cisco's Website
Hi Mohammed,
The script editor has also been built in to the CUE gui. It can be found under system -> scripts.
Best,
David
Mohammed,
Just to let you know, the latest CUE editor is 8.6.1 (not 7.0.6 as posted above):
http://www.cisco.com/cisco/software/release.html?mdfid=283671889&flowid=31833&softwareid=282774364&release=8.6.1&relind=AVAILABLE&rellifecycle=&reltype=latest
Please remember to rate helpful resonses and identify correct answers.
Best,
David
1252
