Community Member
Unable to find phone type in CUCM for manual registration
We are using CUCM 8.0.3 , unable to find Phone type Cisco 8831 for manual registration. How can I add this phone type to CUCM ? Any help is appreciated.
2 ACCEPTED SOLUTIONS
Hello,have you added the
have you added the device pack .If no please upload it in CUCM and then update
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
Further :you can also refer the IP phone feature and CUCM device pack compatibility matrix.
Br,
Nadeem Ahmed
Br, Nadeem Please rate all useful post.
Hall of Fame Super Red
Hi there, +5 to my friends
Hi there,
+5 to my friends Mahmood & Nadeem here for their good ideas.
The problem here is that there is no Device Pack for CUCM 8.0.3 that supports the 8831 :( The ReadMe below is for the last/latest 8.0.3 device pack;
http://www.cisco.com/web/software/282074299/92918/cmterm-devicepack-8_0_3_24051-1_Readme.pdf
You would need to upgrade CUCM to a minimum of 8.5.1 and then install ;
Cisco Unified Communications Manager 8.5(1.17118-1) Device Package - Compatible UCM Version: 8.5
cmterm-devicepack8.5.1.17121-1.cop.sgn
Cheers!
Rob
Hi,It seems you need to add
It seems you need to add the device support package.
Br,
Nadeem Ahmed
Hi there,
Cheers!
Rob
137
