Unable to Forward calls to Call Handler o Analog Lines
I do have Analog lines. I need any call land on the Operator Phone (DN: 200) will ring 3 times, if the Operator doesn't pick the call within 3 rings, call will be forwarded to the Call Handler where a message will be played & based upon caller input calls will be landed on the required extensions.
For this reason, i have created a Call Hander in Unity Connection 250.From internally, if i dial 250 i can reach to the Call Handler successfully...
The problem i am facing is that: if i don't pick the call, then i only can hear the default welcome message from Unity (means the call is not landing to the call handler that i created)....i tried to put 250 (call handler) in the field "No answer External"..but no luck...
Can anyone help me out in this!!!!
CUCM Version: 7.1.2
UC: 2.1
Re: Unable to Forward calls to Call Handler o Analog Lines
That's WAD, CUC uses the original called number to route the call
Configure call routing rules accordingly.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
create a CTI with number 250
and check the check box forward all to tvoice mail
in the DN 200 forward no answer set to 250
this will be like
200 no answer >> CTI 250 >>FW VM>>> CH 250
also check the setting of the call handler under transfered call make sure it is set to play greeting
good luck
if helpful Rate
That won't work, Unity will try to reach VM for 200.
Again, original called number behavior. WAD.
java
java
another way
from the intial post when the call get forwarded to the VM you hear the default Welcome message of unity
this indecate that DN 200 has no VM
you can make the call handeler number as 200 and in the 200 DN setting set the CFNA to be forward to VM instead of number
thats dos not mean you creating VM to DN 200 ( assuming this DN dose need any VM )
in this case the call will be forwarded to the VM and becuase the call handeler has same number as the DN the CH wil answer the forwarded call
good luck
if helpful Rate
345
