Unable to forward the Calls from IP Phone to Mobile
Hi All,
We  have Using CCM 4.0 .All the Call from out side will Come to the  Reception IP Phone (Model 7940). From there We are unable to forward the  call to my mobile. From Extenson we are able to forward the Call to  mobile
Roopesh
2 ACCEPTED SOLUTIONS
Green
Re: Unable to forward the Calls from IP Phone to Mobile
Hi Roopesh,
From your config the components for ISDN/PRI 2/1:15
controller E1 2/1
framing NO-CRC4
clock source internal
pri-group timeslots 1-31
description for Income
interface Serial2/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
voice-port 2/1:15
connection plar 500
dial-peer voice 106 voip
destination-pattern 5..
session target ipv4:10.10.14.11
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
I would change/add a couple items
controller E1 2/1
framing NO-CRC4
no clock source internal
The ISDN/PRI should be taking it clock from line not internally
I would also add a dial peer to match incoming calls from this PRI
dial-peer voice 2 pots
description *** FOR INCOMING DIAL PEER MATCHING ***
incoming called-number .
direct-inward-dial
port 2/1:15
Please nort that this line
(incoming called-number .)
Needs to include the "space" and the fullstop "."
Can you also confirm that the ISDN is in service and Up
show isdn status
Alex
Regards, Alex. Please rate useful posts.
Green
Roopesh,
Glad to be of assistance.
Good to hear of success
Green
Depending on you SP this may be that the forwarded call is being sent to the mobile with a "Calling Number" that is not supported by you SP.
Can you share any traces/debugs
on the gateway --- debug isdn q931
Or at least more info re your network connectivity ISDN/FXO SIP trunk etc.
etc.
Alex
Hi  Alex,
Thanks for the Replay
Please find the Result of Debug
oh-rt2#debug isdn q931
debug isdn q931 isON.
*Mar  7 22:04:13: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  7 22:04:17: ISDN Se4/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0728
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '125'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '8970325670'
Plan:Unknown, Type:Unknown
*Mar  7 22:04:17: ISDN Se4/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8728
*Mar  7 22:04:18: ISDN Se4/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8728
*Mar  7 22:04:24: ISDN Se4/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8728
Progress Ind i = 0x8488 - In-band info or appropriate now available
*Mar  7 22:04:35: ISDN Se4/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8728
Date/Time i = 0x0B0A0C1419
*Mar  7 22:04:35: %ISDN-6-CONNECT: Interface Serial4/0:30 is now connected to 8970325670 N/A
*Mar  7 22:04:35: ISDN Se4/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0728
*Mar  7 22:04:43: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  7 22:05:13: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  7 22:05:33: %ISDN-6-DISCONNECT: Interface Serial4/0:30  disconnected from 8970325670 , call lasted 57 seconds
*Mar  7 22:05:33: ISDN Se4/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0728
Cause i = 0x8090 - Normal call clearing
*Mar  7 22:05:33: ISDN Se4/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8728
*Mar  7 22:05:33: ISDN Se4/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0728
*Mar  7 22:05:43: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
% Type "show ?" for a list of subcommands
oh-rt2#sh debug isdn q931
*Mar  7 22:06:13: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediatelyterm mon       en
oh-rt2#ensh debug isdn q931term mon       en      term mondebug isdn q931sh             en   ensh debugging
The following ISDN debugs are enabled on all DSLs:
debug isdn error isON.
Roopesh
Green
This call looked like a good call taht was set up outbound and cleared by the gateway
and lasted 1 minute 16 secs
Alex
HI
Green
As you can not supply a trace at this time there are a couple of things you can
check.
1) CUCM Admin
Service ---> Service Parameters
PUB ADDRESS Service Call Manager
Advanced
Then look for the parameter
Block Offnet to Offnet --- Set to FALSE
Then Update
This allows external calls to be transferred both internally & externaly
2) Look at the Call Forwarding CSS on the line you are calling
Does this CSS have the Partitions which allow MOBILE calls
Alex
Hi Alex,
Under
Service ---> Service Parameters i was not able to see the option
PUB ADDRESS Service Call Manager. We are using CCm 4.0.
Roopesh
Green
I just mean select the PUBLISHER server (You may have more than 1 server in the drop down depending on the build of your cluster), then the CALL MANAGER service
Alex
Hi ,Now we are able to Forward the Call to mobile.But We gets onle One ring in mobile and Call is Disconnecting Automatically.
Roopesh
Green
Hi Roopesh
At least we are moving on a bit.
Can we see the debug isdn q931 of a forwarded call.
Alex
Hi Alex,
Do i need to do Normal debug Coomand
debug isdn q931 or any thing else
Roopesh
Green
Roopesh
We want to see the forwarded call to try to work out why it is being cleared
router#
term mon
debug isdn q931
Make forwarded call
When you finish taking the trace
router#
un all
term no mon
Please include a few words of what numbers were called and what the destination of the forwarding should be.
Alex
Hi Alex,
Here it is
oh-rt2#term mon
oh-rt2#debug isdn
*Mar  1 20:48:51: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediatelyq931
oh-rt2#
*Mar  1 20:49:10: ISDN Se4/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x822F
*Mar  1 20:49:16: ISDN Se4/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x822F
Date/Time i = 0x0C01181202
*Mar  1 20:49:16: %ISDN-6-CONNECT: Interface Serial4/0:30 is now connected to 64568381 N/A
*Mar  1 20:49:16: ISDN Se4/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x022F
*Mar  1 20:49:21: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  1 20:49:51: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  1 20:50:15: ISDN Se4/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x822F
Cause i = 0x8290 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Mar  1 20:50:15: %ISDN-6-DISCONNECT: Interface Serial4/0:30  disconnected from 64568381 , call lasted 59 seconds
*Mar  1 20:50:15: ISDN Se4/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x80FF
*Mar  1 20:50:15: ISDN Se4/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x022F
*Mar  1 20:50:15: ISDN Se4/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x822F
*Mar  1 20:50:21: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  1 20:50:51: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  1 20:51:21: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  1 20:51:40: ISDN Se4/0:15 Q931: RX <- SETUP pd = 8  callref = 0x68E2
Sending Complete
Standard = CCITT
Calling Party Number i = 0x2181, '9886770029'
Plan:ISDN, Type:National
Called Party Number i = 0x81, '6300'
High Layer Compat i = 0x9181
*Mar  1 20:51:40: ISDN Se4/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xE8E2
*Mar  1 20:51:40: ISDN Se4/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0230
Standard = CCITT
Channel ID i = 0xA9839E
Exclusive, Channel 30
Called Party Number i = 0x80, '9902025093'
*Mar  1 20:51:40: ISDN Se4/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8230
*Mar  1 20:51:40: ISDN Se4/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8230
*Mar  1 20:51:43: ISDN Se4/0:15 Q931: TX -> PROGRESS pd = 8  callref = 0xE8E2
Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
*Mar  1 20:51:43: ISDN Se4/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8230
*Mar  1 20:51:43: ISDN Se4/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xE8E2
Progress Ind i = 0x8188 - In-band info or appropriate now available
*Mar  1 20:51:43: ISDN Se4/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0xE8E2
Cause i = 0x80AF - Resource unavailable, unspecified
*Mar  1 20:51:43: ISDN Se4/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0230
*Mar  1 20:51:43: ISDN Se4/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x68E2
*Mar  1 20:51:43: ISDN Se4/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xE8E2
*Mar  1 20:51:43: ISDN Se4/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8230
*Mar  1 20:51:43: ISDN Se4/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0230
*Mar  1 20:51:51: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  1 20:52:21: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
oh-rt2#un all
All possible debugging has been turned off
oh-rt2#ter
*Mar  1 20:52:51: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediatelym       term no mon
oh-rt2#exit
Roopesh
Green
We see the 2 calls being set up
Call Refs  incoming 68E2 & outgoing 0230
The router is clearing both of these calls with a cause code
This usually infers that there is a codec issue
Can you post the show runn from the gateway
Alex
Hi Alex,
Please find the result for sh run
oh-rt2#sh run
Building configuration...
Current configuration : 6276 bytes
version 12.3
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname oh-rt2
boot-start-marker
boot system flash c3745-advipservicesk9-mz.123-26.bin
boot-end-marker
logging buffered 4096 notifications
enable secret 5 $1$AgBh$dCd1NSglSXBbZXmjcdO/I.
clock timezone IST 5 30
no network-clock-participate slot 2
no network-clock-participate slot 4
voice-card 2
dspfarm
--More--         voice-card 4
dspfarm
dsp services dspfarm
no aaa new-model
ip subnet-zero
ip cef
ip domain name A.com
ip audit po max-events 100
voice hunt user-busy
voice rtp send-recv
voice class codec 1
--More--         !
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.10.14.11
ccm-manager config
fax interface-type fax-mail
controller E1 2/0
controller E1 2/1
framing NO-CRC4
controller E1 4/0
framing NO-CRC4
--More--          pri-group timeslots 1-31
description For Outgoing
ip tcp synwait-time 13
interface Multilink1
bandwidth 256
ip address 172.16.16.45 255.255.255.252
ip tcp header-compression iphc-format
ppp multilink
ppp multilink group 1
ip rtp header-compression iphc-format
interface FastEthernet0/0
ip address 10.10.14.5 255.255.255.0
ip broadcast-address 10.10.14.255
ip accounting output-packets
ip nbar protocol-discovery
ip route-cache flow
--More--          no ip mroute-cache
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.10.14.5
interface Serial0/0
description Circuit #1 initiating in India via Bharti
bandwidth 128
no ip address
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
clock rate 2000000
ppp multilink
interface FastEthernet0/1
ip address 10.10.3.8 255.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial0/1
--More--          description Circuit #2 initiating in India via BSNL
bandwidth 128
no ip address
no ip route-cache
no ip mroute-cache
clock rate 2000000
interface Serial0/2
description initiating in India via TATA
bandwidth 128
no ip address
encapsulation ppp
clock rate 2000000
ppp multilink
interface Serial0/3
no ip address
shutdown
clock rate 2000000
no cdp enable
--More--         interface Serial2/1:15
no ip address
encapsulation hdlc
no cdp enable
interface Serial4/0:15
no ip address
encapsulation hdlc
no cdp enable
ip classless
ip route 10.10.0.0 255.255.0.0 10.10.14.1
ip route 172.18.252.0 255.255.255.192 10.10.14.1
ip http server
no ip http secure-server
logging trap errors
access-list 1 permit 10.10.3.18 log
--More--         access-list 1 deny   any
access-list 2 permit 10.10.3.18 log
access-list 2 deny   any
dialer-list 1 protocol ip permit
snmp-server community public RO 1
snmp-server community private RW 2
snmp-server location OH/BLR/IN/
snmp-server contact
snmp-server enable traps tty
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
cptone IN
timeouts interdigit 3
connection plar 100
voice-port 1/1/1
--More--          cptone IN
connection plar 100
voice-port 2/1:15
connection plar 500
voice-port 4/0:15
connection plar 500
mgcp
mgcp call-agent 10.10.14.11 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
--More--         !
sccp local FastEthernet0/0
sccp
sccp ccm 10.10.14.11 priority 1
dspfarm rtp timeout 60
dial-peer cor custom
dial-peer voice 3 pots
application mgcpapp
incoming called-number 8025053.T
direct-inward-dial
dial-peer voice 4 pots
application mgcpapp
dial-peer voice 5 pots
application mgcpapp
dial-peer voice 3000 voip
--More--          destination-pattern 3...
session target ipv4:160.100.160.151
dial-peer voice 9999 voip
destination-pattern 9T
dial-peer voice 6 pots
application mgcpapp
dial-peer voice 2 voip
destination-pattern ...
codec g711ulaw
no vad
dial-peer voice 14 pots
destination-pattern 0T
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
--More--          direct-inward-dial
port 4/0:15
dial-peer voice 101 voip
destination-pattern 7..
codec g711ulaw
no vad
dial-peer voice 102 voip
destination-pattern 8..
codec g711ulaw
no vad
dial-peer voice 103 voip
destination-pattern 9..
--More--          codec g711ulaw
no vad
dial-peer voice 104 voip
codec g711ulaw
no vad
dial-peer voice 105 voip
destination-pattern 6..
codec g711ulaw
no vad
no vad
dial-peer voice 30 pots
preference 2
destination-pattern *5T
dial-peer voice 77 pots
preference 2
destination-pattern *7T
dial-peer voice 29 pots
preference 1
port 1/1/0
dial-peer voice 78 pots
preference 1
port 1/1/1
num-exp 8025053... ...
--More--         gateway
banner motd ^C
!!!AUTHORIZED ACCESS ONLY !!!
Hostname : OH-RTR2.
Contact  :IS Helpdesk
!!! AUTHORIZED ACCESS ONLY !!!
^C
line con 0
transport output all
line aux 0
transport preferred none
transport output none
line vty 0 5
password 7 1511021F0725
login
transport input all
ntp clock-period 17180604
--More--         ntp server 10.10.8.1
Thnks
Roopesh
Green
Hi Roopesh,
From what I can see the call come from the PSTN to you and uses PLAR to dial 500
500 matches dial peeer 106 and sent to CUCM on IP address 10.10.14.11
The forwarded call comes to the router as 0.9902025093
This matches dial peer 14 and sent out on the ISDN 4/0:15
To ensure correct codecs can you try pasting the following lines into
the config
conf t
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
dial-peer voice 1 pots
direct-inward-dial
port 4/0:15
no codec g711ulaw
voice-class codec 1
voice-class h323 1
no vad
end
Then retry the test call
Alex
Thank you Very Much Alex,
I will make the Change and i Will update the same to you.
I have one more problem .
I was not able to Dial the Pri Line NO 25053500. Can you Find the above configuration and sugggest any thing wrong with this.
Roopesh
Green
Roopesh
If 25053500 is an outbound call it needs to have a leading "0" -- IE 0.25053500 to match
dial peeer 14 and the ISDN/PRI
direct-inward-dial
port 4/0:15
Alex
Hi Alex,
The thing Is We have Two line One is For incomming and one is for Out going
25053500 is for only incomming And now it is connected to Controller E1 like
controller E1 2/1
framing NO-CRC4
Once i Dialed this no It used lonch on Reception .
Now it is not hapening.
Alex.
Green
Hi Roopesh,
controller E1 2/1
framing NO-CRC4
no ip address
encapsulation hdlc
no cdp enable
voice-port 2/1:15
connection plar 500
codec g711ulaw
no vad
controller E1 2/1
framing NO-CRC4
direct-inward-dial
port 2/1:15
show isdn status
Alex
Thanks For the replay Alex,
I will make the Changes in Gateway And i will come back to you.
Roopesh
Hi Alex,
Thank you very much .We Completed our first task successes fully .Now we are able to forward the Call to Mobiles. Thank you for your extended support.
Roopesh
Green
Roopesh,
Hi Alex ,
Our Second issue PRI line Dosent seems working after making the requsted change . But One improvment is there it is now the call is conecting but unable to here the sound from both side.
Roopesh
Green
Roopesh,
To refresh us as what is happening
You receive a call on the ISDN/PRI 2/1:15
This should call your reception desk.
On the voice port for 2/1:15 you are using PLAR
voice-port 2/1:15
connection plar 500
So this meens all calls coming in on this PRI will route to Number 500
So there is a matching dial peer "106"
What is number 500 in the CUCM ?
Alex
Hi Alex,
If I Dailed 500 it will reach Reception(100).Now If dailed 025053500 it is connecting to reception but not able to hear.
Roopesh
Green
Roopesh,
Can you post the latest config
Show runn
Alex
Hi Alex,
Here is the Running Configuration and ISDN Status.
Current configuration : 6792 bytes
version 12.3
hostname oh-rt2
boot-start-marker
boot-end-marker
voice-card 2
dspfarm
     voice-card 4
dspfarm
no aaa new-model
ip subnet-zero
ip cef
ip domain name
voice rtp send-recv
voice class codec 1
--More--         !
voice class h323 1
ccm-manager mgcp
ccm-manager config
controller E1 2/0
framing NO-CRC4
pri-group timeslots 1-24
--More--          description for BSnl
controller E1 2/1
framing NO-CRC4
controller E1 4/0
framing NO-CRC4
bandwidth 256
--More--          ppp multilink
ip route-cache flow
no ip mroute-cache
duplex auto
speed auto
interface Serial0/0
bandwidth 128
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
--More--          clock rate 2000000
ppp multilink
duplex auto
speed auto
no cdp enable
interface Serial0/1
bandwidth 128
no ip address
no ip route-cache
no ip mroute-cache
clock rate 2000000
interface Serial0/2
bandwidth 128
no ip address
encapsulation ppp
       clock rate 2000000
ppp multilink
interface Serial0/3
no ip address
shutdown
clock rate 2000000
no cdp enable
interface Serial2/0:15
no ip address
encapsulation hdlc
no cdp enable
no ip address
encapsulation hdlc
no cdp enable
--More--         !
no ip address
encapsulation hdlc
no cdp enable
ip classless
ip http server
logging trap errors
snmp-server contact
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
cptone IN
connection plar 100
voice-port 1/1/1
cptone IN
connection plar 100
voice-port 2/0:15
connection plar 100
--More--         !
voice-port 2/1:15
connection plar 500
voice-port 4/0:15
connection plar 500
mgcp
mgcp sdp simple
sccp
application mgcpapp
direct-inward-dial
application mgcpapp
application mgcpapp
application mgcpapp
direct-inward-dial
port 4/0:15
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
voice-class codec 1
voice-class h323 1
no vad
preference 2
    preference 2
preference 1
port 1/1/0
preference 1
port 1/1/1
application mgcpapp
direct-inward-dial
description **** For Income Dial Peer***
direct-inward-dial
port 4/0:15
--More--         !
gateway
oh-rt2#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial2/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
DEACTIVATED
    Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 0
--More--         ISDN Serial2/1:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
ACTIVE
    Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
    Active dsl 1 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
--More--         ISDN Serial4/0:15 interface
dsl 2, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
ACTIVE
    Layer 2 Status:
    Layer 3 Status:
1 Active Layer 3 Call(s)
CCB:callid=81EB, sapi=0, ces=0, B-chan=31, calltype=VOICE
    Active dsl 2 CCBs = 1
    The Free Channel Mask:  0xBFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 1
--More--             Total Allocated ISDN CCBs = 1
oh-rt2#exit
Roopesh
Green
Roopesh,
Can you change the clocking for PRI 2/1:15
controller E1 2/1
clock source line
Also if the call is setting Ok like
ringing then answering but no speach and the call stays up.
Usually this is an IP routing/connectivity issue between the RTP
endpoints.
Can you get the IP address of the Called phone.
Can you ping (extended) this from the gateway using a source Ip address
10.10.14.5 (Your H323 binding address)
Alex
Hi Alex,
I will update you on monday.
Happy Weak end.
Roopesh
1821
