Unable to insert Users with PIN/Password less than 5 characters with BAT
On a CUCM 6.1(1) system we have set an Credential Policy with a "Minimum Credential Length" of 4.
Creating users manually, this minimum works fine.
When importing users with BAT we are unable to insert PIN and Password besides 5-127 characters.
Does someone know if this range could be changed and/or to force to use the proper policy (or is it just "hardcoded" internally in BAT)?
Thanks!
Eric
1 REPLY
Re: Unable to insert Users with PIN/Password less than 5 charact
you could add it in with some pin it wants, then do a bulk edit through the gui to change it something else. I think though, when you import new users, you have to use a User Profile that has a PIN set. So it leave it blank, it will import the users, and use the template to fill in the default pin/password
114
