Unable to join Meet me conference from outside (DID) number
Would anyone help to fix below!
What I'm trying to do?
- I'm working on meet me. Meet me pattern is 2222 and is obsolutly working fine internally. I used 2222 (DID) number so anyone can join conference from outside by dialing DID number 2222.
Issue.
- When i try to join Meet me conference by dialing DID it gives busy tone. Unable to join.
Is there something to do with transcode??
- I have already a transcode in CUCM and registered with Gateway
BR
Sam
Everyone's tags (1)
Hi Sam,Which gateway are you
Hi Sam,
Which gateway are you using?
Can you please share your call flow i.e from where the call is coming and who is dialling?
Nishant Savalia
Regards, Nishant Savalia
 Hello Nishant,I'm using H
Hello Nishant,
I'm using H.323.
Call flow from outside : Meet me conference is on and I'm using my mobile to call 01-3-42222 . Where as 2222 is meet me pattern.
Call flow Internally : Meet me conference is on and I'm calling 2222 (Meet me) successfully joined.
Let me know if any more info required.
Thank You
BR
Sam
To rule out transcoder issue
To rule out transcoder issue you can specify g711 codec at the dial peer level. If the issue persists you should collect the output of 'debug voice ccapi inout' for the failed call.
Manish
Hi Manish,Below debug details
Hi Manish,
Below debug details:
Calling number : 583125185 my Mobile
Called Number : 2287797 ( Meet me Pattern )
*Mar 26 08:46:08.176: //-1/E89798C3B280/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=583125185
   ----- ccCallInfo IE subfields -----
   cisco-ani=583125185
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=2287797
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Mar 26 08:46:08.176: //-1/E89798C3B280/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3C90FA24, Call Info(
   Calling Number=583125185,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=2287797(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=5001, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=27631
*Mar 26 08:46:08.176: //-1/E89798C3B280/CCAPI/ccCheckClipClir:
   In: Calling Number=583125185(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=583125185(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Mar 26 08:46:08.176: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 26 08:46:08.176: :cc_get_feature_vsa malloc success
*Mar 26 08:46:08.176:  cc_get_feature_vsa count is 3
*Mar 26 08:46:08.176: :FEATURE_VSA attributes are: feature_name:0,feature_time:1101743440,feature_id:1929
*Mar 26 08:46:08.176: //27631/E89798C3B280/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=583125185(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=2287797(TON=Unknown, NPI=Unknown))
*Mar 26 08:46:08.176: //27631/E89798C3B280/CCAPI/cc_process_call_setup_ind:
   Event=0x3CB041D0
*Mar 26 08:46:08.176: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 2287797
*Mar 26 08:46:08.180: //27631/E89798C3B280/CCAPI/ccCallSetContext:
   Context=0x22CD2400
*Mar 26 08:46:08.180: //27631/E89798C3B280/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 27631 with tag 5001 to app "_ManagedAppProcess_Default"
*Mar 26 08:46:08.180: //27631/E89798C3B280/CCAPI/ccCallProceeding:
*Mar 26 08:46:08.180: //27631/E89798C3B280/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=100, Params=0x22CDF0B0, Progress Indication=NULL(0)
*Mar 26 08:46:08.180: //27631/E89798C3B280/CCAPI/ccCheckClipClir:
   Destination Pattern=22877.., Called Number=2287797, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=583125185, Final Destination Flag=TRUE,
   Guid=E89798C3-B3F9-11E3-B280-F273590C9FA3, Outgoing Dial-peer=100
*Mar 26 08:46:08.180: //27631/E89798C3B280/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=583125185
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=2287797
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 26 08:46:08.180: //27631/E89798C3B280/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3C90FA24, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=583125185,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=2287797(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=100, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Mar 26 08:46:08.180: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 26 08:46:08.180: :cc_get_feature_vsa malloc success
*Mar 26 08:46:08.180:  cc_get_feature_vsa count is 4
*Mar 26 08:46:08.180: :FEATURE_VSA attributes are: feature_name:0,feature_time:1101742096,feature_id:1930
*Mar 26 08:46:08.180: //27632/E89798C3B280/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Mar 26 08:46:08.180: //27632/E89798C3B280/CCAPI/ccCallSetContext:
   Context=0x22CDF060
*Mar 26 08:46:08.180: //27631/E89798C3B280/CCAPI/ccSaveDialpeerTag:
*Mar 26 08:46:08.180: //27632/E89798C3B280/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Mar 26 08:46:08.180: //27632/E89798C3B280/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
*Mar 26 08:46:08.180: //27631/E89798C3B280/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Mar 26 08:46:08.180: //27631/E89798C3B280/CCAPI/ccSetMediaclassIp2ipTags:
*Mar 26 08:46:08.180: //27632/E89798C3B280/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
*Mar 26 08:46:08.180: //27631/E89798C3B280/CCAPI/ccGet_xc_nr_asp_info:
*Mar 26 08:46:08.180: //27632/E89798C3B280/CCAPI/cc_api_event_indication:
   Event=188, Call Id=27632
   Event Is Sent To Conferenced SPI(s) Directly
*Mar 26 08:46:08.180: //27631/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar 26 08:46:08.180: cc_api_get_xcode_stream : 4819
*Mar 26 08:46:08.180: //27632/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar 26 08:46:08.184: //27631/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar 26 08:46:08.184: cc_api_get_xcode_stream : 4819
*Mar 26 08:46:08.184: //27632/E89798C3B280/CCAPI/cc_api_call_proceeding:
   Interface=0x3C90FA24, Progress Indication=NULL(0)
*Mar 26 08:46:08.184: //27632/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar 26 08:46:08.200: //27632/E89798C3B280/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0x3C90FA24, Call Id=27632
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
*Mar 26 08:46:08.200: //27631/E89798C3B280/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Mar 26 08:46:08.200: //27632/E89798C3B280/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=27632
*Mar 26 08:46:08.200: //27632/E89798C3B280/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
*Mar 26 08:46:08.200: //27632/E89798C3B280/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3C90FA24, Tag=0x0, Call Id=27632,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Mar 26 08:46:08.200: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar 26 08:46:08.200: :cc_free_feature_vsa freeing 41AB4008
*Mar 26 08:46:08.200:  vsacount in free is 3
*Mar 26 08:46:08.200: //27631/E89798C3B280/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=5000, Params=0x22CCBE20, Progress Indication=NULL(0)
*Mar 26 08:46:08.200: //27631/E89798C3B280/CCAPI/ccCheckClipClir:
*Mar 26 08:46:08.204: //27631/E89798C3B280/CCAPI/ccCheckClipClir:
*Mar 26 08:46:08.204: //27631/E89798C3B280/CCAPI/ccCallSetupRequest:
   Destination Pattern=.T, Called Number=2287797, Digit Strip=FALSE
   Guid=E89798C3-B3F9-11E3-B280-F273590C9FA3, Outgoing Dial-peer=5000
*Mar 26 08:46:08.204: //27631/E89798C3B280/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=583125185
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=2287797
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Mar 26 08:46:08.204: //27631/E89798C3B280/CCAPI/ccIFCallSetupRequestPrivate:
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=5000, Call Count On=FALSE,
*Mar 26 08:46:08.204: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Mar 26 08:46:08.204: :cc_get_feature_vsa malloc success
*Mar 26 08:46:08.204:  cc_get_feature_vsa count is 4
*Mar 26 08:46:08.204: :FEATURE_VSA attributes are: feature_name:0,feature_time:1101742096,feature_id:1931
*Mar 26 08:46:08.204: //27633/E89798C3B280/CCAPI/ccIFCallSetupRequestPrivate:
*Mar 26 08:46:08.204: //27633/E89798C3B280/CCAPI/ccCallSetContext:
   Context=0x22CCBDD0
*Mar 26 08:46:08.204: //27631/E89798C3B280/CCAPI/ccSaveDialpeerTag:
*Mar 26 08:46:08.204: //27633/E89798C3B280/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Mar 26 08:46:08.204: //27633/E89798C3B280/CCAPI/ccSetMediaclassIp2ipTags:
*Mar 26 08:46:08.204: //27631/E89798C3B280/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Mar 26 08:46:08.204: //27631/E89798C3B280/CCAPI/ccSetMediaclassIp2ipTags:
*Mar 26 08:46:08.204: //27633/E89798C3B280/CCAPI/ccGet_xc_nr_asp_info:
*Mar 26 08:46:08.204: //27631/E89798C3B280/CCAPI/ccGet_xc_nr_asp_info:
*Mar 26 08:46:08.204: //27633/E89798C3B280/CCAPI/cc_api_event_indication:
   Event=188, Call Id=27633
*Mar 26 08:46:08.204: //27631/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar 26 08:46:08.204: cc_api_get_xcode_stream : 4819
*Mar 26 08:46:08.204: //27633/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar 26 08:46:08.204: //27633/E89798C3B280/CCAPI/cc_api_call_proceeding:
*Mar 26 08:46:08.208: //27633/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar 26 08:46:08.208: cc_api_get_xcode_stream : 4819
*Mar 26 08:46:08.208: //27631/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Mar 26 08:46:08.280: //27633/E89798C3B280/CCAPI/cc_api_call_disconnected:
   Cause Value=28, Interface=0x3C90FA24, Call Id=27633
   Call Entry(Responsed=TRUE, Cause Value=28, Retry Count=0)
*Mar 26 08:46:08.280: //27631/E89798C3B280/CCAPI/ccCallReleaseResources:
*Mar 26 08:46:08.280: //27633/E89798C3B280/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=27633
*Mar 26 08:46:08.280: //27633/E89798C3B280/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=28)
   Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
*Mar 26 08:46:08.284: //27633/E89798C3B280/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3C90FA24, Tag=0x0, Call Id=27633,
   Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
*Mar 26 08:46:08.284: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar 26 08:46:08.284: :cc_free_feature_vsa freeing 41AB4008
*Mar 26 08:46:08.284:  vsacount in free is 3
*Mar 26 08:46:08.284: //27631/E89798C3B280/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Mar 26 08:46:08.300: //27631/E89798C3B280/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3C90FA24, Tag=0x0, Call Id=27631,
*Mar 26 08:46:08.300: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Mar 26 08:46:08.300: :cc_free_feature_vsa freeing 41AB4548
BR
Sami
VIP Super Bronze
Sami,It looks like your
Sami,
It looks like your translation is not working as it should..The first dial-peer that was matched was 100 and that comes back saying that the number dialled doesnt exist, then dial-peer 5000 was tried and that destination also rejected the call. How are you translating 2287797 to 2222?
Can you send us your sh run
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi,Plz check attached show
Plz check attached show run.
Let me know if i am missing any parameters.
Thank You
BR
Sam
VIP Super Bronze
Sam,How are you tranlsating
Sam,
How are you tranlsating the dialled number to 2287797 to 2222 in cucm? Do you have a xlation pattern configured? I dont see any tranlsation rules in the gateway doing this
Hi Ayodeji,Plz find in
Hi Ayodeji,
Plz find in attached the screen shot of translation pattern created. Do let me know if any settings are missing.
Thank You
BR
Sam
Hi Sam,It seems that you are
Hi Sam,
It seems that you are translating the called number incorrectly.
As per your translation pattern, you are converting 2287797  to 77XX while your meet me number is 2222.
Modify your required meet-me number and check again.
Also do check that proper CSS is applied to gateway so that it can access meet-me number.
Nishant Savalia
 Hello Nishant, Tried the
Hello Nishant,
Tried the same, but no luck.
Is there any other way to forward call comming to 2287797 (DID) should get forwarded to 2222 (Meet me).
BR
Sam
VIP Super Bronze
There is no CSS applied to
There is no CSS applied to the xlation pattern. Assign a CSS that has the partition of the DN 2222 in it..
HI,Did assigned the CSS.
HI,
Did assigned the CSS. still no luck. Internally working fine but when trying to call from outside no answer. The call gets dropped.
What i tried is.
- Configured DID number 22287797 as an Meet me pattern. Instead configuring (2222) and translating. Still the same.
Did anyone faced this issue, and found solution.
Comments are highly appreciated.
Thank You
Sam
326
