Community Member
Unable to launch service engine on UC560
Having UC560, I cannot open session to service engine to perform factory reset. Here is what I've tried to do.
1. Copy factory config UC560-T1E1-K9-factory-8.6.0.cfg to startup-config and power-down/power-up UC560.
2. Then try to enter service engine with the following command:
service-module integrated-Service-Engine 0/0 se
But it stuck on the following message:
Trying 10.1.10.2, 2002 ...
Connection timed out; remote host not responding
3. OK, here is my show ip interface brief:
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         192.168.1.210   YES DHCP   up                    up
In0/0                      10.1.10.2       YES TFTP   up                    up
GigabitEthernet0/1/0       unassigned      YES unset  up                    down
GigabitEthernet0/1/1       unassigned      YES unset  up                    down
GigabitEthernet0/1/2       unassigned      YES unset  up                    up
GigabitEthernet0/1/3       unassigned      YES unset  up                    up
Vlan1                      192.168.10.1    YES NVRAM  up                    up
Vlan90                     10.1.10.2       YES NVRAM  up                    down
Vlan100                    10.1.1.1        YES NVRAM  up                    down
NVI0                       unassigned      YES unset  administratively down down
I see that Vlan90 and In0/0 have got the same IP. Here is my show ip route:
S*    0.0.0.0/0 [254/0] via 192.168.1.130
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, GigabitEthernet0/0
L        192.168.1.210/32 is directly connected, GigabitEthernet0/0
      192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.10.0/24 is directly connected, Vlan1
L        192.168.10.1/32 is directly connected, Vlan1
So I see no rutes for 10.1.10.0 subnet.
4. OK, here is Integrated-Service-Engine0/0 interface:
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application module
ip unnumbered Vlan90
ip nat inside
ip virtual-reassembly in
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
And here is Vlan90 interface:
interface Vlan90
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
5. Next, here is route to 10.1.10.1:
ip route 10.1.10.1 255.255.255.255 Vlan90
As I see, the /32 mask is insane, so I change it to /24:
ip route 10.1.10.0 255.255.255.0 Vlan90
6. Next, I try to enter service engine again but still no luck with the same error.
What's wrong with the configuration?
Everyone's tags (1)
I have an ISM but it is a similar configuration for service engine. I believe you should remove the NAT. Try your config like this:
interface ISM0/0
ip unnumbered GigabitEthernet0/1
service-module ip address 172.28.85.2 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 172.28.85.1
interface GigabitEthernet0/1
ip address 172.28.85.1 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.28.85.1
ip route 172.28.85.2 255.255.255.255 ISM0/0
Community Member
Re: Unable to launch service engine on UC560
Unfortunately, that didn't help, but the following configuration did the trick:
UC560#show run interface loopback 0
Building configuration...
Current configuration : 63 bytes
interface Loopback0
ip address 10.1.20.2 255.255.255.0
end
UC560#show run interface integrated-Service-Engine 0/0
Current configuration : 276 bytes
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.20.1 255.255.255.0
service-module ip default-gateway 10.1.20.2
end
UC560#show run interface gigabitEthernet 0/1/3
Current configuration : 223 bytes
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
no ip address
end
UC560#show ip route
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C        10.1.20.0/24 is directly connected, Loopback0
S        10.1.20.1/32 is directly connected, Loopback0
L        10.1.20.2/32 is directly connected, Loopback0
269
