Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Unable to log to Cisco 2811
Hi, i recently joined a company as IT engineer, unfortunately i dont have that much information about Cisco IP telephoney and call manager... i went through the quick start guide that came with cisco2811 but was not able to log into the router..not through SDM nor IOS startup, although i followed in details what was mentioned in that guide..can anyone guide me how to login to the router and edit information related to the ip phones (the router has call manager express)
thanks!
Re: Unable to log to Cisco 2811
You can login via web with url
http://ipaddress/ccme.html
Username abd password are configured under Telephony-Service e.g.:
telephony-service
load 7910 P00403020214
load 7960-7940 P00305000301
load 7914 S00103020002
load ATA ATA030100SCCP040211A
load 7905 CP79050101SCCP030530B31.zup
load 7912 CP7912040000SCCP040701A.sbin
max-ephones 52
max-dn 208
ip source-address 192.168.1.1 port 2000
time-format 24
date-format dd-mm-yy
max-redirect 20
timeouts interdigit 4
system message xxxxx
user-locale IT
network-locale IT
create cnf-files version-stamp 7960 Dec 16 2005 15:40:23
max-conferences 8
moh music-on-hold.au
web admin system name admin password admin
web admin customer name customer password admin
well giordano_p thanks for your reply, but i guess that the problem is knowing the ip address in the first place! i joined recently to the company and i found myself near this router with no access or what is the ip configured, setup is already there and phone system is running perfectly. i just need to add new users and to edit current user names...i tried the default ip which was mentioned in quick guide (10.10.10.1) i also used the server ip (callmanager and TFTP) mentioned under the network settings on the cisco ip phone but non was connecting... my question is that how can i know the router IP address?
thanks again
The address find in network setting on cisco ip phone is correct but it is the address configured under telephony-service. This address is probably one of the many ip configured on your router.
This is my configuration:
interface FastEthernet0/0
no ip address
interface FastEthernet0/0.50
description VOICE_INTERFACE
encapsulation dot1Q 50
ip address 10.25.100.31 255.255.255.0
h323-gateway voip interface
interface FastEthernet0/0.667
description WAN_INTERFACE
encapsulation dot1Q 667
ip address 10.25.2.219 255.255.255.248
ip nat outside
interface FastEthernet0/1
no ip address
interface FastEthernet0/1.1
description LAN_x_TELEFONI
encapsulation dot1Q 2
interface FastEthernet0/1.2
description LAN_x_COMPUTER
encapsulation dot1Q 3
ip address 192.168.205.254 255.255.255.0 secondary
ip address 10.25.2.169 255.255.255.248
ip nat inside
telephony-service
In my case the telephony-service ip address is reached only from phone network.
Can you ping your address? There is a reserved VLAN for your phone? Can connect your PC in phone network? If you try this way don't connect your PC below an ip phone because ip phone use can use different VLAN on its PC port.
Can you check VLAN switch configuration?
Is CCME used to surf in Internet? Is It your default gateway?
In my configuration I've disable web access because I use only telnet. Have you try with telnet?
another idea
Router Web server can be configured to a different port. Can you check open port with a port scanner?
Have you try to access on the router via CONSOLE port?
IP phone(7912) Network Configuration:
1 DHCP Server 192.168.200.1
2 BOOTP Server NO
3 MAC Address 0019....
4 Host Name SEP0011.....
5 Domain Name (Blank)
6 IP Address 192.168.200.7
7 Subnet Mask 255.255.255.0
8 TFTP Server1 192.168.200.1
9 TFTP Server2 (Blank)
10 Default Router1 192.168.200.1
11 DNS Server1 (Blank)
12 DNS Server2 (Blank)
13 Operational VLANId 200
14 Admin. VLANId (Blank)
15 VLAN Enables YES
16 CDP Enabled YES
17 Call Manager1 192.168.200.1 Active
18 Call Manager2 (Blank)
19 Call Manager3 (Blank)
20 Call Manager4 (Blank)
21 DHCP Enabled YES
22 DHCP Address Released NO
23 Alternate TFTP NO
24 Alternate DNS NO
25 Alternate Domain NO
26 Erase Configuration NO
Yes i can connect a PC in phone network..and CCME is used to surf internet...
from ip phone configuration I suppose that your switch is configure in this way:
interface FastEthernetxxx
description IP-PHONE & PC
switchport trunk native vlan ?
switchport trunk allowed vlan 200,?
switchport mode trunk
switchport voice vlan 200
If you connect a PC directly to switch or below an ip phone, ip frames will be sent on native vlan.
Try to configure a swith port with voice vlan only:
switchport access vlan 200
switchport mode access
and connect a PC configured in DHCP to this port. If all work, you can contact CCME ip address 192.168.200.1
488
