12-13-2007 10:27 AM - edited 03-15-2019 07:46 AM
A client of ours requires access to the Callmanager Express web GUI but after entering the administrator password in the web login prompt I receive the following message:
"Cisco Unity Express has lost contact with the Host router. Enter the new CCME Web Administrator user name and password."
I have read that in this instance the CUE module should be reloaded, but after reloading I get the same. After resetting even I get the same. The only thing I haven't tried is resetting the router but I would prefer not to do this because it will cause service interruption. Can anyone help?
12-13-2007 10:56 AM
Hi Blake,
Here is some related info;
Problem: User Cannot Log In Through the Cisco Unity Express Graphical User Interface (GUI)
The Cisco Unity Express user cannot log in through the Cisco Unity Express GUI and receives the Cisco Unity Express has lost contact with the Host router. Enter the new CCME Web Administrator username and password error message.
Complete these steps in order to resolve this problem:
Check in order to see if the Cisco CallManager Express configuration misses any of the configuration commands mentioned in this document.
If the configuration is correct, the Cisco CallManager Express router might miss the default-gateway configuration. This might happen if the administrator reloads the router without saving the configuration. Check the Cisco CallManager Express configuration for IP connectivity to Cisco Cisco Unity Express.
This errror message is also seen when the administrator decides to change the Cisco CallManager Express web administrator username and password, and the new name and password is not updated in the Cisco Unity Express system. Use the procedure mentioned in Unity Express GUI Password Recovery in order to update the system with new Cisco CallManager Express username and password.
Use the service-module service-engine slot/port reload command in order to reload the Cisco Unity Express module.
Note: A reboot of the Cisco Unity Express module does not require a reboot of the router. The Cisco Unity Express module and the router can be rebooted independently of each other. However, if you reboot the router, no calls reach the module until IP connectivity is reestablished between the router and the module. Always perform a shutdown of the module before you power-cycle the router in order to avoid data loss or file corruption.
Hope this helps!
Rob
12-13-2007 11:10 AM
Rob,
Thanks very much for the quick reply!
These are actually the two documents I found and tried in order to remedy the problem. Unfortunately after following the procedures outlined in both the results didn't change and I'm still stuck. :(
I am scheduling a reset of the host router after hours tonight with the client and I will repost if this solves my issues.
