Community Member
Unable to make outbound calls using FXO on CME
I am running CME and currently have only one IP phone trying to make outbound calls using the FXO port.  After dialing from the IP phone, I receive a fast busy.  The extension of the IP phone is 1000. I will include my current CME config, can anyone help?  Thanks.
voice-port 0/1/1
supervisory disconnect dualtone pre-connect
pre-dial-delay 0
no battery-reversal
signal groundStart
no vad
timeouts call-disconnect 2
timeouts wait-release 2
timing hookflash-out 250
connection plar 1000
dial-peer voice 1003 pots
description <<Local 10 Digit Calls>>
huntstop
preference 1
destination-pattern 9T
port 0/1/1
forward-digits 10
telephony-service
max-ephones 10
max-dn 10
ip source-address * port 2000
auto assign 1 to 10
timeouts interdigit 3
timeouts ringing 360
max-conferences 8 gain -6
call-forward pattern .T
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 1000
ephone  1
no multicast-moh
mac-address 000E.833C.AFD8
keepalive 30 auxiliary 0
type 7960
button  1:1
1 REPLY
Re: Unable to make outbound calls using FXO on CME
Hi Ninja,
I think you want to remove a few command initially from the FXO port
to see if outbound call works any better. Specifically, get rid of:
pre-dial-delay 0
no battery-reversal
Also ensure that the telco or whatever is on the other side of the cable is
infact set for ground start signaling as well. If not, you should change
signal groundStart to signal loopstart. After making any changes under the
fxo port, issue shut/no shut for the change to take affect.
Capture debug voip ccapi inout | deb vpm sig along with sh voice port
and show voice call to further investigate this.
DK
446
