Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Unable to make Outbound calls
There is one major problem i am facing in CUCM 9.x.
Since yesterday night incomming and outgoing calls are working. Suddenly since morning, unable to make any ougoing call through PSTN link
But able to dial extension to extension. PSTN link is up, am able to receive incomming call from outside. There is no change in configuration also.
I have two UCS-C220m3s boxes, Configured one Pub and two Subs and all are part of one cluster. I have run debug session, not getting hi on Gasteway router, whee my PSTN links get terminatted.
Kindly help..
I have done Dialed Plan Analyser...
Please for your reference.
  Cisco Unified Communications Manager Dialed Number Analyzer
DNA Analysis Output  Save the Displayed Output
Cisco Unified Communications Manager Dialed Number Analyzer Results
Results Summary
Calling Party Information
Calling Party = 3644
Partition = CignaOffice-pt
Device CSS =
Line CSS = Cignaoffice-css
AAR Group Name =
AAR CSS =
Dialed Digits = 9987601166
Match Result = RouteThisPattern
Matched Pattern Information
Pattern = XXXXXXXXXX
Time Schedule =
Called Party Number = 9987601166
Time Zone = Etc/GMT
End Device = Cignaoffice-RL
Call Classification = OffNet
InterDigit Timeout = NO
Device Override = Disabled
Outside Dial Tone = NO
Call Flow
TranslationPattern :Pattern=
Partition =
Positional Match List = 9987601166
Calling Party Number = 3644
PreTransform Calling Party Number =
PreTransform Called Party Number =
Calling Party Transformations
External Phone Number Mask = NO
Calling Party Mask =
Prefix =
CallingLineId Presentation =
CallingName Presentation =
ConnectedParty Transformations
ConnectedLineId Presentation =
ConnectedName Presentation =
Called Party Transformations
Called Party Mask =
Discard Digits Instruction =
Prefix =
Called Number =
Route Pattern :Pattern= XXXXXXXXXX
DialPlan =
Route Filter
Filter Name =
Filter Clause =
Require Forced Authorization Code = No
Authorization Level = 0
Require Client Matter Code = No
PreTransform Calling Party Number = 3644
PreTransform Called Party Number = 9987601166
Prefix =
CallingLineId Presentation = Default
CallingName Presentation = Default
ConnectedLineId Presentation = Default
ConnectedName Presentation = Default
Called Party Mask =
Discard Digits Instruction = None
Prefix =
Called Number = 9987601166
Route List :Route List Name= Cignaoffice-RL
RouteGroup :RouteGroup Name= CignaOffice-RG
External Phone Number Mask = Default
Prefix = 6170
Calling Party Number = 61703644
Called Party Mask =
Discard Digits Instructions =
Prefix =
Device :Type= MGCPE1PRIPort
Transformed Calling Party = 3644
End Device Name = S0/SU0/DS1-0@cigna-office-gw01.asia.intl.cigna.com
PortNumber = 0
Device Status = Registered
AAR Group Name =
AAR Calling Search Space = Cignaoffice-css
AAR Prefix Digits =
Calling Party Selection =
CallingLinePresentation =
ConnectedLinePresentation =
Number Of Strip Digits =
CallerID DN =
Alternate Matches
Note: Information Not Available
VIP Purple
Hi Arindam,
Can u try generating test call from router by using the command
isdn test call interface serial 0/0/0:15 PSTNNUMBER  and check whether outgoing /call is landing or not?
serial port in command  is the E1 port on which PRI is terminated.
regds,
aman
Hi Aman,
I have tried this and this is the capture...
cigna-office-gw01#isdn test call interface serial 0/0/0:15 9833003426
cigna-office-gw01#
Aug 23 2013 13:06:31 IST: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x008B callID = 0x800C switch = primary-net5 interface = User
Aug 23 2013 13:06:31 IST: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x008B
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transfer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Called Party Number i = 0x81, '9833003426'
                Plan:ISDN, Type:Unknown
Aug 23 2013 13:06:31 IST: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x808B
Aug 23 2013 13:06:31 IST: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x008B
        Cause i = 0x80D1 - Invalid call reference value
Aug 23 2013 13:06:35 IST: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x008B
                Standard = CCITT
Aug 23 2013 13:06:35 IST: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x808B
Aug 23 2013 13:06:35 IST: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x008B
Aug 23 2013 13:06:39 IST: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x008B
        Cause i = 0x80E6 - Recovery on timer expiry
Aug 23 2013 13:06:39 IST: ISDN Se0/0/0:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK.  The SETUP failed.
VIP Purple
Hi Arvindam,
Did u check with Service Provider whether outgoing is enabled or not ?
regds,
aman
Hi Aman,
Yea. we have done that testing by removing the link from Gateway router and connect to phone and telco people able to dial outside by using same PSTN link..
I did some changes without any clue. I suspected might be some issue in CUCM, as it was working since last night but suddenly it happend. So i rebooted VM, where Sub-1 resides. and Before that chnaged the priority in UN CM Group. And all ip phones register on other subscriber in the same cluster. Post doing this change, we are able to make any outbound call as well as receive inbound calls.
But still i dont have clue, why suddenly it got stopped.
Thank you Aman, for your help and support.
Regards/Arindam
VIP Purple
Hi Arindam,
can u explain your setup in detail?
are the IP phones registered to SUB2 now and in call manager group, SUB2 is at top priority?secondly, is the gateway registered on which PRI is terminated registered to SUB2 now and outgoing is not happening now but incoming is working  ? earlier this setup was on SUB1 .please confirm.
please provide output from MGCP router?
show ccm-manager hosts and show ccm-manager
regds,
aman
VIP Purple
Hi Arindam,
if possible,please provide utils dbreplication rutime state from pub.
regds,
aman
You're sending the call as video, that's why it fails
                Standard = CCITT
Protocol on GW?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re: Unable to make Outbound calls
Jaime is right.
Please use isdn bearer capability as speech . You can configure this under the interface serial or voice port configuration.
Regards, Avinash
Arindam,
Try to collect #debug isdn q931 and share with us.
Selva
Can you check the "Reply video call as audio on gateway
VIP Purple
Hi Arindam,
Any updates, is your problem resolved?
regds,
aman
1927
