Unable to Make Outgoing Calls on Cisco IP Communicator 8.6
I have configured Cisco Unified CM rel. 7.1 and installed Cisco IP Communicator 8.6. Incoming calls work fine but I am having problems making outgoing calls. Would very much appreciate any advise. Thanks.
Mohammed Noor
1 REPLY
What do you hear on IPC?
What does the debugs on the GW say about the reason code for the disconnect?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
843
