Unable to match inbound dial-peer
I'm having a problem matching an inbound SIP dial-peer.  From the config:
dial-peer voice 2 voip
description Default inbound H323
incoming called-number .
dtmf-relay h245-signal
codec g711ulaw
no vad
dial-peer voice 3 voip
description Default inbound SIP
session protocol sipv2
session transport tcp
dtmf-relay rtp-nte
codec g711ulaw
no vad
However, when I place a call from the SIP IP PBX (not UCM), it always matches dial-peer 2:
*Jul 29 14:48:06.675: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=8800, Called Number=8800, Peer Info Type=DIALPEER_INFO_SPEECH
*Jul 29 14:48:06.679: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=8800
   Result=Success(0) after DP_MATCH_DEST
*Jul 29 14:48:06.679: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=8800, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
*Jul 29 14:48:06.679: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=8800
*Jul 29 14:48:06.679: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=9166328800, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Jul 29 14:48:06.679: //-1/21F22FC38044/DPM/dpAssociateIncomingPeerCore:
   Calling Number=9166328800, Called Number=8800, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=2
*Jul 29 14:48:06.679: //-1/21F22FC38044/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
If I shut down dial-peer 2, it will match dial-peer 3.  All calls are successful, even when dial-peer 2 is matched by the inbound SIP call.  How do I force SIP calls to match dial-peer 3 and H323 calls to match dial-peer 2 (other than using source-based Carrier-ID routing).
Thanx
Re: Unable to match inbound dial-peer
You'll need to be more specific with your incoming called-number. When the GW hunts through the dial-peers it hunts top down, and won't take into account the protocol you have specified.
One suggestion would be to prepend a 9 to all incoming SIP (or H.323) calls then use a translation rule to strip the 9.
Understood. I was just hoping for something more generic.  Very strange that it would even match a dial-peer set up for H323. It should be smarter than that.  It will successfully route the SIP-SIP call, but the call will experience some DTMF relay issues occasionally.
255
