Unable to match incoming calls to a dialpeer
I  have a Cisco 2912 (CUBE) registered to voip.ms. All  the outbound calls  work just fine. I am not able to make the incoming  calls work. When an  incoming call is places the CUBE doesn't match any  incoming dial peer  instead the outboud dial-peer is matched (please see  the debug below).  The cube is sitting behind an ASA 5510, however, the  public IP assigned  to CUBE's loopback is not being natted as it gives to  many problems  when cube traffc is natted. I have also attached a  network diagram to  this post. The following config is on the 2921  router. Also I have  pasted the dialpeer and CCSIP debugs.
SHOW RUN
Current configuration : 8069 bytes
! Last configuration change at 13:32:55 UTC Mon Dec 16 2013 by ajlal
version 15.2
service password-encryption
hostname SEC-HO-VGATEWAY01
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
logging buffered 51200 warnings
no aaa new-model
ip cef
ip domain name yrns.local
ip name-server 10.13.11.2
ip name-server 192.168.60.4
no ipv6 cef
voice-card 0
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 184.75.215.114
ip address trusted call-block cause not-in-cug
gcid
clid substitute name
address-hiding
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  session transport tcp
  e911
  transport switch udp tcp
  asserted-id ppi
  localhost dns:sec-ho-vgateway01.yrns.local
  midcall-signaling passthru
  no call service stop
voice class uri 1001 sip
host ipv4:184.75.215.114
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 ilbc
voice translation-rule 1
rule 1 /^123456\(....\)$/ /\1/
voice translation-profile INBOUND_TRANS
translate called 1
redundancy
interface Loopback0
ip address 64.187.178.132 255.255.255.224
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description TO_ASA
ip address 10.13.255.13 255.255.255.252
duplex full
speed 1000
interface GigabitEthernet0/1
description TO_LOCAL_LAN
ip address 10.13.14.1 255.255.255.0
ip helper-address 192.168.60.4
duplex full
speed 1000
router eigrp 13
network 10.10.10.10 0.0.0.0
network 10.13.10.2 0.0.0.0
network 10.13.14.0 0.0.0.255
network 10.13.255.12 0.0.0.3
network 64.187.178.132 0.0.0.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp profile default
sccp local Loopback0
sccp ccm 10.13.14.22 identifier 2 version 7.0
sccp ccm 10.13.14.21 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 4 register SECHO-G729-MTP
associate profile 3 register SECHO-G711-MTP
associate profile 2 register SECHO-HW-CFB
associate profile 1 register SECHO-HW-XCode
dspfarm profile 1 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
maximum sessions 2
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729r8
maximum sessions 2
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions software 100
dspfarm profile 4 mtp
codec g729r8
dial-peer voice 1001 voip
description SIP TRUNK TO CUCM-SUB01
preference 1
destination-pattern 5...
session protocol sipv2
session target ipv4:10.13.14.21
voice-class codec 1
dial-peer voice 1002 voip
preference 1
destination-pattern 1...$
voice-class codec 1
dial-peer voice 101 voip
preference 1
destination-pattern [2-9]..[2-9]......$
session target dns:toronto2.voip.ms
session transport udp
no voice-class sip block 180
no voice-class sip block 183
no voice-class sip block 181
voice-class sip bind control source-interface Loopback0
voice-class sip bind media source-interface Loopback0
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 103 voip
preference 1
destination-pattern 911$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 102 voip
preference 1
destination-pattern 1[2-9]..[2-9]......$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1 voip
incoming uri via 1001
dtmf-relay rtp-nte
codec transparent
no vad
dial-peer voice 501 voip
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer hunt 1
sip-ua
credentials username USERNAME password 7 PASSWORD realm toronto2.voip.ms
authentication username USERNAME password 7 PASSWORD realm toronto2.voip.ms
registrar 1 dns:toronto2.voip.ms expires 300 auth-realm toronto2.voip.ms
gatekeeper
shutdown
line con 0
exec-timeout 60 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 60 0
privilege level 15
logging synchronous
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
DEBUG VOICE DIALPEER ALL
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=2893211281, Called Number=2893211281, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2893211281
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=2893211281, Expanded String=2893211281, Calling Number=2893211281T
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=101 Is Matched
   Result=Success(0) after DP_MATCH_DEST
*Dec 16 14:44
SEC-HO-VGATEWAY01#:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=2893211281, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=101
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6473215943, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Match Rule=DP_MATCH_ANSWER; Calling Number=6473215943
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
   Dial String=, Expanded String=, Calling Number=6473215943T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6076
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=6473215943
SEC-HO-VGATEWAY01#Number=6473215943T
   Result=Success(0); Incoming Dial-peer=101 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=101
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6704
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6076
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6704
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6473215943, Called Number=2893211281, Voice-Interface=0x0,
SEC-HO-VGATEWAY01#EER_TYPE_VOICE,
   Match Rule=DP_MATCH_VIA_URI; URI=sip:184.75.215.114:5060
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchPeertype:
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchCore:
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1 Is Matched
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchPeertype:exit@6076
   Result=Success(0) after DP_MATCH_VIA_URI; Incoming Dial-peer=1
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpAssociateIncomingPeerSPI:exit@6655
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2893211281, Peer Info Type=DIALPEER_INFO_SPEECH
   dialstring=2893211281, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 16 14:44:16.173: //-1/5F20307A81F3/DPM/dpMatchPeersCore:
*Dec 16 14:44:16.173: //-1/5F20307A81F3/DPM/dpMatchCore:
*Dec 16 14:44:16.173: //-1/5F20307A81F3/DPM/MatchNextPeer:
*Dec 16 14:44:16.173: //-1/5F20307A81F3/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.173: //-1/5F20307A81F3/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2893211281, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=2893211281
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Dial String=, Expanded String=, Calling Number=2893211281T
   Result=-1
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6076
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=2893211281
   Re
SEC-HO-VGATEWAY01#sult=Success(0); Incoming Dial-peer=101 Is Matched
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6704
   Result=-1
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Dec 16 14:44:16.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Dec 16 14:44:16.437: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
*Dec 16 14:44:16.437: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Dec 16 14:44:16.437: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 16 14:44:16.437: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Dec 16 14:44:16.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Result=-1
*Dec 16 14:44:16.437: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6076
*Dec 16 14:44:16.437: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6704
   Result=-1
*Dec 16 14:44:16.437: //-1/5F49B07481FA/DPM/dpAssociateIncomingPeerCore:
*Dec 16 14:44:16.437: //-1/5F49B07481FA/DPM/dpMatchPeertype:
*Dec 16 14:44:16.437: //-1/5F49B07481FA/DPM/dpMatchCore:
*Dec 16 14:44:16.437: //-1/5F49B07481FA/DPM/MatchNextPeer:
*Dec 16 14:44:16.437: //-1/5F49B07481FA/DPM/dpMatchPeertype:exit@6076
*Dec 16 14:44:16.437: //-1/5F49B07481FA/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.437: //-1/5F49B07481FA/DPM/dpAssociateIncomingPeerSPI:exit@6655
*Dec 16 14:44:16.441: //-1/5F49B07481FA/DPM/dpMatchPeersCore:
*Dec 16 14:44:16.441: //-1/5F49B07481FA/DPM/dpMatchCore:
*Dec 16 14:44:16.441: //-1/5F49B07481FA/DPM/MatchNextPeer:
SEC-HO-VGATEWAY01# Result=Success(0); Outgoing Dial-peer=101 Is Matched
*Dec 16 14:44:16.441: //-1/5F49B07481FA/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.441: //-1/5F49B07481FA/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
*Dec 16 14:44:16.441: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Dec 16 14:44:16.441: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
*Dec 16 14:44:16.441: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Dec 16 14:44:16.441: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.441: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 16 14:44:16.441: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Dec 16 14:44:16.441: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Result=-1
*Dec 16 14:44:16.441: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6076
*Dec 16 14:44:16.441: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6704
   Result=-1
*Dec 16 14:44:16.445: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Dec 16 14:44:16.445: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
*Dec 16 14:44:16.445: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Dec 16 14:44:16.445: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.445: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 16 14:44:16.445: //-1/5F49B07481FA/DPM/dpMatchPeersCore:
*Dec 16 14:44:16.445: //-1/5F49B07481FA/DPM/dpMatchCore:
*Dec 16 14:44:16.445: //-1/5F49B07481FA/DPM/MatchNextPeer:
*Dec 16 14:44:16.445: //-1/5F49B07481FA/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.445: //-1/5F49B07481FA/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 16 14:44:16.693: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Dec 16 14:44:16.693: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
*Dec 16 14:44:16.693: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Dec 16 14:44:16.693: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.697: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 16 14:44:16.697: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Dec 16 14:44:16.697: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
*Dec 16 14:44:16.697: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
*Dec 16 14:44:16.697: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6076
*Dec 16 14:44:16.697: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Dec 16
SEC-HO-VGATEWAY01#14:44:16.697: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.697: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6704
   Result=-1
*Dec 16 14:44:16.697: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Dec   16 14:44:16.697:   //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6704 Dial   String=2893211281, Expanded String=2893211281, Calling Number=
*Dec 16 14:44:16.701: //-1/5F70C0688201/DPM/MatchNextPeer:
*Dec 16 14:44:16.701: //-1/5F70C0688201/DPM/dpMatchPeersCore:
*Dec 16 14:44:16.701: //-1/5F70C0688201/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.701: //-1/5F70C0688201/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
DEBUG CCSIP ALL
*Dec   16 06:56:19.627: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads:   Msg enqueued for SPI with IP addr: [184.75.215.114]:5060,   local_address:[64.187.178.132]
*Dec 16 06:56:19.627:   //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event:   ccsip_spi_get_msg_type returned: 2 for event 1
*Dec 16 06:56:19.627: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x408C10E8
*Dec   16 06:56:19.627:   //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg:   gConnTab=0x408C10E8, addr=184.75.215.1
SEC-HO-VGATEWAY01#14, port=5060, local_addr=64.187.178.132, connid=3, transport=UDP
*Dec 16 06:56:19.627: //-1/xxxxxxxxxxxx/SIP/Info/sipHolderGetConnInstance: Return existing connection for port 5060 connId 3
*Dec 16 06:56:19.627: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:2893211281@64.187.178.132 SIP/2.0
Via: SIP/2.0/UDP 184.75.215.114:5060;branch=z9hG4bK29e50406;rport
Max-Forwards: 70
From: "6473215943" <sip:6473215943@184.75.215.114>;tag=as0ef7e899
To: <sip:2893211281@64.187.178.132>
Contact: <sip:6473215943@184.75.215.114:5060>
Call-ID: 63e5ab0b6e4ce5d3427bfa7c10e46a49@184.75.215.114:5060
CSeq: 102 INVITE
User-Agent: voip.ms
Date: Mon, 16 Dec 2013 06:58:12 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Remote-Party-ID: "6473215943" <sip:6473215943@184.75.215.114>;party=calling;privacy=off;screen=no
Content-Type: application/sdp
Content-Length: 274
v=0
o=root 1354162751 1354162751 IN IP4 184.75.215.114
s=voip.ms
c=IN IP4 184.75.215.114
t=0 0
m=audio 13254 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
*Dec 16 06:56:19.627: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Dec 16 06:56:19.627: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x
SEC-HO-VGATEWAY01#40CA2A48) with key=[24] to table
*Dec 16 06:56:19.627: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
*Dec 16 06:56:19.627: //-1/000000000000/SIP/Info/ccsip_iwf_init:
*Dec 16 06:56:19.627: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
*Dec 16 06:56:19.627: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
*Dec 16 06:56:19.627: //-1/000000000000/SIP/Info/ccsip_ipip_media_forking_init: MF: Queue is initialised..
*Dec   16 06:56:19.627:   //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog   Transaction Address 184.75.215.114,Port 5060, Transport 1, SentBy Port   5060
*Dec 16 06:56:19.627: //-1/xxxxxxxxxxxx/SIP/Info/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 64.187.178.132 for SIP
*Dec 16 06:56:19.627: //-1/000000000000/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 64.187.178.132
*Dec   16 06:56:19.627: //-1/00347728803E/SIP/State/sipSPIChangeState:   0x40CA2A48 : State change from (STATE_NONE, SUBSTATE_NONE)  to   (STATE_IDLE, SUBSTATE_NONE)
*Dec 16 06:56:19.627: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
SEC-HO-VGATEWAY01#1/00347728803E/SIP/Info/ccsip_ipip_media_forking_copy_prev_best_rpid:   MF: This rpid could/could not be best one..
*Dec 16  06:56:19.627:   //-1/00347728803E/SIP/Info/sipSPIUpdateCallingInfoUsingRpidOrFrom:   Updating Calling Info with RPID header data
*Dec 16 06:56:19.627:   //-1/00347728803E/SIP/Info/sipSPISetInfoFromRpid: Received current   remote name: 6473215943, current remote number: 6473215943
*Dec  16  06:56:19.627: //-1/00347728803E/SIP/Info/sipSPISetInfoFromRpid:   Received ;screen=no ;privacy=off -> Setting Octet3A 0x80,   extended_privacy 0x00
*Dec 16 06:56:19.627: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
*Dec 16 06:56:19.627: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCSTA: No CSTA found in inbound container
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
*Dec   16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIUaddCcbToTable:  Added  to table. ccb=0x40CA2A48   key=63e5ab0b6e4ce5d3427bfa7c10e46a49@184.75.215.114:50602893211281
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 2893211281
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 6473215943
*Dec   16 06:56:19.627:   //-1/00347728803E/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo:   Calling name 6473215943, number 6473215943, Calling oct3 0x00, oct_3a   0x80, Called number 2893211281
*Dec 16 06:56:19.627:   //-1/00347728803E/SIP/Info/sipSPIGetViaHostInURLFormat: VIA   URL:sip:184.75.215.114:5060, Host:184.75.215.114
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 6473215943
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIGetPeerByCal
SEC-HO-VGATEWAY01#ledPartyId: P-Called-Party-ID not found or parse error
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIGetCallConfig: No match found for P-Called-Party-ID
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIGetCallConfig: Peer tag 1 matched for incoming call
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 64.187.178.132
*Dec 16 06:56:19.627: //-1/00347728803E/SIP/Info/sipSPIGetCallConfig: This call is being treated for E911
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Error/ccsip_ipip_media_forking_update_preferred_codec:
MF: Not a Forked SIP leg..
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPIGetCallConfig: Incoming: No defer BYE for last
                              call stats
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPIGetCallConfig: Media forking disabled
*Dec   16 06:56:19.631:   //-1/00347728803E/SIP/Info/ccsip_ipip_media_forking_anchor_leg_config:   MF: en_p->encap_s.voIP.voipPeerCfgMediaClass = 0
*Dec 16   06:56:19.631:   //-1/00347728803E/SIP/Info/ccsip_ipip_media_forking_anchor_leg_config:   MF: Dial-peer has no media class recorder.
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPIMFChangeState: MF: Prev state = 0 & New state = -1
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/ccsip_ipip_media_forking_anchor_leg_reset: MF: Anchor leg config reset done...
*Dec   16 06:56:19.631: //-1/00347728803E/SIP/Info/ccsipInitDSCPPolicyInfo:  No  DSCP Profile configured, No RPH 2 DSCP Mapping and DSCP policing
SEC-HO-VGATEWAY01#-1/00347728803E/SIP/Info/sipSPIGetCallConfig: Initilise the DSCP policy
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
*Dec   16 06:56:19.631:   //-1/00347728803E/SIP/Info/sipSPI_ipip_build_consolidated_header_list:   Both passthru and copylist are disabled
*Dec 16 06:56:19.631:   //-1/00347728803E/SIP/Info/sipSPIContinueNewMsgInvite: Calling name   6473215943, number 6473215943, Calling oct3 0x00, oct_3a 0x80, ext_priv   0x00, Called number 2893211281, oct3 0x00
*Dec 16 06:56:19.631:   //-1/00347728803E/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code  ,  prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPIValidateRequestUri: Not Enabled
*Dec 16 06:56:19.631: //-1/00347728803E/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPI_ipip_IsSDPPassthruEnabled:  - 0
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:3CFE25D8
*Dec   16 06:56:19.631:   //31/00347728803E/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr:   Not received session expires header
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
*Dec   16 06:56:19.631:   //31/00347728803E/SIP/Event/Session-Timer/sipSTSLPrintTDContainer:   Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE   Value:1800, flags:2001
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/Session-Timer/sipSTSLMain:
        SE: 0;refresher:none peer refresher:none, flags:2001, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
        Configured SE:1800, Configured Min-SE:1800
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 13254
SIP: (31) Attribute mid, level 1 instance 1 not found.
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
*Dec 16 06:56:19.631: //-1/xxxxxxxxxxxx/SIP/Info/resolve_ip_address_to_bind: ip_get_ifaddress IPv4 64.187.178.132 for SIP
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 64.187.178.132
*Dec 16 06:56:19.631: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
*Dec 16 06:56:19.631: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateD
SEC-HO-VGATEWAY01#ynamicPayloadunused: Unreserving dynamic payload type 96
*Dec 16 06:56:19.631: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
                          as its in use by other codec No Codec
*Dec   16 06:56:19.631: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT:   Requested payload-Type (101) is  reserved by another application
*Dec 16 06:56:19.631: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
*Dec 16 06:56:19.631: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
*Dec 16 06:56:19.631: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
*Dec   16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIDoAudioNegotiation:   Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
*Dec   16 06:56:19.631:   //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec:   g711ulaw ptime :20, codecbytes: 160
*Dec 16 06:56:19.631:   //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec:   g711ulaw codecbytes :160, ptime: 20
*Dec 16 06:56:19.631:   //31/00347728803E/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20,   Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
*Dec   16 06:56:19.631:   //31/00347728803E/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of full   named event(NE) match in fmtp list of events.
*Dec 16   06:56:19.631:   //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE   payload = 0, SSE payload = 0, SPRT payload=0
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Dec   16 06:56:19.631:   //31/00347728803E/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction   attribute present or multiple direction attributes that can't be  handled  for m-line:1 and num-a-lines:0
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
        payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
        stream_type=voice+dtmf (1), dest_ip_address=184.75.215.114, dest_port=13254
*Dec   16 06:56:19.631: //31/00347728803E/SIP/State/sipSPIChangeStreamState:   Stream (callid =  -1)  State changed from (STREAM_DEAD) to   (STREAM_ADDING)
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Media/sipSPIUpdCallWithSdpInfo:
        Preferred Codec        : transparent, bytes
        Preferred  DTMF relay  : rtp-nte
        Preferred NTE payload  : 101
        Early Media            : No
        Delayed Media          : No
        Bridge Done            : No
        New Media              : No
        DSP DNLD Reqd          : No
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/resol
SEC-HO-VGATEWAY01#ve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/ccsip_offer_ans_handle_rcvd_sdp:
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/ccsip_offer_ans_process_event:
*Dec   16 06:56:19.631: //31/00347728803E/SIP/State/ccsip_cnfsm_debugs:   OA:cur_container:ccsip_offer_ans_main_container,   cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_RCVD
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/ccsip_offer_ans_is_invite_offer_valid:  - 1
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/ccsip_offer_ans_common_offer_rcvd_hdlr:
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/ccsip_iwf_handle_network_event:
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/ccsip_iwf_process_event:
*Dec   16 06:56:19.631: //31/00347728803E/SIP/State/ccsip_cnfsm_debugs:   IWF:cur_container:sip_iwf_default_early_dialog_container,   cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_RCVD_SDP
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sip_iwf_def_ed_rcvd_sdp_hdlr:
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:
CallID 31, sdp 0x3D0DF898 channels 0x40CA41A4
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/copy_channels:
callId 31 size 0 ptr 0x40993DD8)
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPI_ipip_copy_and_init_channelInfo_params:
CCB t38 version 0 ipip_caps version 0
CCB fax rate 2 ipip_caps rate 14400
*Dec   16 06:56:19.631:   //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:   stream_callid = 31, peer_stream_callid = -1
Hndl ptype 0 mline 1
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/codec_found:
Codec to be matched: 5
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPI_ipip_update_codec_params_in_channelInfo:
*Dec   16 06:56:19.631:   //31/00347728803E/SIP/Info/sipSPI_ipip_update_codec_params_in_channelInfo:   Parsing from stream media address
Adding negotiated codec 5 ptype 0 time 20,   bytes 160 as channel 0 mline 1 ss 1 184.75.215.114:13254
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Error/sipSPI_ipip_update_codec_params_in_channelInfo:
failed to update call entry
*Dec   16 06:56:19.631:   //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Media   negotiation done:   stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160,stream->mline_index=1,   media_ndx=1
*Dec 16 06:56:19.631:   //31/00347728803E/SIP/Info/sipSPIBwCacCalcAudioBandwidth: calculated   audio bandwidth : codec g711ulaw      bw 64000
Hndl ptype 18 mline 1
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Selecting codec g729r8
Codec to be matched: 16
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 16
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPI_ipip_GetCodecBytePtimeFromSdp:
*Dec 16 06:56:19.631: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g729r8 ptime :20, codecbytes: 20
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPI_ipip_GetCodecBytePtimeFromSdp: Codec bytes 0, use default packet rate 20
SEC-HO-VGATEWAY01#47728803E/SIP/Info/sipSPI_ipip_update_codec_params_in_channelInfo:
Adding negotiated codec 16 ptype 18 time 20,   bytes 20 as channel 1 mline 1 ss 1 184.75.215.114:13254
*Dec   16 06:56:19.631:   //31/00347728803E/SIP/Info/sipSPIBwCacCalcAudioBandwidth: calculated   audio bandwidth : codec g729r8        bw 8000
Hndl ptype 101 mline 1
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPI_ipip_update_dynamic_codec_params:
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sipSPI_ipip_upd_2833_dtmf_params:
*Dec   16 06:56:19.631:   //31/00347728803E/SIP/Info/sipSPI_ipip_upd_2833_dtmf_params: setting   ipip_caps DTMF to RFC2833: callid = 31, dtmf = 6
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Error/sipSPI_ipip_update_call_entry:
*Dec   16 06:56:19.631:   //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Copy  sdp  to channel- AFTER CODEC FILTERING:   ccb->pld.ipip_caps.codecInfo[0].codec = 5
*Dec 16  06:56:19.631:   //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Copy   sdp to channel- AFTER CODEC FILTERING:   ccb->pld.ipip_caps.codecInfo[1].codec = 16
*Dec 16   06:56:19.631:   //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: Copy  sdp  to channel- AFTER CODEC FILTERING:   ccb->pld.ipip_caps.codecInfo[2].codec = -1
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo: srcChannelID = -1, dstChannelID = 31
*Dec 16 06:56:19.631: //31/00347728803E/SIP/Media/sipSPIDisplayStreamInfo:
          Stream type            : voice+dtmf
          Media line             : 1
          State                  : STREAM_ADDING (2)
          Stream address type    : 1
          Callid                 : 31
          Peer Callid            : -1
          RTP/SRTP Negotiated     : 8
          Negotiated Codec       : g711ulaw, bytes :160
          Nego. Codec payload    : 0 (tx), 0 (rx)
          Negotiated DTMF relay  : rtp-nte
          Negotiated NTE payload : 101 (tx), 101 (rx)
          Negotiated CN payload  : 0
          Media Srce Addr/Port   : [64.187.178.132]:0
          Media Dest Addr/Port   : [184.75.215.114]:13254
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPI_ipip_calculate_channel_count: Number of streams to report = 1
*Dec 16 06:56:19.635: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_set_channel_count:
Unable to set CHANNEL_COUNT for callid 31
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Error/sip_iwf_sip_copy_sdp_to_channelInfo:
Channel count is not set at this point. Not SIP-SIP or SET_MODE is not done.
*Dec   16 06:56:19.635:   //31/00347728803E/SIP/Info/sip_iwf_sip_copy_sdp_to_channelInfo:   sdp->chnl audio bw 80000 bps video bw 0 bps fax bw 0 bps
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sip_iwf_def_ed_rcvd_sdp_hdlr: Setting media_direction to 4
*Dec   16 06:56:19.635:   //31/00347728803E/SIP/Info/sipSPIBwCacUpdateAccountedBw: bwcac update   accounted BW Option 0 flow mode flow-through
audio bw 80000 bps video bw 0 bps fax bw 0 bps total bw 80000 bps  accounted bw 0 bps
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIBwCacUpdateInterfaceBw: bwcac acquiring interface Loopback0 bw 80
*Dec   16 06:56:19.635:   //31/00347728803E/SIP/Info/sipSPIBwCacUpdateAccountedBw: bwcac update   accounted bw (initial offer) accounted bw set to 80000
*Dec 16 06:56:19.635: //31/00347728803E/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_RCVD_AWAIT_PEER_EVENT
*Dec 16 06:56:19.635: //31/00347728803E/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_RCVD
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Media/sipSPIUpdCallWithSdpInfo:
          Media line             : 1
          Callid                 : 31
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIHandleInviteMedia:
Preferred  DTMF relay 1 : 6
Preferred  DTMF relay 2 : 0
Negotiated DTMF relay   : 6
Preferred and Negotiated NTE payloads: 101 101
Preferred and Negotiated NSE payloads: 100 0
Preferred and Negotiated Modem Relay: 0 0
Preferred and Negotiated V150.1 Modem Passthrough: 0 0
Preferred
SEC-HO-VGATEWAY01#and Negotiated V150.1 Modem Relay: 0 0
Preferred and Negotiated Modem Relay GwXid: 1 0
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIBwCacIsDialPeerBwAvailable: bwcac NOP dial-peer bw available tag 1
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIBwCacIsInterfaceBwAvailable: bwcac interface bw threshold not configured
*Dec   16 06:56:19.635:   //31/00347728803E/SIP/Info/sipSPIBwCacVerifyBwThreshold: bwcac verify  bw  threshold, bw available allow call total bw 80000 bps
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
*Dec 16 06:56:19.635: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16418 for stream 1
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Reserving rtp port for stream 1, src_port=16418
*Dec 16 06:56:19.635: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 16418
SIP update src sdp, negoitated codec 5, payload type 0
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 16
*Dec   16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIAddBillingInfoToCcb:   sipCallId for billing records =   63e5ab0b6e4ce5d3427bfa7c10e46a49@184.75.215.114:5060
*Dec 16 06:56:19.635: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCPA: No CPA found in inbound container
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIProcessCPA: No x-cisco-cpa content found
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
*Dec   16 06:56:19.635:   //31/00347728803E/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer:   Unsupported header passthru is not configured and no headers are   present in hdr_hash_queue
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled:  - 0
*Dec   16 06:56:19.635:   //31/00347728803E/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer:   Passthru Content Not Enabled
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/ccsip_api_call_setup_ind: Unable to add unsupp headers to container
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/ccsip_api_call_setup_ind: Set Protocol information
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 26
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/ccsip_api_call_setup_ind: Setting media_direction to 4
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
*Dec   16 06:56:19.635:   //31/00347728803E/SIP/Info/sipSPI_ipip_store_channel_info: dtmf   negotiation done, storing negotiated dtmf = 6,
*Dec 16   06:56:19.635: //31/00347728803E/SIP/Info/sipSPI_ipip_store_config_info:   Setting mid_call_config_info = 0x0 for callid = 31
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Media/sipSPIDisplayStreamInfo:
          Media line             : 1
          Callid                 : 31
          Peer Callid            : -1
          Media Srce Addr/Port   : [64.187.178.132]:16418
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPI_ipip_store_channel_info: Setting CHANNEL_COUNT = 1 for callid 31
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIShrlCall: Check peer: 1 for Shared-Line call, callid: 31
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/ccsip_set_bearer_capability:
   Bearer Capability: Speech (0x00)
*Dec 16 06:56:19.635: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
*Dec 16 06:56:19.635: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
*Dec 16 06:56:19.635: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 1F to table
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Info/sipSPIUpdateCallEntry:
Call 31 set InfoType to SPEECH
*Dec 16 06:56:19.635: //31/00347728803E/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESPACK
SEC-HO-VGATEWAY01# sip:2893211281@64.187.178.132 SIP/2.0
Max-Forwards: 70
To: <sip:2893211281@64.187.178.132>;tag=2256B8-227B
CSeq: 102 ACK
User-Agent: voip.ms
Content-Length: 0
*Dec 16 06:56:21.007: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Dec 16 06:56:21.007: //-1/xxxxxxxxxxxx/SIP/Error/sipSPISipIncomingMsg:
Invalid method for (STATE_IDLE): ACK
Everyone's tags (5)
1 ACCEPTED SOLUTION
VIP Super Bronze
From the logs, we can see that your call is matching dial-peer 1
This is the config on dial-peer 1..
dtmf-relay rtp-nte
codec transparent
no vad
Here is what I think is going on..The incoming URI command takes precedence over incoming called number, hence the reason why this dial-peer is matched...Try and remove the incoming URI command on this dial-peer and test again
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Silver
How about if you change
to
incoming called-number .T
or move dial peer 501 before 101, delete and re-add dial peer 101?
Chris
Hi Chris,
I have tried it with all possible ways. i.e. .T and .* and also 2893211... etc but nothing seems to be working. I am going to give your other suggestion a try in a little bit and will update you. Thanks for the reply.
Ajlal
Hi Chris,
I tried removing and adding back the dialpeer 101 and adding .T to 501 but still the same result. Please help.
Please see the following:
SEC-HO-VGATEWAY01#show dial-peer voice summ
dial-peer hunt 1
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE
501    voip  up   up                                0  syst
1001   voip  up   up             5...               1  syst ipv4:10.13.14.21
1002   voip  up   up             1...$              1  syst ipv4:10.13.14.21
103    voip  up   up             911$               1  syst dns:toronto2.voip.ms
102    voip  up   up             1[2-9]..[2-9]...-  1  syst dns:toronto2.voip.ms
101    voip  up   up             [2-9]..[2-9]....-  1  syst dns:toronto2.voip.ms
SEC-HO-VGATEWAY01#show run | sec dial-peer voice 501
dtmf-relay rtp-nte
codec g711ulaw
no vad
VIP Super Bronze
dtmf-relay rtp-nte
codec transparent
no vad
Re: Unable to match incoming calls to a dialpeer
Hi Aokanlawon and Chris,
First of all, thanks a lot for your help. I figured out what the problem was. The reply of Aokanlawon pointed me in the right direction. As Aokanlawon suggested the dial peer 1 was getting matched for the incoming calls as the INCOMING URI command was taking precedence over the INCOMING CALLED-NUMBER . command in the dialpeer 501, however, when I had the DEBUG VOICE DIALPEER ALL on it was only showing dialpeer 101 as the match and that is what created all the confusion. At the same time the DEBUG CCSIP ALL was showing that dialpeer 1 was matching the incoming calls.
So I tought that maybe the incoming dialpeer match is not being showed in the dialpeer debug but it is actually matching. So I got rid of the dialpeer 1 and only kept dialpeer 501 for incoming and also applied the translation rule that converted the incoming called number to a 4 digit extention. The did the trick and the calls started routing.
So to summarize, the incoming dialpeer match is not showed in the DEBUG VOICE DIALPEER ALL only the outbound dialpeer is showed. So when I configured the translation profile on the incoming dialpeer 501 it started showing the output dialpeer to the CUCM as well and that is how it routed the call.
If anyone needs any help with this issue in future or if something is not clear in my explanation please contact me at ajlalhaider13@gmail.com
AJ
1141
