Unable to open Cisco Unified Communications Manager Express
Hello All,
We have Cisco 1861, i am doing Voip deployment on it, i attached my configuration, can anyone look it, & please let me know if i'm wrong because I'm Unable to open Cisco Unified Communications Manager Express throuh Browser
Vikrant
1 ACCEPTED SOLUTION
Re: Unable to open Cisco Unified Communications Manager Express
Have a look at the following CME Admin Guide for Installing the software.  Looks like you haven't TFTP'ed the files to the flash yet:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html
Pl. try adding following two commands:
no ip http secure-server
ip http path flash:
I am assuming your PC/browser has IP connex to the CME router
and all CME GUI files are on the flash?
As Dilip mentioned, make sure you have the CME files on the flash and also extract them if they are still in .tar format using the
'archive tar /xtract' command'.
Thanks for your Reply,
Can you please explain how to check whether CME GUI files is on the flash or not..
Vikrant
The CME GUI tar file would be cme-gui-7.1.0.0.tar or cme-gui-124-24t.tar (or something else depending on the version you're running).  If you don't see files on the flash such as admin_user.html then you need to extract the tar file to get the html files for the GUI.
Can u suggest how to extract Call manager from flash:
Melbourne1861#sh flash:
-#- --length-- -----date/time------ path
1         2898 Aug 27 2009 05:28:34 +00:00 cpconfig-18xx.cfg
2      2324992 Aug 27 2009 05:28:50 +00:00 cpexpress.tar
3         1038 Aug 27 2009 05:29:00 +00:00 home.shtml
4       115712 Aug 27 2009 05:29:10 +00:00 home.tar
5      1697952 Aug 27 2009 05:29:28 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
6       415956 Aug 27 2009 05:29:40 +00:00 sslclient-win-1.1.4.176.pkg
7     34148116 Nov 5 2009 01:09:06 +00:00 c1861-spservicesk9-mz.124-20.T4.bin
457
