Unable to reach devices behind Cisco 3750 on the same inside VLAN via Cisco Anyconnect VPN
Hi Guys,
I've been stuck with this for the last 2 days, and I thought to try and use Cisco's forum, I setup my home DC, and started having problems once I moved a Cisco 5505 behind a Cisco 1841 router, I was no longer able to ping some devices, then as soon as I introduce a collapsed core/distribution switch, I'm also no longer able to ping the devices behind the Cisco ASA 3750.
For some odd reason, I am able to ping the following.
Cisco 3750 SVI (192.168.1.3)
CentOS web server (connected directly to the Cisco ASA 5505)
I have checked and enable the following:
  • Nat Exemption
  • Sysopt connection permit-vpn
  • ACL's
  • same-security-traffic permit inter-interface
  • same-security-traffic permit intra-interface
  • Added ICMP in the inspection policy
Any help is much appreciated, and thank you.
Network Diagram
Discussion created from blog https://supportforums.cisco.com/blog/12265331/unable-reach-devices-behind-cisco-3750-same-inside-vlan-cisco-anyconnect-vpn as blogs should not be used to post questions.  (I did not include the entire configuration txt file since It might contain confidential information)
1 ACCEPTED SOLUTION
Please move this to the
Please move this to the appropriate Security forum.
Please rate useful posts.
1 REPLY
50
