Unable to receive direct incoming calls when in SRST mode
Hi there - I have an issue relating to my 2851 when in SRST mode. I am able to make outgoing calls with no issues. However if I dial a number at the site I am presented with a dial tone and not a phone ringing. During this dial tone if I dial the 4 digit extension the SRST phone at the site rings.
I'm grateful for any suggestions. Config and debug isdn Q931 below.
Note all works OK when the gateway can see the CUCM server.
VG04_2851_LAB#sh run
Building configuration...
Current configuration : 2347 bytes
version 12.4
hostname VG04_2851_LAB
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 4096 informational
logging console informational
logging monitor informational
no aaa new-model
resource policy
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip subnet-zero
ip cef
ip host CUCM6-Publisher 10.60.5.10
isdn switch-type primary-net5
voice-card 0
no dspfarm
voice call send-alert
voice rtp send-recv
application
global
service alternate Default
username <removed for privacy>
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
interface GigabitEthernet0/0
ip address 10.60.5.23 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
isdn incoming-voice voice
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.60.5.1
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.60.5.10
ccm-manager config
mgcp
mgcp call-agent CUCM6-Publisher 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 1 pots
destination-pattern 9T
port 0/0/0:15
dial-peer voice 2 pots
destination-pattern 02032061...
incoming called-number .
direct-inward-dial
call-manager-fallback
max-conferences 8 gain -6
limit-dn 7960 2
ip source-address 10.60.5.23 port 2000 strict-match
max-ephones 3
max-dn 6 dual-line
dialplan-pattern 1 02032061... extension-length 4 extension-pattern 1...
keepalive 20
line con 0
login local
line aux 0
line vty 0 4
login local
scheduler allocate 20000 1000
end
VG04_2851_LAB#
incoming debug ISDN Q931
*Sep 11 13:04:22.231: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected
to N/A N/A
*Sep 11 13:04:30.067: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0 disconnected
from unknown , call lasted 7 seconds
Outgoing debug ISDN Q931
*Sep 11 13:05:45.635: %ISDN-6-CONNECT: Interface Serial0/0/0:30 is now connected
to <removed for privacy>118 N/A
*Sep 11 13:05:48.307: %ISDN-6-DISCONNECT: Interface Serial0/0/0:30 disconnected
from <removed for privacy>118 , call lasted 2 seconds
Thanks again for your help.
Best Regards,
Alfie
  • IP Telephony
1 ACCEPTED SOLUTION
Re: Unable to receive direct incoming calls when in SRST mode
I would recommend that you use voice translation rules for digit manipultaion and remove the dialplan-pattern command from your SRST configuration, as this has an affect on both outbound and inbound calls.
Under dial-peer voice 2 pots enter the following:
port 0/0/0:15
Hope that helped, if so please rate.
Hi Kenneth,
Thanks for the swift response. I added the port as requested
direct-inward-dial
port 0/0/0:15
Unfortunately this did not work. Now when dialing there is an unobtainable tone and no Q931 info being displayed.
Best Regards,
Alfie
This is most likely a dial-peer problem. issue debug voip dialpeer and see which dialpeer the call is hitting. Also, how many digits is telco sending on incoming calls?
Hello Again,
I have debugged as requested but get no output!!!
The Telco has confirmed they are sending six digits. In light of this I have amended dial-peer 2 to read;
incoming called-number 061...
direct-inward-dial
for a number 020320617XX
debugging is as follows with term mon;
The following ISDN debugs are enabled on all DSLs:
debug isdn error is ON.
debug isdn q931 is ON. (filter is OFF)
DIALPEER:
debug voip dialpeer error call is ON (filter is OFF)
debug voip dialpeer error software is ON
debug voip dialpeer inout is ON (filter is OFF)
CCAPI:
debug voip ccapi inout is ON (filter is OFF)
Now getting an unreachable tone when dialing and no debug output.
Getting frustrating now so appreciate your help.
Alfie
Whether or not the call completes, you should get some debug output when the call completes if you have "term mon" on. I know this seems obvious, but please check to make sure that your PRI is indeed up.
Hi again,
ISDN is up and have verified for sanity by dialing in when there is a call going out. Output is below.
VG04_2851_LAB#
*Sep 14 12:37:58.485: %ISDN-6-CONNECT: Interface Serial0/0/0:30 is now connected
to 123 N/A
*Sep 14 12:38:04.461: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected
to N/A N/A
*Sep 14 12:38:08.937: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0 disconnected
from unknown , call lasted 4 secondsconf t
Enter configuration commands, one per line. End with CNTL/Z.
VG04_2851_LAB(config)#dial-peer voice 2 pots
VG04_2851_LAB(config-dial-peer)#incoming called-number 061...
VG04_2851_LAB(config-dial-peer)#direct-inward-dial
VG04_2851_LAB(config-dial-peer)#^Z
VG04_2851_LAB#
*Sep 14 12:39:01.509: %SYS-5-CONFIG_I: Configured from console by ksfadmin on vt
y0 (10.56.45.51)
*Sep 14 12:39:22.221: %ISDN-6-DISCONNECT: Interface Serial0/0/0:30 disconnected
from 123 , call lasted 83 seconds
Still the same issue if I remove the incoming dial peer I'm presented with the dial tone. Then I dial the 4 digit ext and am put through.
If telco is sending you 6 digits and your extensions are 4 digits, you may try translating the 6 digits to 4. Example
voice translation-rule 1
rule 1 /^061.../ /1.../
voice translation-profile TEST
translate called 1
destination-pattern 061...
translation-profile incoming TEST
direct-inward-dial
Hi appreciate your swift responses.
I had to amend the translation rule to
rule 1 /^061.../ /1702/
purely as my router did not like me adding the final ... as you suggested.
Still no answer when dialing 02032061702. However unlike previously when I just got a reorder tone, I now get the dial tone as previously.
Alfie
Try removing the dialplan-pattern statement from under call-manager-fallback and try again. Sorry for all the back and forth, Im not an expert in SRST but am curious about the issue.
529
