Community Member
unable to register mgcp gateway on cucm 9.1
It just sits in this state of Registering with CM.
Router is a 3845 running ios: c3845-spservicesk9-mz.124-24.T8.bin
On the CUCM, I enter the router as the 3845, specify MGCP, and the ports (fxo/fxs) that are on it, and enter the FQDN, copied directly from the router so it is exactly the same.
On the DNS server, I have an A record and a PTR for the router.  The router successfully downloads a config from the tftp server, a lot of the configuration below was downloaded via tftp from the cucm.  On the CUCM under the transcoder, under XCODER, I see the router successfully registered with the routers IP address.  But the router never goes beyond registering with cm.
I changed the domain name below, but has the same number of characters/dots in case that is important.
Problem:
voiptest1#sh ccm
MGCP Domain Name: voiptest1.companys.aaa.int
Priority        Status                   Host
Primary         Registering with CM      192.168.49.81
First Backup    None
Second Backup   None
router config:
hostname voiptest1
ip domain name companys.aaa.int
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.49.81
ccm-manager config
mgcp
mgcp call-agent 192.168.49.81 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.49.81 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register XCODER
associate profile 2 register CONFERENCE
1 ACCEPTED SOLUTION
Purple
Hi Clark,
Do u have any E1/T1 card on router since MGCP does not directly control FXS/FXO ports as compared to E1/T1?
regds,
aman
Purple
Hi Clark,
regds,
aman
Community Member
I hadnt added it yet, I just put it in the router and added it in the MGCP configuration on the server, still nothing.
Community Member
It registered after I applied the config to the PRI from the Server.  Thank you for the help.
Hi Beau,
Is the Domain name entered on the gateway page on cucm the same as on gateway i.e voiptest1.companys.aaa.int ?
Is there any firewall between the gateway and callmanager 192.168.49.81 ?
Config on the gateway loos good, you can try bouncing mgcp ( no mgcp / mgcp ) and collect debug mgcp packets for the same to get some additional pointers.
Manish
Purple
Hi Clark,
thanks for update.
If possible,please share show diag and complete show config of router.
a. show ccm-manager
b. show controller E1
regds,
aman
957
