Community Member
Unable to route calls from FXO
Hi All,
I have below CME setup and i am able to call from Analog phone connected to FXS port to all PSTN numbers but unable to receive call from PSTN on to the analog phone connected to FXS port. I can see the PSTN call is hitting my FXO port but cannot receive call on to my analog phone. Can any one help me?
Mangesh Bhende
1 ACCEPTED SOLUTION
Re: Unable to route calls from FXO
On the inbound call from telco  to the FXO, does the analog phone on FXS port even ring ?
I'd suggest to change ring number to a lower value (say 2 or default) and then shut/no shut
the port so that we close the loop quicker.
Can u pl. make that change and test?
If it still fails, can u provide deb voip ccapi inout and deb vpm sig along with config?
1 REPLY
159
