Unable to upload MoH wav file
I'm having issues with uploading wave file.  I am running CUCM 8.6.1.20000-1.  What I notice is I am able to upload the file to Sub but not to Pub.  After I upload to SUB, Pub shows the stream number but says filewas not found in specified directory.  I have restarted Voice media service and am thinking of rebooting the PUB.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Check out:
CSCtr11072          Bug Details
MOH Audio File may be slow or fail to upload
Symptom:
MOH file upload fail, upload window does not update.
Conditions:
- CUCM 8.6.1.10000-43
- CUCM 8.6.1.20000-1
Workaround:
Additional Information
To recreate issue:
1) Open the MOH Audio file Management Select Upload file --  the upload file
window will pop up.
2) Select a file to upload.  The window get stuck, the file is not upload
1st Found-In
1st Found-in
8.6(1.10000.43)
8.6(1.20000.1)
Fixed-In
Fixed-in
8.6(1.98000.43)
8.6(1.98000.98)
8.6(1.21002.1)
8.6(2.10000.30)
HTH,
Chris
1 REPLY
Check out:
Symptom:
Conditions:
Workaround:
To recreate issue:
window will pop up.
1st Found-In
1st Found-in
8.6(1.10000.43)
8.6(1.20000.1)
Fixed-In
Fixed-in
8.6(1.98000.43)
8.6(1.98000.98)
8.6(1.21002.1)
8.6(2.10000.30)
HTH,
Chris
489
