Unable to use touchtone service Cisco CME 7.1
The  config below is a for a 2911 v/sec-k9 rtr with CME 7.1...I have  everything working..I can make outbound and receive inbound calls.  However when I call-in  to leave a message and hit the # key or call an  external number from my  cisco phone, I cannot seem to get the DTMF  (touchtone)  to work for answering AA prompts. Can someone look at my  config and please and tell me what I am doing wrong? I have another PBX  connected to the same provider, and I can answer DTMF prompts from the  AA.
Last configuration change at 16:48:01 EST Tue Jul 16 2013
logging buffered 51200
logging console critical
clock timezone EST -5
clock summer-time EST recurring
ip source-route
ip cef
ip dhcp excluded-address 10.52.35.1 10.52.35.69
ip dhcp excluded-address 10.52.35.200 10.52.35.254
ip dhcp pool MyLCLPool
import all
network 10.52.35.0 255.255.255.0
    domain-name myweb.net
dns-server 64.151.85.68 216.246.37.202
default-router 10.52.35.1
option 150 ip 10.52.35.1
option 66 ip 10.52.35.1
ip domain name myweb.net
ip name-server 209.18.47.61
ip name-server 64.151.85.68
password encryption aes
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice register global
mode cme
source-address 10.52.35.1 port 5060
max-dn 50
max-pool 30
timezone 13
time-format 24
dst start Apr day 1 time 02:00
dst stop Oct day 1 time 02:00
create profile sync 0014215810250381
voice translation-rule 1
rule 1 /9911/ /911/
rule 2 /9411/ /411/
voice translation-rule 2
rule 1 /97XX/ /7XX/<br />!<br />voice translation-rule 3<br /> rule 1 /9/ //
voice translation-rule 4
rule 1 /91/ /1/<br />!<br />voice translation-rule 5<br /> rule 1 /9011/ /011/
voice translation-rule 6
rule 1/17XXXXXXXX/ /1.../
voice translation-rule 7
rule 1 /1.../ /17XXXXXXXX/
voice translation-profile Incoming
translate calling 7
translate called 6
voice translation-profile Internationl
translate calling 7
translate called 5
voice translation-profile Local10
translate calling 7
translate called 2
voice translation-profile Local7
translate calling 7
translate called 3
voice translation-profile LongDistance
translate calling 7
translate called 4
voice translation-profile Services
translate calling 7
translate called 1
voice translation-profile voip-in
translate calling 2
translate called 1
!hw-module pvdm 0/0
energywise activitycheck
hw-module sm 1
redundancy
no ip ftp passive
ip ssh version 2
interface Loopback0
description created for NME-CUE loopback
ip address 10.52.21.1 255.255.255.0
interface GigabitEthernet0/0
description WAN
ip address dhcp client-id GigabitEthernet0/0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
description Internal Voice Lan$ETH-LAN$
ip address 10.52.35.1 255.255.255.0
ip helper-address 10.52.35.1
ip nat inside
duplex auto
speed auto
interface Integrated-Service-Engine1/0
description Cisco NME-CUE 8.0 loopback
ip unnumbered Loopback0
service-module ip address 10.52.21.2 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 10.52.21.1
no keepalive
ip forward-protocol nd
ip http server
ip http secure-server
ip http path flash:/GUI
ip nat inside source list 3 interface GigabitEthernet0/0 overload
ip route 10.52.21.2 255.255.255.255 Integrated-Service-Engine1/0
access-list 1 remark CCP_ACL Category=16
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 10.52.35.0 0.0.0.255
access-list 3 remark CCP_ACL Category=2
access-list 3 permit 10.52.35.0 0.0.0.255
tftp-server flash:term06.default.loads alias term06.default.loads
tftp-server flash:term11.default.loads alias term11.default.loads
tftp-server flash:B015-1-0-3.SBN alias B015-1-0-3.SBN
tftp-server flash:B016-1-0-3.SBN alias B016-1-0-3.SBN
tftp-server flash:CP7921G-1.3.3.LOADS alias CP7921G-1.3.3.LOADS
tftp-server flash:APPS-1.3.3.SBN alias APPS-1.3.3.SBN
tftp-server flash:GUI-1.3.3.SBN alias GUI-1.3.3.SBN
tftp-server flash:MISC-1.3.3.SBN alias MISC-1.3.3.SBN
tftp-server flash:SYS-1.3.3.SBN alias SYS-1.3.3.SBN
tftp-server flash:TNUX-1.3.3.SBN alias TNUX-1.3.3.SBN
tftp-server flash:WLAN-1.3.3.SBN alias WLAN-1.3.3.SBN
tftp-server flash:term31.default.loads alias term31.default.loads
tftp-server flash:apps37sccp.1-3-4-0.bin alias apps37sccp.1-3-4-0.bin
tftp-server flash:term41.default.loads alias term41.default.loads
tftp-server flash:term61.default.loads alias term61.default.loads
tftp-server flash:term42.default.loads alias term42.default.loads
tftp-server flash:term62.default.loads alias term62.default.loads
tftp-server flash:term45.default.loads alias term45.default.loads
tftp-server flash:term65.default.loads alias term65.default.loads
tftp-server flash:term75.default.loads alias term75.default.loads
tftp-server flash:term70.default.loads alias term70.default.loads
tftp-server flash:term71.default.loads alias term71.default.loads
tftp-server flash:p00307020300.bin
tftp-server flash0:dsp45.9-2-1TH1-13.sbn alias dsp45.9-2-1THT1-13.sbn
tftp-server flash0:jar45sccp.9-2-1TH1-13.sbn alias jar45sccp.9-2-1THT1-13.sbn
tftp-server system:/its/SEPDEFAULT.cnf alias SEPDEFAULT.cnf
tftp-server system:/its/vrf1/ATADefault.cnf.xml
tftp-server system:/its/united_states_7960-tones.xml
tftp-server system:/its/united_states alias United_States_7960-tones.xml
control-plane
call threshold global cpu-avg low 68 high 75
call threshold global total-mem low 75 high 85
call threshold global total-calls low 1 high 2
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 5
associate application SCCP
dial-peer voice 100 voip
description Connect to voicemail
destination-pattern 5...
session protocol sipv2
session target ipv4:10.52.21.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 10 voip
translation-profile outgoing Services
destination-pattern 9[49]11
session target dns:sip.provider.com
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 11 voip
translation-profile outgoing Local10
destination-pattern 9718[2-9]......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 12 voip
translation-profile outgoing Local7
destination-pattern 9[2-9]......
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 13 voip
translation-profile outgoing LongDistance
destination-pattern 91[2-9]..[2-9]......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 14 voip
translation-profile outgoing International
destination-pattern 9011T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1 voip
description *** Incoming call from SIP Trunk ***
translation-profile incoming Incoming
destination-pattern 1...
session target sip-server
session transport tcp
incoming called-number 17XX......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 101 voip
description *** CUE VOICEMAIL AA NUMBER ***
destination-pattern 5002
codec g711ulaw
no vad
dial-peer voice 102 voip
description *** CUE aVT PILOT NUMBER ***
destination-pattern 5003
codec g711ulaw
no vad
sip-ua
credentials username username 7 0050312A5C0 realm sip.provider.com
  authentication username username password 7 0879271E033A
no remote-party-id
retry register 3
registrar dns:sip.provider.com expires 300
sip-server dns:sip.provider.com
telephony-service
authentication credential vmail xxxxxx
max-ephones 30
max-dn 50
ip source-address 10.52.35.1 port 2000
calling-number initiator
system message Fix Me!!
  url services http://10.52.21.2/voiceview/common/login.do
url authentication http://10.52.21.1/CCMCIP/authenticate.asp
cnf-file location flash:
load 7915-12 B015-1-0-3.SBN
load 7915-24 B015-1-0-3.SBN
load 7916-12 B016-1-0-3.SBN
load 7916-24 B016-1-0-3.SBN
load 7906 SCCP11.8-5-3S.loads
load 7911 SCCP11.8-5-3S.loads
load 7921 CP7921G-1.3.3.LOADS
load 7931 SCCP31.8-5-3S.loads
load 7937 apps37sccp.1-3-4-0.bin
load 7941 SCCP41.8-5-3S.loads
load 7941GE SCCP41.8-5-3S.loads
load 7942 SCCP42.8-5-3S.loads
load 7945 SCCP45.8-5-3S.loads
load 7961 SCCP41.8-5-3S.loads
load 7961GE SCCP41.8-5-3S.loads
load 7962 SCCP42.8-5-3S.loads
load 7965 SCCP45.9-2-1S.loads
load 7970 SCCP70.8-5-3S.loads
load 7971 SCCP70.8-5-3S.loads
load 7975 SCCP75.8-5-3S.loads
time-zone 13
voicemail 5001
max-conferences 4 gain -6
call-forward pattern .T
call-forward pattern 9.T
call-forward system redirecting-expanded
moh flash:/music-on-hold.au
web admin system name vmail password xxxxxxxx
web admin customer name user password xxxxxxx
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp 7960 Jul 14 2013 02:03:20
ephone-dn 1 dual-line
number 1001
call-forward busy 5002
call-forward noan 5001 timeout 15
ephone-dn 2 dual-line
number 1002
call-forward busy 5001
ephone-dn 3 dual-line
number 1003
ephone 1
device-security-mode none
mac-address 0022.555E.9ED1
button 1:1 2:2 3:3
line 67
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
ntp master
end
VIP Super Bronze
Can you do a test call and send the following:
debug ccsip messages
debug voip rtp session-named event
Include the calling and called number and the digits you pressed
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: Unable to use touchtone service Cisco CME 7.1
HI sorry for not responding earlier. Please see the attached debug file.....
329
