Unallocated/unassigned number
In below debug isdn q931 is the unallocated/unassigned because the calling party number says “local number”?
In this case the Castelle fax press is dialing my home fax machine at 919043399696
I'm guessing this Castelle fax press sending local number is making the MGCP/PRI unhappy?
Router3#
002082: Nov 7 18:35:12.251 EDT: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0056
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98388
Exclusive, Channel 8
Calling Party Number i = 0x0080, 'local number'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '919043399696'
002083: Nov 7 18:35:12.255 EDT: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8056
Cause i = 0x8081 - Unallocated/unassigned number
002084: Nov 7 18:35:17.671 EDT: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8
1 REPLY
Hall of Fame Super Gold
Re: Unallocated/unassigned number
Is this interface connected directly to PSTN, or something else? If so, the problem is the leading 9 in called number, not supposed to be there.
Admittedly,
is very strange, but perhaps that is some default value that has not been changed.
247
