unavailable channel disconnect
Hi;
Changed out callmgrs from 4.x to 6.1 over weekend.
Remote site in London has a H323 gateway w/ partial E1 to PSTN. Nothing was changed in config but now out calls can not be made from one phone. Q931 debug shows call being setup but router disconnects it with a "unavailable channel" cause code.
Stanger thing is it is only happening from this one phone. the other phones work fine.
below is debug from attempted call from x307 and then good call from x305, both to same number over same E1 channel.
Any suggestions would be welcome:
005349: Apr 1 15:19:59.963 gmt: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x03FC
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838A
Exclusive, Channel 10
Calling Party Number i = 0x0081, '2075622307'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '08701662801'
005350: Apr 1 15:20:00.183 gmt: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x83FC
Progress Ind i = 0x8288 - In-band info or appropriate now available
005351: Apr 1 15:20:00.643 gmt: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x03FC
Cause i = 0x80AC - Requested circuit/channel not available
005352: Apr 1 15:20:00.783 gmt: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x83FC
005353: Apr 1 15:20:00.787 gmt: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x03FC
JCF-LN-2821-1#
JCF-LN-2821-1#
JCF-LN-2821-1#
005354: Apr 1 15:21:12.840 gmt: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 2075622305
005355: Apr 1 15:21:12.840 gmt: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 08701662801
005356: Apr 1 15:21:12.840 gmt: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x03FD
Standard = CCITT
Calling Party Number i = 0x0081, '2075622305'
005357: Apr 1 15:21:13.052 gmt: ISDN Se0/1/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x83FD
005358: Apr 1 15:21:16.544 gmt: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x83FD
005359: Apr 1 15:21:17.504 gmt: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x83FD
005360: Apr 1 15:21:19.312 gmt: ISDN Se0/1/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x83FD
005361: Apr 1 15:21:19.316 gmt: %ISDN-6-CONNECT: Interface Serial0/1/0:9 is now connected to 08701662801 N/A
005362: Apr 1 15:21:19.316 gmt: ISDN Se0/1/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x03FD
Rob
Hall of Fame Super Gold
Re: unavailable channel disconnect
Which exact IOS is this? You might need an upgrade and reload.
version is:
c2800nm-spservicesk9-mz.124-11.T4.bin
Rob
Hi, reading better, should not be an IOS issue but CM one. That could be proved by debug cch323 showing something going on after setup ack.
Unfortunately I'm not good at CM to suggest anything to check in there. Hope others can help.
Is the problem phone a newer generation phone and the working and older generation phone?
If so you may be running into the problem described in CSCsi61965. If this is the issue then modify the Enterprise Parameter 'Advertise G.722 Codec' by setting it to disable. Reset the problem phone and see if the call works. ou will then need to follow the steps in the defect and reset all of the newer phones.
Kevin
Kevin:
you may have something there....the non-working phone is a 7961, the others are 7960's.
I'll give it a try
thanks
Rob
Kevin:
It worked!
changed the g722 setting from default to disable on the non-working device
funny that the bug description does not talk about a straight call but it did the trick
thanks
Rob
251
