Community Member
Uncorrect working of tag <transfer> in VoiceXML
There are Cisco 2801, 4 FXO ports connect to PSTN, CME configured and connect to H323 VoIP network by Gatekeeper.
On Cisco 2801 working VoiceXML application:
<?xml version="1.0"?>
<vxml version="2.0" base="tftp://Ñ….Ñ….Ñ….Ñ…/ivr.vxml">
<form id="main">
<property name="timeout" value="10s"/>
<transfer name="mycall" dest="phone://7373" bridge="true"/>
Dial-peers on Cisco 2801 are following:
dial-peer voice 1 pots
destination-pattern .T
port 0/0/0
dial-peer voice 2 pots
port 0/0/1
dial-peer voice 3 pots
port 0/0/2
dial-peer voice 4 pots
port 0/0/3
dial-peer voice 7000 voip
destination-pattern 7[0-34679]..
session target ras
codec g711ulaw
dial-peer voice 7667 voip
service ivr
incoming called-number 7667
codec g711ulaw
Trouble: VXML transfer to internal number 7373 by gatekeepr and to other numbers, beginning with 7 routed to POTS dial-peers (1,2,3,4) , but not to dial-peer 7000. Why? Help me, please.
Re: Uncorrect working of tag <transfer> in VoiceXML
IOS doesn't route based on closest match, it just goes with the first match. You might try adding pref 1 to all the POTS dial peers, that way the voip dial peers with the default preference of 0 will be first choice. Having the .T changed to a ....T might work as well, it just depends on your entire dialplan and what works for your situation.
Community Member
This tips don't work. Construction voice service voip
resolved my trouble
Thanks a lot off for help. Please close topic.
