Understanding codec negotiation
I am using G.711 with UCM 6.1, we also have a SIP trunk where telco requires us to use G.729r8. I was doing some packet captures and I noticed all inbound/outbound pstn calls are G.711. The voice class codec on the router only contains the 729 codec. I understand these calls are being transcoded on the gateway, but i don't understand how G.711 is negotiated instead of G.729
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 2 priority 1 version 4.1
sccp ccm 10.1.1.2 identifier 1 priority 2 version 4.1
sccp ip precedence 3
sccp
sccp ccm group 10
bind interface Loopback0
associate ccm 1 priority 2
associate ccm 2 priority 1
associate profile 10 register MTP002155e68541
associate profile 20 register CON002155e68541
associate profile 30 register XCO002155e68541
keepalive retries 2
keepalive timeout 2
switchover method immediate
switchback method graceful
switchback interval 5
dspfarm profile 30 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 24
associate application SCCP
voice class codec 1
codec preference 1 g729r8
dial-peer voice 100 voip
preference 1
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target sip-server
incoming called-number 90855512..
dtmf-relay rtp-nte digit-drop
fax protocol pass-through g711ulaw
no vad
dial-peer voice 200 voip
preference 1
destination-pattern 90855512..
progress_ind setup enable 3
voice-class codec 1
session target ipv4:10.1.1.1
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
Re: Understanding codec negotiation
Those dial peers will not use anything except g729r8. (You could have accomplished the same thing by not putting anything on the dial peer at all.)
My best guess is one of two things:
1) You have a transcoder in CUCM somewhere else that's transcoding. This is less likely because a phone in a g711 region talking to a g729 region will just use g729 since it's a native codec.
2) You're not hitting the dial peers you're expecting to. 'debug voip dialpeer' may clarify. If you see dial peer 0, it means that dial peer is advertising every codec.
-nick
I tried doing some debugs on the dial peers and I am getting predictable results with hitting the dial peers, but I am still seeing G711 on PSTN calls from the VoIP phones. I setup a test where I made 10 calls from the PSTN to one of my internal extensions. On 8 of the calls the codec was G711 and twice it was G729, even though the dial peers matched were the same each time. I can see that when G711 is the codec the UBE router is transcoding; I can see that with the "show dspfarm dsp active" command. I am just not understanding the arbitrary nature of the codec selection.
Try changing your dspfarm profile 30 to:
codec g729r8
codec g729ar8
codec g729abr8
codec g711ulaw
codec g711alaw
maximum sessions 24
I believe this is what I did to correct the same issue at our sites.
Hope it helps!
509
