Understanding CUCM trace
Hi All,
I have doubts in reference to understand the CUCM trace (Cisco callmanager, h245 and h225) in order to see what is the reason my call is getting fast busy thru a H323 trunk with an Avaya Gateway. So basically I have a route parttern pointed to this route group/gateway where I need to know the ISDN or h225 release cause of the call, if this call has been deliveried or not to the end point.
I know how active the trace, but I am not too familiar with the trace.
Please suggest
Andres
1 REPLY
Re: Understanding CUCM trace
If you're not familiar with CUCM traces try using VLT (available at download center) or open a TAC case
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
533
