08-31-2017 07:10 PM - edited 03-17-2019 11:05 AM
Greeting SIP Experts,
I am testing SIP Trunking and having some issues with outboud calls. I get a fastbusy after dialing the called number. Please find attached
CUCM version 10.5
ISR 4431 with IOS Version 15.4(3)S4
Calling Number: 6132604849
Called Number: 5146027093
CUBE1# show call leg active summary
G<id> L<id> Elog A/O FAX T<sec> Codec type Peer Address IP R<ip>:<udp>
G0 L 950 N ANS T0 g711ulaw VOIP P6132604848 10.9.0.15:25612
G0 L 951 N ORG T0 g711ulaw VOIP P5146027093 0.0.0.0:0
Total call-legs: 2
Here's the output of debug ccsip messages:
CUBE1#
Aug 31 20:26:56.958: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:5146027093@192.168.2.179:5060 SIP/2.0
Via: SIP/2.0/UDP 10.9.0.14:5060;branch=z9hG4bK416af38314cf8
From: "SIP Trunk Test Phone2" <sip:6132604849@10.9.0.14>;tag=11142103~c95be849-4c79-4ab9-b071-5968a9cb676e-73377700
To: <sip:5146027093@192.168.2.179>
Date: Thu, 31 Aug 2017 20:26:56 GMT
Call-ID: ba412d80-9a817110-208f3-e00090a@10.9.0.14
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM10.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:10.9.0.14:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 3124833664-0000065536-0000000084-0234883338
Session-Expires: 1800
P-Asserted-Identity: "SIP Trunk Test Phone2" <sip:6132604849@10.9.0.14>
Remote-Party-ID: "SIP Trunk Test Phone2" <sip:6132604849@10.9.0.14>;party=calling;screen=yes;privacy=off
Contact: <sip:6132604849@10.9.0.14:5060>
Max-Forwards: 70
Content-Type: application/sdp
Content-Length: 198
v=0
o=CiscoSystemsCCM-SIP 11142103 1 IN IP4 10.9.0.14
s=SIP Call
c=IN IP4 10.9.0.15
t=0 0
m=audio 25380 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Aug 31 20:26:56.965: //536/BA412D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.4.3.S4
Content-Length: 0
Aug 31 20:26:56.965: //537/BA412D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:5146027093@207.236.237.219:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.64.199:5060;branch=z9hG4bK677F0
From: "SIP Trunk Test Phone2" <sip:6132604849@10.0.64.199>;tag=46B5EF-2B0
To: <sip:5146027093@207.236.237.219>
Call-ID: 91A27DE2-8DC111E7-82F5B590-170175E8@10.0.64.199
Supported: 100rel,timer,resource-priority,replaces,histinfo,sdp-anat
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-15.4.3.S4
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1504211216
Contact: <sip:6132604849@10.0.64.199:5060>
History-Info: <sip:5146027093@207.236.237.219:5060>;index=1
Expires: 1800
Max-Forwards: 69
P-Asserted-Identity: "SIP Trunk Test Phone2" <sip:6132604849@10.0.64.199>
Privacy: none
Content-Disposition: session;handling=required
Content-Length: 293
v=0
o=CiscoSystemsSIP-GW-UserAgent 3526 3573 IN IP4 10.0.64.199
s=SIP Call
c=IN IP4 10.0.64.199
t=0 0
m=audio 16654 RTP/AVP 0 100 101
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Aug 31 20:26:57.466: //537/BA412D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 31 Aug 2017 20:26:57 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1504211217
Expires: 1800
Max-Forwards: 69
Privacy: none
Content-Length: 293
v=0
s=SIP Call
t=0 0
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Aug 31 20:26:58.466: //537/BA412D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 31 Aug 2017 20:26:58 GMT
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1504211218
Expires: 1800
Max-Forwards: 69
Privacy: none
Content-Length: 293
v=0
s=SIP Call
t=0 0
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Aug 31 20:27:00.404: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:customer7.lab.internetvoice.ca:5060 SIP/2.0
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bKqi518e301g2ovnqogpd0
Call-ID: 801c0c444d37afd1c271c092988c5fbf000o6p1@207.236.237.219
To: sip:ping@customer7.lab.internetvoice.ca
From: <sip:ping@207.236.237.219>;tag=45d0b0b387ff2df15e3d69b8ebeb1278000o6p1
Max-Forwards: 0
CSeq: 27762 OPTIONS
Route: <sip:192.197.135.179:5060;lr>
Aug 31 20:27:00.406: //538/93AF8D7282F6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=46C360-1E76
Date: Thu, 31 Aug 2017 20:27:00 GMT
CSeq: 27762 OPTIONS
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 178
v=0
o=CiscoSystemsSIP-GW-UserAgent 4284 5971 IN IP4 192.197.135.179
s=SIP Call
c=IN IP4 192.197.135.179
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
Aug 31 20:27:00.470: //539/BA412D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:5146027093@10.89.0.3:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.2.179:5060;branch=z9hG4bK68201B
From: "SIP Trunk Test Phone2" <sip:6132604849@192.168.2.179>;tag=46C3A0-55A
To: <sip:5146027093@10.89.0.3>
Call-ID: 93B95122-8DC111E7-82F8B590-170175E8@192.168.2.179
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1504211220
Contact: <sip:6132604849@192.168.2.179:5060>
History-Info: <sip:5146027093@10.89.0.3:5060>;index=1
Expires: 1800
Max-Forwards: 69
P-Asserted-Identity: "SIP Trunk Test Phone2" <sip:6132604849@192.168.2.179>
Privacy: none
Content-Length: 297
v=0
o=CiscoSystemsSIP-GW-UserAgent 646 817 IN IP4 192.168.2.179
s=SIP Call
c=IN IP4 192.168.2.179
t=0 0
m=audio 16656 RTP/AVP 0 100 101
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Aug 31 20:27:00.472: //539/BA412D800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Aug 31 20:27:00.473: //539/BA412D800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not Found
To: <sip:5146027093@10.89.0.3>;tag=13665636~c95be849-4c79-4ab9-b071-5968a9cb676e-89900165
CSeq: 101 INVITE
Reason: Q.850;cause=1
Server: Cisco-CUCM10.5
Content-Length: 0
Aug 31 20:27:00.478: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:5146027093@10.89.0.3:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Privacy: none
Content-Length: 0
Aug 31 20:27:00.478: //540/BA412D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:5146027093@10.9.0.15:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.2.179:5060;branch=z9hG4bK692E0
From: "SIP Trunk Test Phone2" <sip:6132604849@192.168.2.179>;tag=46C3A8-2529
To: <sip:5146027093@10.9.0.15>
Call-ID: 93BA62B5-8DC111E7-82FAB590-170175E8@192.168.2.179
Min-SE: 1800
CSeq: 101 INVITE
History-Info: <sip:5146027093@10.9.0.15:5060>;index=1
Expires: 1800
Max-Forwards: 69
Privacy: none
Content-Length: 299
v=0
o=CiscoSystemsSIP-GW-UserAgent 7216 4338 IN IP4 192.168.2.179
s=SIP Call
t=0 0
m=audio 16658 RTP/AVP 0 100 101
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Aug 31 20:27:00.480: //540/BA412D800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 503 Service Unavailable
To: <sip:5146027093@10.9.0.15>;tag=164410014
CSeq: 101 INVITE
Warning: 399 SCCM50005P "Unable to find a device handler for the request received on port 5060 from 192.168.2.179"
Content-Length: 0
Aug 31 20:27:00.482: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:5146027093@10.9.0.15:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Privacy: none
Content-Length: 0
Aug 31 20:27:00.483: //536/BA412D800000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:5146027093@192.168.2.179>;tag=46C3AD-57E
CSeq: 101 INVITE
Reason: Q.850;cause=38
Content-Length: 0
Aug 31 20:27:00.484: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:5146027093@192.168.2.179:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
08-31-2017 08:57 PM
08-31-2017 11:31 PM
From the logs your ITSP is not responding to your invite. One possible reason is that they may not be able to connect to you in this IP
10.0.64.199..
This is the IP in your via header and that's where responses will be sent to.
You may need to apply sip bind statement to originate traffic to your ITSP on the correct interface from the CUBE
09-01-2017 08:56 AM
Thanks guys,
10.0.64.199 is my Loopback0 IP address. This IP is not visible by the provider. The only visible address by ITSP is the GigabitEthernet0/0/1 which has 192.197.135.179. When I bind the loopback address to the outbound dialpeer (dial-peer 200 in my case) , I can see the call gets into the CUBE but fails to connect to ITSP. As soon as I bind the outbound dial peer to interface GigabitEthernet0/0/1 which is visible by the ITSP the call doesn't even reach the CUBE and I hear a fastbusy.
sbc1#show call leg active summary
Total call-legs: 0
The Digit Analyzer shows that the call hits the CUBE via lq 500-sbc1.tel.loto-quebec.com trunk.
The trunk from CUCM to CUBE is pointed to interface GigabitEthernet0/0/0 which is visible by CUCM but not by the ITSP. As mentionned the only reachable interface by the ITSP is the GigabitEthernet0/0/1.
Here's the output of the debug ccsip all:
Sep 1 15:53:41.916: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x7F0BF96A8AF0 with refCount = 1
Sep 1 15:53:41.916: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x7F0C0841C360 with refCount = 1
Sep 1 15:53:41.916: //-1/xxxxxxxxxxxx/SIP/Error/get_content_length:
Could not get Content-length
Sep 1 15:53:41.916: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [207.236.237.219]:5060, local_address:[ - ]
Sep 1 15:53:41.916: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x7F0BF96A8AF0
Sep 1 15:53:41.916: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Sep 1 15:53:41.916: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
Sep 1 15:53:41.916: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bKg65ct700eon80oae6tp0
Call-ID: e9792f334cdce2addf1bcdbff7aa5037000eo33@207.236.237.219
From: <sip:ping@207.236.237.219>;tag=17b39f1ea40becb933fdb265569c76c1000eo33
Max-Forwards: 0
CSeq: 34759 OPTIONS
Sep 1 15:53:41.916: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/ccsip_new_msg_preprocessor: Checking Invite Dialog
Sep 1 15:53:41.916: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x7F0C074478C8) with key=[7576] to table
Sep 1 15:53:41.916: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Sep 1 15:53:41.917: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Sep 1 15:53:41.917: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Sep 1 15:53:41.917: //-1/000000000000/SIP/Info/verbose/4097/ccsip_platform_init_ccb: Initialising rtp session queue
Sep 1 15:53:41.917: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 207.236.237.219,Port 5060, Transport 1, SentBy Port 5060vrfid 0
Sep 1 15:53:41.917: //-1/000000000000/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
Sep 1 15:53:41.917: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 192.197.135.179 for SIP
Sep 1 15:53:41.917: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 192.197.135.179
Sep 1 15:53:41.917: //-1/8FD69AA79EB8/SIP/State/sipSPIChangeState: 0x7F0C074478C8 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Sep 1 15:53:41.917: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 207.236.237.219,Port 5060, Transport 1, SentBy Port 5060vrfid 0
Sep 1 15:53:41.917: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPISetDateHeader: Converting TimeZone EDT to SIP default timezone = GMT
Sep 1 15:53:41.917: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_lock: Increment msg (0x7F0C0841C360) counter, current msg->refCount = 2
Sep 1 15:53:41.917: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
Sep 1 15:53:41.917: //7576/8FD69AA79EB8/SIP/Info/info/1024/ccsipInitPldCallingInfo: non-numeric calling number: ping
Sep 1 15:53:41.917: //7576/8FD69AA79EB8/SIP/Info/verbose/1024/sipSPIGetViaHostInURLFormat: VIA URL:sip:207.236.237.219:5060, Host:207.236.237.219
Sep 1 15:53:41.917: //7576/8FD69AA79EB8/SIP/Info/verbose/67584/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : ping
Sep 1 15:53:41.917: //7576/8FD69AA79EB8/SIP/Error/sipSPIGetPeerByCalledPartyId:
input arg error
Sep 1 15:53:41.917: //7576/8FD69AA79EB8/SIP/Info/critical/10240/sipSPIGetCallConfig: No match found for P-Called-Party-ID
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Error/sipSPIUpdateCallInfo:
input argument error
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/verbose/1024/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/verbose/2048/sipSPIGetCallConfig: Media Antitrombone disabled
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/8192/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/2304/sipSPISetMediaFlowMode: xcoder high-density disabled
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/8192/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/10240/sipSPIGetCallConfig: Non dial peer leg - using RTP Supported Codecs
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 18
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 0
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 8
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 9
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 4
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 2
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 15
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/10240/sipSPIGetCallConfig: RTP Preferred Codecs supported by GW 3
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/critical/32768/ccsip_ipip_media_forking_update_preferred_codec: MF: Not a Forked SIP leg..
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/verbose/12288/sipSPIGetModemInfoPerCall: peer_callID=0
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/8192/sipSPIGetModemConfig:
From Config: Modem NSE payload = 100, Passthrough = 4, Modem relay = 0, Gw-Xid = 1
SPRT latency 200, SPRT Retries = 12, Dict Size = 1024
String Len = 32, Compress dir = 3
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Error/ccsip_ipip_media_forking_anchor_leg_config:
MF: Dial-peer is absent..
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/36864/sipSPIMFChangeState: MF: Prev state = 0 & New state = -1
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/32768/ccsip_ipip_media_forking_anchor_leg_reset: MF: Anchor leg config reset done...
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Error/ccsip_ipip_media_forking_intra_frame_request_config:
MF:video profile Dial-peer is absent..
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/verbose/8192/sipSPICheckFAAnatAssymetricOrDO2EO: Not a SIP-SIP call or not in FA mode
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/2049/populate_vcc_data: Non dial peer leg - using RTP Supported Codecs
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 18
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 0
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 8
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 9
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 4
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 2
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 15
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/1/populate_vcc_data: RTP Preferred Codecs supported by GW 3
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/notify/8192/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/verbose/10240/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/verbose/2048/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/notify/10240/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
Sep 1 15:53:41.918: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Decrement msg (0x7F0C0841C360) counter, current msg->refCount = 1
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/notify/6/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Sep 1 15:53:41.918: //7576/8FD69AA79EB8/SIP/Info/verbose/513/resolve_media_ip_address_to_bind: peer_tag=0
Sep 1 15:53:41.918: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_media_ip_address_to_bind: VRF id = 0
Sep 1 15:53:41.918: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_media_ip_address_to_bind: ip_best_local_address 192.197.135.179 for SIP
Sep 1 15:53:41.918: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_media_ip_address_to_bind: return addr 192.197.135.179
Sep 1 15:53:41.919: //7576/8FD69AA79EB8/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.197.135.179
Sep 1 15:53:41.919: //7576/8FD69AA79EB8/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: VRF id = 0
Sep 1 15:53:41.919: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: ip_best_local_address 192.197.135.179 for SIP
Sep 1 15:53:41.919: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/resolve_sig_ip_address_to_bind: return addr 192.197.135.179
Sep 1 15:53:41.919: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
Sep 1 15:53:41.919: //7576/8FD69AA79EB8/SIP/Info/info/4096/sact_idle_new_message_options: ccsip_api_options_ind returned: SIP_SUCCESS
Sep 1 15:53:41.919: //7576/8FD69AA79EB8/SIP/State/sipSPIChangeState: 0x7F0C074478C8 : State change from (STATE_IDLE, SUBSTATE_NONE) to (SIP_STATE_OPTIONS_WAIT, SUBSTATE_NONE)
Sep 1 15:53:41.919: //7576/8FD69AA79EB8/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x7F0C074478C8 key=e9792f334cdce2addf1bcdbff7aa5037000eo33@207.236.237.219 balance 0
Sep 1 15:53:41.919: //7576/8FD69AA79EB8/SIP/Info/verbose/4096/sipSPIUaddccCallIdToTable: Adding call id 1D98 to table
Sep 1 15:53:41.919: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 38
Sep 1 15:53:41.919: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_create: created msg=0x7F0BF96A8AF0 with refCount = 1
Sep 1 15:53:41.919: //7576/8FD69AA79EB8/SIP/Info/info/4096/sipSPISendOptionsResponse: Associated container=0x7F0BF20824C0 to Options Response
Sep 1 15:53:41.919: //-1/xxxxxxxxxxxx/SIP/Info/verbose/8192/sipSPIAppHandleContainerBody: sipSPIAppHandleContainerBody len 178
Sep 1 15:53:41.919: //7576/8FD69AA79EB8/SIP/Transport/sipSPITransportSendMessage: msg=0x7F0BF96A8AF0, addr=207.236.237.219, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x7F0C609BAE00
Sep 1 15:53:41.919: //7576/8FD69AA79EB8/SIP/Info/info/2048/sipSPIGetExtensionCfg: SIP extension config:1, check sys cfg:1
Sep 1 15:53:41.919: //7576/8FD69AA79EB8/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Sep 1 15:53:41.919: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportLogicSendMsg: connection-reuse configured, listen conn-id : 0
Sep 1 15:53:41.919: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x7F0BF96A8AF0, addr=207.236.237.219, port=5060, local_addr=, connId=0 vrfid=0 for UDP
Sep 1 15:53:41.920: //7576/8FD69AA79EB8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=472E6C8-887
Date: Fri, 01 Sep 2017 15:53:41 GMT
CSeq: 34759 OPTIONS
Content-Length: 178
v=0
o=CiscoSystemsSIP-GW-UserAgent 9638 5534 IN IP4 192.197.135.179
s=SIP Call
t=0 0
Sep 1 15:53:41.920: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x7F0BF96A8AF0
Sep 1 15:53:43.914: //7573/7DF45B7F9EB5/SIP/Info/verbose/4096/sipSPIUdeleteccCallIdFromTable: Removing call id 1D95
Sep 1 15:53:43.914: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[7573] removed.
Sep 1 15:53:43.914: //7573/7DF45B7F9EB5/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x7F0C07455F58 key=e9792f334cdce2addf1bcdbff7aa5037000e823@207.236.237.219
Sep 1 15:53:43.914: //-1/xxxxxxxxxxxx/SIP/Info/info/1024/httpish_msg_free: Freed msg=0x7F0BFC668100
Sep 1 15:53:43.914: //7573/7DF45B7F9EB5/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Sep 1 15:53:43.914: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerUnregisterCtxtInConnection: gConnTab=0x7F0BF8A58690, addr=207.236.237.219, port=5060, local_addr=, unregistering context=0x7F0C07455F58
Sep 1 15:53:43.914: //-1/xxxxxxxxxxxx/SIP/Info/critical/512/sipConnectionManagerUnregisterCtxtInConnection: Could not find conn holder for addr=207.236.237.219
Sep 1 15:53:43.914: //7573/7DF45B7F9EB5/SIP/Transport/sipSPITransportContextCleanup: Could not purge context gcb=0x7F0C07455F58 from the connection; gcb might be locked
Sep 1 15:53:43.914: //7573/7DF45B7F9EB5/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Sep 1 15:53:43.914: //7573/7DF45B7F9EB5/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
Sep 1 15:53:43.914: //7573/7DF45B7F9EB5/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x7F0C07455F58
09-01-2017 02:30 PM
Do you guys see any issues with the config of the CUBE?
MK
09-03-2017 10:57 AM
Can someone please look at the CUB config and let me know if I am missing anything?
MK
09-04-2017 07:03 AM
Mighty King,
Looking at your configs I dont see your correct sip bind statements.
Also from the last logs you attached I dont see the cvall hitting the gateway as you said.
Here are the things to do.
1. Create an inbound dial-peer for calls coming from CUCM ( I can see that you are using incoming called number .) You cant do this in this case because you need to apply different bind statementes to the interface that connects to BELL and CUCM
So create a new inbound dial-peer fro calls coming in from CUCM. Apply the correct sip bind matching the interface that is local to CUCM
2. Create a new inbound dial-peer for calls coming in from BELL ( be more specific, dont use incoming called number .) apply the correct sip bind using the interface that is reachabe to/from BELL
3. If calls are not hitting your gateway after changing the sip bind statement, you need to change the ip address of your SIP trunk to that matching the interface local to CUCM which you used for binding sip traffic in step 1 above
4. Ensure that you have run on all active cm node on your sip trunk and use server-group to assing all your cucm nodes. Then create dial-peers that sends calls to the server-group in the order of your preference
5. Once you have done all these, reset your sip trunk, verify that your sip trunk is up and then place a test call. If it still fails, then send only "debug ccsip mess"
09-04-2017 07:09 PM
Hi Ayodeji
Your reply is very much apprciated.
I modified the config to match what you posted. The debug shows there's no matching outgoing Dial peer while the show dialplan displays the matching dialpeers. I have two outgoing dialpeers which match 95146027093 and 5146027093. Please find attached the new running config.
sbc1# show ip interface brief
Interface IP-Address
GigabitEthernet0/0/0 192.168.2.179 This interface is used btw CUCM and CUBE
GigabitEthernet0/0/1 192.197.135.179 This interface is used btw CUBE and the Provider
sbc1#show dialplan number 95146027093
Macro Exp.: 95146027093
VoiceOverIpPeer207
peer type = voice, system default peer = FALSE, information type = voice,
description = `WAN Outgoing local Calls to Bell',
tag = 207, destination-pattern = `95146027093',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
rtp-ssrc mux = system
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 207, Admin state is up, Operation state is up,
incoming called-number = `',
connections/maximum = 0/unlimited,
bandwidth/maximum = 0/unlimited,
DTMF Relay = enabled,
modem transport = system,
URI classes:
Incoming (Request) =
Incoming (Via) =
Incoming (To) =
Incoming (From) =
Destination (Diversion) =
Destination (From) =
Destination (Referred-By) =
Destination (To) =
Destination (Via) =
Destination =
Destination route-string = None
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
outgoing LPCOR:
Translation profile (Incoming):
Translation profile (Outgoing):Bahman_outbound
sbc1#show dialplan number 5146027093
Macro Exp.: 5146027093
VoiceOverIpPeer201
tag = 201, destination-pattern = `5146027093',
allow watch = FALSE
group = 201, Admin state is up, Operation state is up,
URI classes:
Incoming (Via) =
Incoming (To) =
Incoming (From) =
Destination (To) =
Destination (Via) =
Destination =
dnis-map =
permission :both
outgoing LPCOR:
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 0 oldAddrFamily 0
mailbox selection policy: none
type = voip, session-target = `ipv4:207.236.237.219:5060',
technology prefix:
settle-call = disabled
*Sep 5 01:16:37.120: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bKs6c7at304o8cdolb1ei0
Call-ID: e8405d9e01bf67f433e2c9cd204e68a9000kf50@207.236.237.219
From: <sip:ping@207.236.237.219>;tag=215f9e2ba2086b11b221d5c1f9a1f1a6000kf50
Max-Forwards: 0
CSeq: 64010 OPTIONS
*Sep 5 01:16:37.122: //256/B2AAFE4E810C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=125C1F-321
Date: Tue, 05 Sep 2017 01:16:37 GMT
CSeq: 64010 OPTIONS
Content-Length: 178
v=0
o=CiscoSystemsSIP-GW-UserAgent 3957 8137 IN IP4 192.197.135.179
s=SIP Call
t=0 0
*Sep 5 01:16:46.568: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.14:5060;branch=z9hG4bK47964e8729d1
From: "" <sip:6132604849@10.9.0.14>;tag=14538844~c95be849-4c79-4ab9-b071-5968a9cb676e-73444127
Date: Tue, 05 Sep 2017 01:16:46 GMT
Call-ID: e1279880-9ad1fafe-242aa-e00090a@10.9.0.14
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Cisco-Guid: 3777468544-0000065536-0000000123-0234883338
P-Asserted-Identity: "" <sip:6132604849@10.9.0.14>
Remote-Party-ID: "" <sip:6132604849@10.9.0.14>;party=calling;screen=yes;privacy=off
Max-Forwards: 69
Content-Length: 0
*Sep 5 01:16:46.574: //257/E12798800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
*Sep 5 01:16:46.575: //258/E12798800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.197.135.179:5060;branch=z9hG4bK5170D
From: "" <sip:6132604849@192.197.135.179>;tag=12810C-13CB
Call-ID: B84D4094-910E11E7-81129A45-2D45614B@192.197.135.179
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1504574206
Contact: <sip:6132604849@192.197.135.179:5060>
Expires: 1800
Max-Forwards: 68
P-Asserted-Identity: "" <sip:6132604849@192.197.135.179>
Privacy: none
Content-Length: 351
v=0
o=CiscoSystemsSIP-GW-UserAgent 8723 158 IN IP4 192.197.135.179
s=SIP Call
t=0 0
m=audio 16398 RTP/AVP 0 18 100 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:100 192-194
a=fmtp:101 0-16
a=ptime:20
*Sep 5 01:16:46.588: //258/E12798800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
*Sep 5 01:16:46.592: //258/E12798800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not found
To: <sip:5146027093@207.236.237.219>;tag=1580743609-1504574209532
CSeq: 101 INVITE
Reason: Q.850;text="User not Found";cause=1
Content-Length: 0
*Sep 5 01:16:46.595: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:5146027093@207.236.237.219:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Privacy: none
Content-Length: 0
*Sep 5 01:16:46.595: //257/E12798800000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:5146027093@192.168.2.179>;tag=128120-B12
CSeq: 101 INVITE
Warning: 399 192.168.2.179 "No matching outgoing dial-peer"
Content-Length: 0
*Sep 5 01:16:46.596: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Sep 5 01:16:47.120: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bKlnu11s3040astjep62g0
Call-ID: e8405d9e01bf67f433e2c9cd204e68a9000kv50@207.236.237.219
From: <sip:ping@207.236.237.219>;tag=215f9e2ba2086b11b221d5c1f9a1f1a6000kv50
Max-Forwards: 0
CSeq: 64011 OPTIONS
*Sep 5 01:16:47.122: //259/B8A0B8918113/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=12832E-103E
Date: Tue, 05 Sep 2017 01:16:47 GMT
CSeq: 64011 OPTIONS
Content-Length: 177
v=0
o=CiscoSystemsSIP-GW-UserAgent 642 6834 IN IP4 192.197.135.179
s=SIP Call
t=0 0
*Sep 5 01:16:57.121: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bK201cal1048bqn6es2om0
Call-ID: e8405d9e01bf67f433e2c9cd204e68a9000kf60@207.236.237.219
From: <sip:ping@207.236.237.219>;tag=215f9e2ba2086b11b221d5c1f9a1f1a6000kf60
Max-Forwards: 0
CSeq: 64012 OPTIONS
*Sep 5 01:16:57.123: //260/BE96E7A58114/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=12AA40-1F1B
Date: Tue, 05 Sep 2017 01:16:57 GMT
CSeq: 64012 OPTIONS
Content-Length: 178
v=0
o=CiscoSystemsSIP-GW-UserAgent 2215 1165 IN IP4 192.197.135.179
s=SIP Call
t=0 0
MK
09-05-2017 12:29 AM
MK,
The call is matching the correct dial-peer and BELL is responding, however BELL is rejecting the call with 404 not found. This generally means that the dialled number is incorrect. Looks like you need to send more digits to BELL to complete this call.
++ Here is the INVITE to BELL ++
Sent:
++ Here is the trying from BELL ++
Received:
SIP/2.0 100 Trying
++ Here is the 404 not found ++
Received:
09-05-2017 11:21 AM
Thank your very much for taking the time and replying. I had to play with headers to match what provider was expecting to receive. Now the inbound and outbound calls can be received and the phones ring but there's no audio. The call terminates after 5 seconds from being answered. I tried to engage the MTP in the trunk configuration page but no luck. Here's the debug for an outbound call:
sbc1#debug ccsip mess
SIP Call messages tracing is enabled
sbc1#
Sep 5 18:13:41.280: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.14:5060;branch=z9hG4bK4d12914365f91
From: "SIP Trunk Test Phone1" <sip:6132604848@10.9.0.14>;tag=15128771~c95be849-4c79-4ab9-b071-5968a9cb676e-73466532
Date: Tue, 05 Sep 2017 18:13:41 GMT
Call-ID: f0edbe00-9ae1e955-27090-e00090a@10.9.0.14
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Cisco-Guid: 4042112512-0000065536-0000000175-0234883338
P-Asserted-Identity: "SIP Trunk Test Phone1" <sip:6132604848@10.9.0.14>
Remote-Party-ID: "SIP Trunk Test Phone1" <sip:6132604848@10.9.0.14>;party=calling;screen=yes;privacy=off
Contact: <sip:6132604848@10.9.0.14:5060>
Max-Forwards: 69
Content-Length: 198
v=0
o=CiscoSystemsCCM-SIP 15128771 1 IN IP4 10.9.0.14
s=SIP Call
c=IN IP4 10.9.0.15
t=0 0
m=audio 27054 RTP/AVP 0 101
a=fmtp:101 0-15
Sep 5 18:13:41.288: //1408/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Sep 5 18:13:41.288: //1409/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:5146027093@siptrunking.bell.ca:5060 SIP/2.0
Via: SIP/2.0/UDP 192.197.135.179:5060;branch=z9hG4bK2F2472
From: "SIP Trunk Test Phone1" <sip:6132604848@lab.internetvoice.ca;user=phone>;tag=57400E-12BF
To: <sip:5146027093@siptrunking.bell.ca>
Call-ID: C7E79B9E-919C11E7-85D4A539-97E82138@lab.internetvoice.ca
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1504635221
Contact: <sip:6132604848;tgrp=CUST7_6132604848_01A;trunk-context=siptrunking.bell.ca@192.197.135.179:5060>
Expires: 1800
Max-Forwards: 68
P-Asserted-Identity: "SIP Trunk Test Phone1" <sip:6132604848@lab.internetvoice.ca;user=phone>
Privacy: none
Content-Length: 292
v=0
o=CiscoSystemsSIP-GW-UserAgent 178 5929 IN IP4 192.197.135.179
s=SIP Call
c=IN IP4 10.9.0.15
t=0 0
m=audio 27054 RTP/AVP 0 100 101
c=IN IP4 10.9.0.15
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Sep 5 18:13:41.299: //1409/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Sep 5 18:13:41.313: //1409/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
To: <sip:5146027093@siptrunking.bell.ca>;tag=937289300-1504635030156
CSeq: 101 INVITE
WWW-Authenticate: DIGEST qop="auth",nonce="BroadWorksXj77wujkcTn7mn2bBW",realm="siptrunking.bell.ca",algorithm=MD5
Content-Length: 0
Sep 5 18:13:41.314: //1409/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Sent:
From: "SIP Trunk Test Phone1" <sip:6132604848@lab.internetvoice.ca>;tag=57400E-12BF
Max-Forwards: 70
CSeq: 101 ACK
Privacy: none
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 192.197.135.179:5060;branch=z9hG4bK302421
Min-SE: 1800
CSeq: 102 INVITE
History-Info: <sip:5146027093@207.236.237.219:5060>;index=1,<sip:5146027093@207.236.237.219:5060>;index=2
Expires: 1800
Authorization: Digest username="CUST7_6132604848_01A",realm="siptrunking.bell.ca",uri="sip:5146027093@207.236.237.219:5060",response="eb5b595ba7c16b719daa0901465100d0",nonce="BroadWorksXj77wujkcTn7mn2bBW",cnonce="1F0EB659",qop=auth,algorithm=MD5,nc=00000001
Max-Forwards: 68
Privacy: none
Content-Length: 292
v=0
s=SIP Call
c=IN IP4 10.9.0.15
t=0 0
c=IN IP4 10.9.0.15
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Sep 5 18:13:41.327: //1409/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Sep 5 18:13:42.245: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bK0jk2kd20e0a7japn2si0
Call-ID: e23b80a7751d4cf5cd5fd5cf386c4e1c00080j0@207.236.237.219
From: <sip:ping@207.236.237.219>;tag=b0b1c7362ffeffb111d274242f8388f400080j0
Max-Forwards: 0
CSeq: 1062 OPTIONS
Sep 5 18:13:42.247: //1410/C879F0A085D5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=5743CD-C20
Date: Tue, 05 Sep 2017 18:13:42 GMT
CSeq: 1062 OPTIONS
Content-Length: 178
v=0
o=CiscoSystemsSIP-GW-UserAgent 8217 6898 IN IP4 192.197.135.179
s=SIP Call
t=0 0
Sep 5 18:13:43.349: //1409/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <sip:5146027093@siptrunking.bell.ca>;tag=1015722548-1504635032191
CSeq: 102 INVITE
Supported:
Contact: <sip:5146027093@207.236.237.219:5060;transport=udp>
Session: Media
RSeq: 698239295
Call-Info: <sip:172.17.25.90>;appearance-index=1
Require: 100rel
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Content-Length: 241
v=0
o=- 2166096403 1 IN IP4 207.236.237.219
s=-
c=IN IP4 207.236.237.219
t=0 0
m=audio 49186 RTP/AVP 0 101
a=fmtp:101 0-15
a=silenceSupp:off - - - -
a=maxptime:30
a=ptime:20
Sep 5 18:13:43.351: //1409/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:5146027093@207.236.237.219:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.197.135.179:5060;branch=z9hG4bK31F68
CSeq: 103 PRACK
RAck: 698239295 102 INVITE
Authorization: Digest username="CUST7_6132604848_01A",realm="siptrunking.bell.ca",uri="sip:5146027093@207.236.237.219:5060;transport=udp",response="932367adc78f8ce933a8a36801fa81c3",nonce="BroadWorksXj77wujkcTn7mn2bBW",cnonce="109495B3",qop=auth,algorithm=MD5,nc=00000002
Max-Forwards: 70
Privacy: none
Content-Length: 0
Sep 5 18:13:43.353: //1408/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:5146027093@192.168.2.179>;tag=57481F-1059
CSeq: 101 INVITE
Require: 100rel
RSeq: 7175
Contact: <sip:5146027093@192.168.2.179:5060>
Content-Length: 253
v=0
o=CiscoSystemsSIP-GW-UserAgent 2103 756 IN IP4 192.168.2.179
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Sep 5 18:13:43.355: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:5146027093@192.168.2.179:5060 SIP/2.0
Via: SIP/2.0/UDP 10.9.0.14:5060;branch=z9hG4bK4d12a528bd580
CSeq: 102 PRACK
RAck: 7175 101 INVITE
Max-Forwards: 70
Content-Length: 0
Sep 5 18:13:43.355: //1408/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Tue, 05 Sep 2017 18:13:43 GMT
CSeq: 102 PRACK
Content-Length: 0
Sep 5 18:13:43.369: //1409/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 PRACK
Content-Length: 0
Sep 5 18:13:44.313: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:192.168.2.179:5060 SIP/2.0
Via: SIP/2.0/UDP 10.57.0.11:5060;branch=z9hG4bK53c13989be54
To: <sip:192.168.2.179>
Date: Tue, 05 Sep 2017 18:13:44 GMT
Call-ID: f2b78180-9ae1e958-2295-b00390a@10.57.0.11
CSeq: 101 OPTIONS
Contact: <sip:10.57.0.11:5060>
Max-Forwards: 0
Content-Length: 0
Sep 5 18:13:44.315: //1411/C9B57D7885D6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=574BE1-16BC
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 6061 2018 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 5 18:13:45.751: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.15:5060;branch=z9hG4bK823eb80631db
Date: Tue, 05 Sep 2017 18:13:45 GMT
Call-ID: f3501800-9ae1e959-2b873-f00090a@10.9.0.15
CSeq: 101 OPTIONS
Contact: <sip:10.9.0.15:5060>
Max-Forwards: 0
Content-Length: 0
Sep 5 18:13:45.753: //1412/CA910FF085D7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=57517F-5E8
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 8233 3773 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 5 18:13:46.761: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.89.0.3:5060;branch=z9hG4bK4c74b526503
Date: Tue, 05 Sep 2017 18:13:46 GMT
Call-ID: f3e8ae80-9ae1e95a-4b9-300590a@10.89.0.3
CSeq: 101 OPTIONS
Contact: <sip:10.89.0.3:5060>
Max-Forwards: 0
Content-Length: 0
Sep 5 18:13:46.763: //1413/CB2B2CD485D8/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=575571-1472
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 6854 3218 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 5 18:13:47.773: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.49.0.9:5060;branch=z9hG4bK162b3b74797b
Date: Tue, 05 Sep 2017 18:13:47 GMT
Call-ID: f4814500-9ae1e95b-afc-900310a@10.49.0.9
CSeq: 101 OPTIONS
Contact: <sip:10.49.0.9:5060>
Max-Forwards: 0
Content-Length: 0
Sep 5 18:13:47.774: //1414/CBC5710E85D9/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=575964-261C
CSeq: 101 OPTIONS
Content-Length: 171
v=0
o=CiscoSystemsSIP-GW-UserAgent 776 2714 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 5 18:13:49.817: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.57.0.10:5060;branch=z9hG4bK465b14b62f6a
Date: Tue, 05 Sep 2017 18:13:49 GMT
Call-ID: f5b27200-9ae1e95d-379a-a00390a@10.57.0.10
CSeq: 101 OPTIONS
Contact: <sip:10.57.0.10:5060>
Max-Forwards: 0
Content-Length: 0
Sep 5 18:13:49.819: //1415/CCFD7BB485DA/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=576161-1D04
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 3858 2759 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 5 18:13:50.366: //1409/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported:
Accept: application/media_control+xml,application/sdp
Content-Length: 241
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=maxptime:30
a=ptime:20
Sep 5 18:13:50.369: //1409/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.197.135.179:5060;branch=z9hG4bK32116D
Max-Forwards: 70
CSeq: 102 ACK
Privacy: none
Content-Length: 0
Sep 5 18:13:50.369: //1408/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Session-Expires: 1800;refresher=uac
Require: timer
Supported: timer
Content-Length: 253
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Sep 5 18:13:50.371: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.14:5060;branch=z9hG4bK4d1344d200a9d
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sep 5 18:13:51.514: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.25.0.8:5060;branch=z9hG4bK4144d9928d3
Date: Tue, 05 Sep 2017 18:13:51 GMT
Call-ID: f6e39f00-9ae1e95f-415-800190a@10.25.0.8
CSeq: 101 OPTIONS
Contact: <sip:10.25.0.8:5060>
Max-Forwards: 0
Content-Length: 0
Sep 5 18:13:51.515: //1416/CE00464985DB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=576801-C2B
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 7799 7871 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 5 18:13:52.185: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.25.0.7:5060;branch=z9hG4bK52211f5c9b37
Date: Tue, 05 Sep 2017 18:13:52 GMT
Call-ID: f77c3580-9ae1e960-1bb7-700190a@10.25.0.7
CSeq: 101 OPTIONS
Contact: <sip:10.25.0.7:5060>
Max-Forwards: 0
Content-Length: 0
Sep 5 18:13:52.187: //1417/CE66AA1785DC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=576AA1-1D63
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 6034 6378 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 5 18:13:52.245: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bKh3i1gn20e0bl67p5fri0
Call-ID: e23b80a7751d4cf5cd5fd5cf386c4e1c0008gj0@207.236.237.219
From: <sip:ping@207.236.237.219>;tag=b0b1c7362ffeffb111d274242f8388f40008gj0
Max-Forwards: 0
CSeq: 1063 OPTIONS
Sep 5 18:13:52.247: //1418/CE6FD1A085DD/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=576ADD-DEE
CSeq: 1063 OPTIONS
Content-Length: 178
v=0
o=CiscoSystemsSIP-GW-UserAgent 9705 6226 IN IP4 192.197.135.179
s=SIP Call
t=0 0
Sep 5 18:13:53.299: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.14:5060;branch=z9hG4bK4d135285fcd85
Date: Tue, 05 Sep 2017 18:13:53 GMT
Call-ID: f814cc00-9ae1e961-27094-e00090a@10.9.0.14
CSeq: 101 OPTIONS
Contact: <sip:10.9.0.14:5060>
Max-Forwards: 0
Content-Length: 0
Sep 5 18:13:53.300: //1419/CF10A56D85DE/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=576EFB-6CD
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 5582 7897 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 5 18:13:53.648: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.5:5060;branch=z9hG4bK41ad47e778896
Call-ID: f814cc00-9ae1e961-14543-500090a@10.9.0.5
CSeq: 101 OPTIONS
Contact: <sip:10.9.0.5:5060>
Max-Forwards: 0
Content-Length: 0
Sep 5 18:13:53.650: //1420/CF45E57E85DF/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=577058-1757
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 6746 5356 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 5 18:13:55.423: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:6132604848;tgrp=CUST7_6132604848_01A;trunk-context=siptrunking.bell.ca@192.197.135.179:5060 SIP/2.0
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bKdb4j1o0010ts3phrnem0sd9h7b481.1
From: <sip:5146027093@siptrunking.bell.ca>;tag=1015722548-1504635032191
To: "SIP Trunk Test Phone1" <sip:6132604848@lab.internetvoice.ca;user=phone>;tag=57400E-12BF
CSeq: 698238288 BYE
Max-Forwards: 19
Content-Length: 0
Sep 5 18:13:55.426: //1408/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:6132604848@10.9.0.14:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.2.179:5060;branch=z9hG4bK3313BB
From: <sip:5146027093@192.168.2.179>;tag=57481F-1059
To: "SIP Trunk Test Phone1" <sip:6132604848@10.9.0.14>;tag=15128771~c95be849-4c79-4ab9-b071-5968a9cb676e-73466532
Date: Tue, 05 Sep 2017 18:13:50 GMT
Max-Forwards: 70
Timestamp: 1504635235
CSeq: 101 BYE
Reason: Q.850;cause=16
Content-Length: 0
Sep 5 18:13:55.426: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "SIP Trunk Test Phone1" <sip:6132604848@lab.internetvoice.ca>;tag=57400E-12BF
Date: Tue, 05 Sep 2017 18:13:55 GMT
CSeq: 698238288 BYE
Content-Length: 0
Sep 5 18:13:55.429: //1408/F0EDBE000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
un all
VDSL daemon error condition debugging is off
VDSL daemon state machine debugging is off
VDSL daemon information debugging is off
VDSL ipc error condition debugging is off
VDSL ipc tx debugging is off
VDSL ipc rx debugging is off
VDSL MIB error debugging is off
VDSL MIB information debugging is off
All possible debugging has been turned off
09-05-2017 01:26 PM
Hi Ayodeji,
I reloaded the voice gateway and checked the Media Termination Point checkbox and reset the trunk. Both incoming and outgoing calls are working now. I personally don't believe to engage MTP for each incoming and outgoing calls. Could you please advise?
MK
09-05-2017 02:32 PM
I agree you should not use MTP for normal calls.
Looking at your previous logs, I see that media is been sent to this ip address:
c=IN IP4 10.9.0.15 instead of this192.197.135.179
When you sent INVITE to BELL you are telling them to send your media an ip address that is not reachable. Please check your SIP bind again for media..What is this IP address 10.9.0.15 --it looks like this is your cucm ip address..I am not sure why this is been used. Please remove MTP, reset the trunk and do another test call..send the logs and your updated config if it doesnt work
Sent:
s=SIP Call
c=IN IP4 10.9.0.15
09-05-2017 06:42 PM
10.9.0.15 is the CUCM Publisher. I have no idea why the Publisher is being used!!!
I disabled the MTP, reset the trunk and took the debug ccsip messaages. I guess the reason why calls requiring MTP is because the regoin used for trunk usess codecs G722 and G711. The G722 codec in service parameter is enabled. Here's the output of the debug ccsip:
sbc1#
Sep 6 01:29:41.743: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bK11v98b30c8t5gtotr890
Call-ID: e23b80a7751d4cf5cd5fd5cf386c4e1c000sg11@207.236.237.219
From: <sip:ping@207.236.237.219>;tag=b0b1c7362ffeffb111d274242f8388f4000sg11
Max-Forwards: 0
CSeq: 3651 OPTIONS
Sep 6 01:29:41.745: //6169/B0C0B5079894/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=179311D-2216
Date: Wed, 06 Sep 2017 01:29:41 GMT
CSeq: 3651 OPTIONS
Content-Length: 177
v=0
o=CiscoSystemsSIP-GW-UserAgent 5767 317 IN IP4 192.197.135.179
s=SIP Call
t=0 0
Sep 6 01:29:51.105: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.14:5060;branch=z9hG4bK4f86510005519
From: "6132604848" <sip:6132604848@10.9.0.14>;tag=15382540~c95be849-4c79-4ab9-b071-5968a9cb676e-73476518
Date: Wed, 06 Sep 2017 01:29:51 GMT
Call-ID: df76d700-9af14f8f-28433-e00090a@10.9.0.14
Min-SE: 1800
CSeq: 101 INVITE
Expires: 180
Cisco-Guid: 3749107456-0000065536-0000000198-0234883338
P-Asserted-Identity: "6132604848" <sip:6132604848@10.9.0.14>
Remote-Party-ID: "6132604848" <sip:6132604848@10.9.0.14>;party=calling;screen=yes;privacy=off
Max-Forwards: 69
Content-Length: 0
Sep 6 01:29:51.112: //6170/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Sep 6 01:29:51.112: //6171/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.197.135.179:5060;branch=z9hG4bK86570
From: "6132604848" <sip:6132604848@lab.internetvoice.ca;user=phone>;tag=17955B4-B8
Call-ID: B655D994-91D911E7-989AD5C3-63D7EB2F@lab.internetvoice.ca
Min-SE: 1800
CSeq: 101 INVITE
Timestamp: 1504661391
Expires: 1800
Max-Forwards: 68
P-Asserted-Identity: "6132604848" <sip:6132604848@lab.internetvoice.ca;user=phone>
Privacy: none
Content-Length: 352
v=0
o=CiscoSystemsSIP-GW-UserAgent 8556 4417 IN IP4 192.197.135.179
s=SIP Call
t=0 0
m=audio 16490 RTP/AVP 0 18 100 101
a=fmtp:18 annexb=no
a=fmtp:100 192-194
a=fmtp:101 0-16
a=ptime:20
Sep 6 01:29:51.126: //6171/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Sep 6 01:29:51.138: //6171/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:5146027093@siptrunking.bell.ca>;tag=1900786008-1504661200057
CSeq: 101 INVITE
WWW-Authenticate: DIGEST qop="auth",nonce="BroadWorksXj78cfge1T1guzbkBW",realm="siptrunking.bell.ca",algorithm=MD5
Content-Length: 0
Sep 6 01:29:51.140: //6171/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Sent:
From: "6132604848" <sip:6132604848@lab.internetvoice.ca>;tag=17955B4-B8
Max-Forwards: 70
CSeq: 101 ACK
Privacy: none
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 192.197.135.179:5060;branch=z9hG4bK871AC7
Min-SE: 1800
CSeq: 102 INVITE
Expires: 1800
Authorization: Digest username="CUST7_6132604848_01A",realm="siptrunking.bell.ca",uri="sip:5146027093@207.236.237.219:5060",response="42bebd5c3906050c2ac2733883b635b9",nonce="BroadWorksXj78cfge1T1guzbkBW",cnonce="FFFFFFFF",qop=auth,algorithm=MD5,nc=00000001
Max-Forwards: 68
Privacy: none
Content-Length: 352
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:100 192-194
a=fmtp:101 0-16
a=ptime:20
Sep 6 01:29:51.152: //6171/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Sep 6 01:29:51.745: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bKqpa1d130c0vb15nnai20
Call-ID: e23b80a7751d4cf5cd5fd5cf386c4e1c000s021@207.236.237.219
From: <sip:ping@207.236.237.219>;tag=b0b1c7362ffeffb111d274242f8388f4000s021
Max-Forwards: 0
CSeq: 3652 OPTIONS
Sep 6 01:29:51.747: //6172/B6B6E41B989B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=179582E-1993
CSeq: 3652 OPTIONS
Content-Length: 178
v=0
o=CiscoSystemsSIP-GW-UserAgent 2632 5882 IN IP4 192.197.135.179
s=SIP Call
t=0 0
Sep 6 01:29:53.223: //6171/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:5146027093@siptrunking.bell.ca>;tag=196602298-1504661202139
CSeq: 102 INVITE
Supported:
Session: Media
RSeq: 711324269
Require: 100rel
Content-Length: 241
v=0
o=- 3785097756 1 IN IP4 207.236.237.219
s=-
t=0 0
m=audio 49152 RTP/AVP 0 101
a=fmtp:101 0-15
a=maxptime:30
a=ptime:20
Sep 6 01:29:53.225: //6171/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.197.135.179:5060;branch=z9hG4bK881E3F
CSeq: 103 PRACK
RAck: 711324269 102 INVITE
Authorization: Digest username="CUST7_6132604848_01A",realm="siptrunking.bell.ca",uri="sip:5146027093@207.236.237.219:5060;transport=udp",response="67cf0a64829c8a9bb5b5b88a9aeaf320",nonce="BroadWorksXj78cfge1T1guzbkBW",cnonce="3A331D87",qop=auth,algorithm=MD5,nc=00000002
Max-Forwards: 70
Privacy: none
Content-Length: 0
Sep 6 01:29:53.228: //6170/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:5146027093@192.168.2.179>;tag=1795DF7-1991
CSeq: 101 INVITE
Require: 100rel
RSeq: 9882
Supported: sdp-anat
Content-Length: 298
v=0
o=CiscoSystemsSIP-GW-UserAgent 942 9764 IN IP4 192.168.2.179
s=SIP Call
t=0 0
m=audio 16488 RTP/AVP 0 100 101
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Sep 6 01:29:53.232: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.14:5060;branch=z9hG4bK4f86627f336df
CSeq: 102 PRACK
RAck: 9882 101 INVITE
Max-Forwards: 70
Content-Length: 222
v=0
o=CiscoSystemsCCM-SIP 15382540 1 IN IP4 10.9.0.14
s=SIP Call
c=IN IP4 10.8.64.14
b=TIAS:64000
b=AS:64
t=0 0
m=audio 22886 RTP/AVP 0 101
a=fmtp:101 0-15
Sep 6 01:29:53.235: //6170/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 06 Sep 2017 01:29:53 GMT
CSeq: 102 PRACK
Content-Length: 0
Sep 6 01:29:53.243: //6171/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 103 PRACK
Content-Length: 0
Sep 6 01:30:01.745: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bKaarr4p20d00e8u1bof60
Call-ID: e23b80a7751d4cf5cd5fd5cf386c4e1c000sg21@207.236.237.219
From: <sip:ping@207.236.237.219>;tag=b0b1c7362ffeffb111d274242f8388f4000sg21
Max-Forwards: 0
CSeq: 3653 OPTIONS
Sep 6 01:30:01.747: //6173/BCACC51B989C/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=1797F3E-10C7
Date: Wed, 06 Sep 2017 01:30:01 GMT
CSeq: 3653 OPTIONS
Content-Length: 178
v=0
o=CiscoSystemsSIP-GW-UserAgent 8944 8726 IN IP4 192.197.135.179
s=SIP Call
t=0 0
Sep 6 01:30:02.197: //6171/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported:
Content-Length: 241
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=maxptime:30
a=ptime:20
Sep 6 01:30:02.200: //6171/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.197.135.179:5060;branch=z9hG4bK891027
Max-Forwards: 70
CSeq: 102 ACK
Privacy: none
Content-Length: 0
Sep 6 01:30:02.200: //6170/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 298
v=0
s=SIP Call
t=0 0
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
Sep 6 01:30:02.205: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.14:5060;branch=z9hG4bK4f8677d79bb1b
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 222
v=0
s=SIP Call
c=IN IP4 10.8.64.14
b=TIAS:64000
b=AS:64
t=0 0
a=fmtp:101 0-15
Sep 6 01:30:11.747: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bK7be06500d804sbmv78a0
Call-ID: e23b80a7751d4cf5cd5fd5cf386c4e1c000s031@207.236.237.219
From: <sip:ping@207.236.237.219>;tag=b0b1c7362ffeffb111d274242f8388f4000s031
Max-Forwards: 0
CSeq: 3654 OPTIONS
Sep 6 01:30:11.749: //6174/C2A2F42F989D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=179A650-10E
Date: Wed, 06 Sep 2017 01:30:11 GMT
CSeq: 3654 OPTIONS
Content-Length: 177
v=0
o=CiscoSystemsSIP-GW-UserAgent 7813 802 IN IP4 192.197.135.179
s=SIP Call
t=0 0
Sep 6 01:30:16.076: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.25.0.7:5060;branch=z9hG4bK55184f88cec0
Date: Wed, 06 Sep 2017 01:30:16 GMT
Call-ID: ee5d8980-9af14fa8-1dc7-700190a@10.25.0.7
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Sep 6 01:30:16.077: //6175/C5375C28989E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=179B739-F6A
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 7910 2618 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 6 01:30:16.349: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.5:5060;branch=z9hG4bK43cb11ad0a063
Call-ID: ee5d8980-9af14fa8-15098-500090a@10.9.0.5
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Sep 6 01:30:16.351: //6176/C5612ACF989F/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=179B84A-15F0
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 1733 4782 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 6 01:30:16.575: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.25.0.8:5060;branch=z9hG4bK5c574f7f59c
Call-ID: ee5d8980-9af14fa8-5c6-800190a@10.25.0.8
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Sep 6 01:30:16.577: //6177/C5837FA898A0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=179B92C-18D0
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 4263 5398 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 6 01:30:17.695: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.15:5060;branch=z9hG4bK851a063e1cdd1
Date: Wed, 06 Sep 2017 01:30:17 GMT
Call-ID: eef62000-9af14fa9-2c8c2-f00090a@10.9.0.15
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Sep 6 01:30:17.699: //6178/C62E653998A1/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=179BD8C-1C63
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 3015 1126 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 6 01:30:17.980: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.57.0.11:5060;branch=z9hG4bK56873c1f4b08
Call-ID: eef62000-9af14fa9-24b2-b00390a@10.57.0.11
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Sep 6 01:30:17.982: //6179/C65A085898A2/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=179BEA9-46D
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 4593 5781 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 6 01:30:18.565: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.9.0.14:5060;branch=z9hG4bK4f869607f1eda
Date: Wed, 06 Sep 2017 01:30:18 GMT
Call-ID: ef8eb680-9af14faa-28435-e00090a@10.9.0.14
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Sep 6 01:30:18.566: //6180/C6B325AB98A3/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=179C0F2-EA5
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 7262 4457 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 6 01:30:18.630: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.49.0.9:5060;branch=z9hG4bK186361acac38
Call-ID: ef8eb680-9af14faa-cdb-900310a@10.49.0.9
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Sep 6 01:30:18.631: //6181/C6BD10B298A4/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=179C133-45D
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 4110 2285 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 6 01:30:18.824: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bKdal2tt3048phbpsllu90sda9psuj1.1
From: <sip:5146027093@siptrunking.bell.ca>;tag=196602298-1504661202139
To: "6132604848" <sip:6132604848@lab.internetvoice.ca;user=phone>;tag=17955B4-B8
CSeq: 711323239 BYE
Max-Forwards: 19
Content-Length: 0
Sep 6 01:30:18.826: //6170/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.2.179:5060;branch=z9hG4bK8A108D
From: <sip:5146027093@192.168.2.179>;tag=1795DF7-1991
To: "6132604848" <sip:6132604848@10.9.0.14>;tag=15382540~c95be849-4c79-4ab9-b071-5968a9cb676e-73476518
Date: Wed, 06 Sep 2017 01:30:02 GMT
Max-Forwards: 70
Timestamp: 1504661418
CSeq: 101 BYE
Content-Length: 0
Sep 6 01:30:18.827: //6171/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "6132604848" <sip:6132604848@lab.internetvoice.ca>;tag=17955B4-B8
CSeq: 711323239 BYE
Content-Length: 0
Sep 6 01:30:18.830: //6170/DF76D7000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
Sep 6 01:30:18.923: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.57.0.10:5060;branch=z9hG4bK49a23a2b3630
Call-ID: ef8eb680-9af14faa-3a84-a00390a@10.57.0.10
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Sep 6 01:30:18.925: //6182/C6E9C56398A5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=179C258-1FBB
CSeq: 101 OPTIONS
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 4688 6150 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 6 01:30:20.270: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.89.0.3:5060;branch=z9hG4bK679e6be323
Date: Wed, 06 Sep 2017 01:30:20 GMT
Call-ID: f0bfe380-9af14fac-66b-300590a@10.89.0.3
CSeq: 101 OPTIONS
Max-Forwards: 0
Content-Length: 0
Sep 6 01:30:20.272: //6183/C7B7773C98A6/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:192.168.2.179>;tag=179C79B-1DED
CSeq: 101 OPTIONS
Supported: 100rel,timer,resource-priority,replaces,sdp-anaun at
Content-Length: 172
v=0
o=CiscoSystemsSIP-GW-UserAgent 5319 9671 IN IP4 192.168.2.179
s=SIP Call
t=0 0
Sep 6 01:30:21.747: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 207.236.237.219:5060;branch=z9hG4bKhbt49310dg1gunhmf2g0
Call-ID: e23b80a7751d4cf5cd5fd5cf386c4e1c000sg31@207.236.237.219
From: <sip:ping@207.236.237.219>;tag=b0b1c7362ffeffb111d274242f8388f4000sg31
Max-Forwards: 0
CSeq: 3655 OPTIONS
Sep 6 01:30:21.749: //6184/C898D52F98A7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:ping@customer7.lab.internetvoice.ca;tag=179CD61-1A03
Date: Wed, 06 Sep 2017 01:30:21 GMT
CSeq: 3655 OPTIONS
Allow-Events: telephll
sbc1#one-event
Content-Length: 178
v=0
o=CiscoSystemsSIP-GW-UserAgent 5966 2921 IN IP4 192.197.135.179
s=SIP Call
t=0 0
un all
09-06-2017 02:40 AM
So what is the status now. Everything looks okay from the logs. I can see that media is sent to the correct address..
09-06-2017 08:59 AM
As soon as I disable the MTP on the trunk, the call gets disconnected. The phone rings and gets disconnected 5 seconds after being answered.
MK
