Understanding VOIP Telephony
I have a 3845 router and we are in the process of configuring for a circuit switchoever to use a complete VOIP system for long distance and 800 numbers.
I don't really understand the set up, the router will be like the DMARC for the DS3 connection to the Voice Internet.
We have been given some test numbers to use in prep for the circuit switchover.
I have been told to do q931 debugs and call the test number, the number should be routed to our gateway.
The serial congifs are shown below.
My questions are:
1. I cannot see the numbers come in when I dial any of the test numbers in the debugs, all I see is:
Ux_DLRelInd: DL_REL_IND received from L2
The controllers are up and I can ping Internet addresses rom the router.
Is this a normal error to see, or is there a problem with Layer 2?
2. If the carrier has not done their end by making sure the test numbers are routed to us, would I see this error?
3. What would be the terminology for what this router is doing (acting as the DMARC)?
4. Should I be able to test dial a number from one of the Interfaces shown below?
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:23
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/1/0:23
no ip address
encapsulation hdlc
no cdp enable
interface Serial1/0
no ip address
no ip redirects
no ip proxy-arp
encapsulation frame-relay IETF
no ip mroute-cache
dsu bandwidth 44210
frame-relay traffic-shaping
frame-relay lmi-type q933a
max-reserved-bandwidth 90
interface Serial1/0.1 point-to-point
ip address 1.1.1.1 255.255.255.252
no cdp enable
no arp frame-relay
frame-relay class Advantage
frame-relay interface-dlci 500
crypto map sip
Hall of Fame Super Gold
Re: Understanding VOIP Telephony
This is a voice gateway. If you do "show isdn status" you will be able to check on ISDN L2 status. If you enter
csim start
a call will be placed according to you dial-peer configuration. You should be able to see it with "debug isdn q931".
Thank
144
