11-28-2011 05:48 AM - last edited on 03-25-2019 08:11 PM by ciscomoderator
I have a E1 interface on a 2951 MGCP gateway.
I have setup a fractional PRI, but I need to enforce some channel "direction":
- ch 1-5: inbound
- ch 6-10: bidirectional
- ch 11-15: outbound
- ch 16: signaling
I have setup the fractional pri in this way:
on the 2951:
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 6-16 service mgcp
trunk-group 1 timeslots 6-15
on the cucm
Service Parameter -> Advanced
Change B-Channel Maintenance Status 1 =
S0/SU0/DS1-0@ues-mgw02 = 0000 0000 0000 0000 1111 1111 1111 1111
but in this way I am not able to get inbound calls coming from first 5 channels....
Does any1 know how to setup such a configuration using a mgcp gateway ??
11-28-2011 06:21 AM
If you change to an H323 gateway your trunk group commands will work.
trunk group INBOUND
trunk group OUTBOUND
controller E1 1/0/0
pri-group timeslots 1-16
trunk-group INBOUND timeslots 1-5
trunk-group OUTBOUND timeslots 6-15
description *** ISDN for PSTN ***
dial-peer voice 9 pots
description *** O/G LEVEL 9 TRAFFIC TO PSTN ***
destination-pattern 9T
tone ringback alert-no-PI
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
trunkgoup OUBOUND
You cannot control the timeslot selection from the PSTN service provider
But at least you will not send calls out on 1 - 5
Alex
11-28-2011 06:33 AM
thx 4 ut help but I'd prefere to keep the MGCP configuration... and I was wondering if such a setup could work:
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-16 service mgcp
trunk-group 1 timeslots 1-5
trunk-group 2 timeslots 6-10
trunk-group 3 timeslots 11-15
trunk-group 1
max-calls voice 5 direction in
max-calls voice 0 direction out
trunk-group 2
max-calls voice 5 direction out
trunk-group 3
max-calls voice 0 direction in
We're in a sensible environment so I have not applied this configuration, and I'm going to test it during night hours but i'd like to know your opinion...
11-28-2011 06:49 AM
My understanding re MGCP.
When you bind the the service of the E1 to MGCP the PRI is
backhauled therefore any commands that you invoke re
the controller and the serial "D" channel are ignored until the
MGCP service fails and you fall-over to SRST for example.
You can only try.
If it does not work then you will need to cosider moving to
H323 or SIP.
Alex
11-28-2011 06:59 AM
I see: so each and every command about trunk-group etc etc will be ignored by design because of the MGCP "behaviour"...
I should consider configuring a H323 gateway but this will be a "major" change in the setup.
Anyway, thanks a lot for your help
G.
