Community Member
Unified CM Component Version mismatch
I have CUCM 7.1(3b)SU2 [7.1.3.32900-4]. It was upgrade from 7.1(3b) [7.1.3.30000-1] during installation. The subscriber has been added successfully but when I run Unified CM Cluster Overview Report it shows me a Unified CM Component Version mismatch for more than one component. In corrupted component is not installed at all on the subscriber. This will affect the call process if I forced to IP phones to register on the subscriber.
Attached is the XML file for that report.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Unified CM Component Version mismatch
This can actually be a cosmetic issue based on how you added the Subscriber to the cluster.  Some components such as Cactus (and a number of others) have been stripped in newer releases of CUCM.  I ran into the same issue when I added a 4th Subscriber to an existing cluster and upgraded directly to the current cluster version during install as opposed to the install path the other servers had seen (base from factory, then upgrade to version XYZ).  At the time, I opened a TAC case and after a couple weeks - the case was escalated internally and the escalation engineer indicated this is usually a cosmetic issue.  My customer has had no issues since.  If it makes you feel better, put in the TAC case and get validation on whether it's an issue for you or not.  I suspect the answer is no.
Hailey
Please rate helpful posts!
Hailey
Community Member
In fact the installation path was the same for both CUCM and same media.. I am opening a TAC with Cisco and I will inform you once they solve it.
Community Member
Yes, You are right.
Community Member
Abu/David,
I am also having the same problem after upgrading from 7.1(3)b (7.1.3.30000-1) to 7.1(3)b SU2 (7.1.3.32900-4). Can you both please provide your TAC cases on this so that I can give my existing TAC engineer these SR numbers for reference.
Thank you,
Hunter Guillory, Sr. UC Engineer
Presidio Networked Solutions
CCIE #25780 (Voice)
SR 611197073
Hailey
Community Member
Excellent, thank you.
Hall of Fame Super Red
Hi Hunter,
Just in case;
CSCsl71686 has been superseded by CSCsl61950 displayed below.
CSCsl61950            Bug Details
Cisco Unified Reporting does not handle upper case /etc/hosts correctly
Symptom:
reporting app is not handling the case correctly. I changed the /etc/hosts file
to have lower case and the report is generated correctly.
Conditions:
reporting app
mixed case chars in /etc/hosts
Workaround:
Further Problem Description:
StatusStatus
Fixed
Severity Severity
3 - moderate
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified Communications Manager (CallManager)
Technology Technology
1st Found-In 1st Found-in
5.1(3)
6.1(1)
7.0(0.9821.2)
Fixed-In Fixed-in
7.0(0.39000.14)
6.1(1.9901.32)
5.1(3.9901.89)
5.1(3.2102.1)
6.1(1.2105.1)
6.1(2.1000.13)
7.0(0.66666.1)
7.0(0.66666.2)
7.0(1.11000.2)
6.1(3.9999.1)
Related Bug Information
CU Reporting CM Cluster Overview component versions are out of sync
Symptom: When using Cisco Unified Reporting, after you run CM Cluster Overview report the Component versions are always out of sync.  Conditions: The component versions shows which version of software components are installed on each node and this report indicates all components on all nodes are out of sync incorrectly. Inspecting via CU OS Admin CLI "show packages" indicates all components are infact in sync. Workaround:No workaround to get this report to reliably compare all components on all nodes. This section of the report can be ignored since it is not reliably showing which components are in fact out of sync.
Cheers!
Rob
Community Member
Rob,
Great feedback; I will reference this bug as well.
Hunter
1250
