08-09-2012 01:40 PM - edited 03-16-2019 12:38 PM
Hello guys!
Is there any questionaire to give to clients when offering a Communication Manager solution, sort of a client requirement list? Thanks in advanced for any help!
Solved! Go to Solution.
08-09-2012 01:52 PM
See this link:
http://www.cisco.com/en/US/products/ps11369/index.html
Is about BE6000.
Rate this if helps you.
Leonardo Santana
08-09-2012 01:49 PM
Yes depends on what solution are you talking about. You can see on the datasheet and CUCM SRND.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guides_list.html
See the SRND of the CUCM version that you need.
Datasheet:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/index.html
Leonardo Santana
08-09-2012 01:50 PM
Thanks for the reply! In this case, it is BE 6000.
08-09-2012 01:52 PM
See this link:
Is about BE6000.
Leonardo Santana
08-09-2012 02:06 PM
Thanks for the information.
