Unified Communications requirements questionaire
                   Hello guys!
Is there any questionaire to give to clients when offering a Communication Manager solution, sort of a client requirement list? Thanks in advanced for any help!
1 ACCEPTED SOLUTION
Re: Unified Communications requirements questionaire
See this link:
http://www.cisco.com/en/US/products/ps11369/index.html
Is about BE6000.
Rate this if helps you.
Leonardo Santana
Yes depends on what solution are you talking about. You can see on the datasheet and CUCM SRND.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guides_list.html
See the SRND of the CUCM version that you need.
Datasheet:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/index.html
Leonardo Santana
Thanks for the reply! In this case, it is BE 6000.
See this link:
Is about BE6000.
Leonardo Santana
Thanks for the information.
467
