05-01-2009 08:05 AM - edited 03-15-2019 05:46 PM
Hi all,
Currently, we have unified messaging 4.21 with exchange 2003.
Soon we will upgrade to unified messaging to 5 or 7 to compatible with exchange 2007.
However, our unified is running on windows 2003, but exchange 2007 will run on windows 2008.
It might be a stupid question, but I want to make sure that: is it ok unified runs on windows 2003 and exchange 2007 runs on windows 2008??
Ken
Solved! Go to Solution.
05-04-2009 08:42 AM
Its more of a microsoft issue, not Unity per say. Unity's only requirements is that it either works with Exchange 2007 on 2003 or Exchange 2007 on Windows 2008. Both are supported in the CCO Documents.
05-04-2009 08:18 AM
Not quite sure what you are looking for here.
Unity runs on Windows 2003, but can be a member of a Windows 2008 domain. Your Exchange 2007 platform needs to comply with Microsoft best practice. Exchange 2007 can be installed on Windows 2003 or 2008 server.
make sense or?
05-04-2009 08:34 AM
Sorry to confuse you.
Because my server guy asked me that make sure unified messaging running on window 2003 will compatible with exchange 2007 with window 2008. Because he worries about windows 2003 will not compatible windows 2008.
I am sure it will work, just want to confirm.
Ken
05-04-2009 08:42 AM
05-04-2009 08:43 AM
Thanks.. you answer my questions.
