Community Member
Unified Mobility Advantage and CUCM 7.1
Could please some one confirm do the Unified Mobility Advantage is integrated with CUCM 7.1 or do we need to buy seprate server for this. Client needs Cisco Unified Mobile Communicator in Nokia N series Wireless IP Phone.
1 ACCEPTED SOLUTION
Re: Unified Mobility Advantage and CUCM 7.1
CUMA 7.x will integrate with CUCM 7.1.  However, you will need a Cisco ASA running the UC Proxy feature set (and associated licensing).  The Cisco ASA is placed in your DMZ.  The ASA will proxy connections from CUMC to CUMA.  The CUMA server will then allow CUMC features to access backend services offered by CUCM (call processing), LDAP (directories), Exchange (calendaring), etc.
See: http://www.cisco.com/en/US/docs/voice_ip_comm/cuma/7_1/XML/new_installs/cuma71_new_install_config_chapter2.html
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
1 REPLY
Bill
275
