Unified Mobility, no audio on Send call to Mobile Phone
I'm using UCM 9.1 with Unified Mobility (xfer to alternate number) with good success if I follow a typical call flow:
Inbound call -> Ext -> Rings deskphone x seconds -> Rings mobile phone -> Answer mobile phone -> hangup -> Resume call on desk phone.
But if I pick up a call on my desk phone, and use the Mobility button to xfer a call to my mobile phone I get no audio:
Inbound call -> Ext -> Pickup desk phone -> Mobility soft button, 'Send call to Mobile Phone' -> Answer mobile phone, no audio -> Hang up mobile phone -> Resume call on desk phone (two-way audio).
Device wise the call flow is:
ITSP SIP trunk -> CUBE -> CUCM -> 7965 IP Phone.
Recently I reconfigured CUCM to use the CUBE for any MTP resources instead of the software option and I think I may have missed something.
CUBE config:
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 173.46.30.218
  ipv4 173.46.30.202
  ipv4 10.0.6.30
  ipv4 10.0.6.31
  ipv4 10.0.6.33
  ipv4 10.0.6.32
  ipv4 10.1.1.4
  ipv4 10.0.250.0 255.255.255.0
mode border-element
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  midcall-signaling passthru media-change
  early-offer forced
  no call service stop
  registration passthrough
voice class codec 1
codec preference 1 g711ulaw
sccp local GigabitEthernet0/0.42
sccp ccm 10.0.6.30 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0.42
associate ccm 1 priority 1
associate profile 1 register MTP_2951-01
dspfarm profile 2 transcode universal
codec pass-through
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 11
associate application SCCP
shutdown
dspfarm profile 3 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
dspfarm profile 1 mtp
codec pass-through
codec g711ulaw
maximum sessions hardware 15
In CUCM I removed the software MTP from the MRG:
Screenshot from 2013-12-04 12:09:27.png
Not sure where to start troubleshooting this problem, any help is appreciated.
Steve
Re: Unified Mobility, no audio on Send call to Mobile Phone
Can you add mid-call signalling passthru mediachange at dial-peer level. I know you had configured at globally but still a chance.
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/cube_proto/configuration/15-2mt/cube-midcall-reinvite.html
Hi Steve.
Please check which Media Resource Group List is associated whith your IP Phone and, if you can, please send the output of a debug ccsip messages during a call with no audio.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Steve,
I assume you are looking at MTP because you expect it to be invoked in the call. If you have provisioned the SIP trunk to use MTP and can make an outbound call that has full duplex audio then your MTP is configured correctly. In any case, you can use "show sccp conn" on the CUBE during an active call to see MTP status.
One of the UCM configs to check when you are inserting a MTP provided for a specific codec (G711) is the region assigned to the phone, CUBE, and MTP. Make sure that if they are in different regions that you have allowed G711 between regions.
The above line of thought leads me to asking about your codec requirements. Is the ITSP expecting G711 or G729 (or other)? If they want G729 and you are invoking a MTP with G711 then you will have media negotiation failure. That is usually manifested with a lovely fast busy but I figured it is worth asking.
Is it accurate that you have "no audio"? Or is it just half-duplex?
I concur that see the SIP message exchange could help.
Since you asked about your config, there is one config element to review. Your MTP profile looks like:
 codec pass-through
 codec g711ulaw
This isn't affecting your mobility configuration but there is no need to use hardware resources on an IOS MTP if you aren't transrating. Just a FYI.
HTH.
-Bill (http://ucguerrilla.com)
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Thanks for the help gents. I couldn't get to this until we're out of office hours on the weekend.
Interestingly, I have no mid-call option in my dial-peers. This is a 2951 running 15.2(4)M2.
I double checked the MRGL, my phone is associated with it.
Codec is G711 on ITSP side, and on phones - I'm not sure I fully understand the use cases for MTP, this is something I need to research more.
I've included two ccsip message debugs, the first one is the existing issue of no audio (in either direction).
The second I've changed the midcall-signaling passthru option, dropping the media-change bit and we get audio in both directions for mobility except we use Unity call handlers for IVR functionality, and now when an inbound caller is forwarded to an extension we get no audio - obviously this is a game stopper.
In Unity I have the port group configured as SCCP - Maybe I should be using SIP instead?
No Audio:
voice service voip
sip
  early-offer forced
Dec  8 21:07:35.842: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:5198079141@10.0.250.4:5060 SIP/2.0
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bK6b1b7e642f53
From: "Steve Dainard" <5195132407>;tag=40265~d732e07f-799a-4d2b-9d6a-ae2aaf54507d-19727249
To: <5198079141>
Date: Sun, 08 Dec 2013 21:07:35 GMT
Call-ID: c1638b00-2a41df97-146a-1e06000a@10.0.6.30
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Cisco-Guid: 3244526336-0000065536-0000003600-0503709706
Session-Expires:  1800
Diversion: <5195132407>;reason=follow-me;privacy=off;screen=yes
P-Asserted-Identity: "Steve Dainard" <5195132407>
Remote-Party-ID: "Steve Dainard" <5195132407>;party=calling;screen=yes;privacy=off
Contact: <5195132407>;isFocus
Max-Forwards: 70
Content-Length: 0
Dec  8 21:07:35.850: //13815/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:5198079141@173.46.30.202:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.1.67:5060;branch=z9hG4bK274BE17
From: "Steve Dainard" <5195132407>;tag=47582CDC-2165
To: <5198079141>
Call-ID: 98B39623-5F8311E3-9013C4ED-C30E2996@10.0.1.67
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1386536855
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Diversion: <5195132407>;privacy=off;reason=follow-me;screen=yes
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 7885 9952 IN IP4 10.0.1.67
s=SIP Call
c=IN IP4 10.0.1.67
t=0 0
m=audio 29558 RTP/AVP 0 101
c=IN IP4 10.0.1.67
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Dec  8 21:07:35.850: //13814/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <5198079141>
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-15.2.4.M2
Content-Length: 0
Dec  8 21:07:35.858: //13815/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <5198079141>
CSeq: 101 INVITE
Dec  8 21:07:41.986: //13815/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <5198079141>;tag=as1502e8b4
CSeq: 101 INVITE
Contact: <5198079141>
Server: Rogers SIP Core
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Content-Length: 253
v=0
o=root 959120698 959120698 IN IP4 173.46.30.202
s=Rogers SIP
c=IN IP4 173.46.30.202
t=0 0
m=audio 40818 RTP/AVP 0 101
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Supported: replaces
Content-Length: 0
Dec  8 21:07:41.990: //13814/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <5198079141>;tag=475844D8-1CC2
CSeq: 101 INVITE
Supported: sdp-anat
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 3614 6206 IN IP4 10.0.250.4
s=SIP Call
c=IN IP4 10.0.250.4
t=0 0
m=audio 29556 RTP/AVP 0 101
c=IN IP4 10.0.250.4
a=fmtp:101 0-16
a=ptime:20
Sent:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
Dec  8 21:07:43.938: //13815/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 253
v=0
o=root 959120698 959120699 IN IP4 173.46.30.202
s=Rogers SIP
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Dec  8 21:07:43.938: //13814/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Session-Expires:  1800;refresher=uac
Supported: timer
Content-Length: 241
v=0
s=SIP Call
c=IN IP4 10.0.250.4
t=0 0
c=IN IP4 10.0.250.4
a=fmtp:101 0-16
a=ptime:20
Dec  8 21:07:43.942: //13815/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:5198079141@173.46.30.202:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.0.1.67:5060;branch=z9hG4bK274C4F2
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Dec  8 21:07:43.958: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:5198079141@10.0.250.4:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bK6b1d288c5e53
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 218
v=0
o=CiscoSystemsCCM-SIP 40265 1 IN IP4 10.0.6.30
s=SIP Call
c=IN IP4 10.0.6.30
t=0 0
m=audio 4000 RTP/AVP 0 101
a=ptime:20
a=inactive
a=fmtp:101 0-15
Dec  8 21:07:44.158: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
UPDATE sip:5198079141@10.0.250.4:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bK6b1f50a2749f
Max-Forwards: 70
CSeq: 102 UPDATE
P-Asserted-Identity: "Steve Dainard" <450>
Remote-Party-ID: "Steve Dainard" <450>;party=calling;screen=yes;privacy=off
Content-Length: 0
Dec  8 21:07:44.158: //13814/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sun, 08 Dec 2013 21:07:44 GMT
CSeq: 102 UPDATE
Supported: timer
Content-Length: 0
Dec  8 21:07:44.162: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:5198079141@10.0.250.4:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bK6b2028eab237
Min-SE:  1800
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
Dec  8 21:07:44.162: //13814/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 103 INVITE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 103 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 241
v=0
s=SIP Call
c=IN IP4 10.0.250.4
t=0 0
c=IN IP4 10.0.250.4
a=fmtp:101 0-16
a=ptime:20
Dec  8 21:07:44.214: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bK6b2151dd5c40
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 232
v=0
o=CiscoSystemsCCM-SIP 40265 3 IN IP4 10.0.6.30
s=SIP Call
c=IN IP4 10.0.250.93
b=TIAS:64000
b=AS:64
t=0 0
m=audio 25834 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
Dec  8 21:07:52.590: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:5195132407@10.0.1.67:5060 SIP/2.0
Via: SIP/2.0/UDP 173.46.30.202:5060;branch=z9hG4bK76uf9710bomh2kk6c350.1
Max-Forwards: 68
To: "Steve Dainard" <5195132407>;tag=47582CDC-2165
CSeq: 102 INVITE
User-Agent: Rogers SIP Core
Supported: replaces
Content-Length: 253
v=0
o=root 959120698 959120700 IN IP4 173.46.30.202
s=Rogers SIP
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Dec  8 21:07:52.594: //13815/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sun, 08 Dec 2013 21:07:52 GMT
CSeq: 102 INVITE
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 7885 9953 IN IP4 10.0.1.67
s=SIP Call
c=IN IP4 10.0.1.67
t=0 0
c=IN IP4 10.0.1.67
a=fmtp:101 0-16
a=ptime:20
Dec  8 21:07:52.610: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:5195132407@10.0.1.67:5060 SIP/2.0
Via: SIP/2.0/UDP 173.46.30.202:5060;branch=z9hG4bK8m4hbg10c8ag4kg723g0.1
Max-Forwards: 68
CSeq: 102 ACK
Content-Length: 0
Dec  8 21:07:52.630: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:5195132407@10.0.1.67:5060 SIP/2.0
Via: SIP/2.0/UDP 173.46.30.202:5060;branch=z9hG4bK96bidp10cou05l89e611.1
Max-Forwards: 68
CSeq: 103 BYE
X-RBS-SIP-HangupCause: Normal Clearing
X-RBS-SIP-HangupCauseCode: 16
Content-Length: 0
Dec  8 21:07:52.634: //13814/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:5195132407@10.0.6.30:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.0.250.4:5060;branch=z9hG4bK274D1192
To: "Steve Dainard" <5195132407>;tag=40265~d732e07f-799a-4d2b-9d6a-ae2aaf54507d-19727249
Max-Forwards: 70
Timestamp: 1386536872
CSeq: 101 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=0,OS=0,PR=420,OR=67200,PL=0,JI=0,LA=0,DU=8
Content-Length: 0
Dec  8 21:07:52.634: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 BYE
P-RTP-Stat: PS=2,OS=320,PR=100,OR=16000,PL=0,JI=0,LA=0,DU=8
Content-Length: 0
Dec  8 21:07:52.646: //13814/C1638B000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
bi-direcitonal audio:
voice service voip
sip
  early-offer forced
Dec  8 21:09:44.331: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bK6b267445467f
From: "Steve Dainard" <5195132407>;tag=40276~d732e07f-799a-4d2b-9d6a-ae2aaf54507d-19727255
To: <5198079141>
Date: Sun, 08 Dec 2013 21:09:44 GMT
Call-ID: e476180-2a41e018-1471-1e06000a@10.0.6.30
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Cisco-Guid: 0239559040-0000065536-0000003601-0503709706
Max-Forwards: 70
Content-Length: 0
Dec  8 21:09:44.339: //13819/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.0.1.67:5060;branch=z9hG4bK274E8E6
From: "Steve Dainard" <5195132407>;tag=475A22C4-26C5
To: <5198079141>
Call-ID: E5496B22-5F8311E3-9019C4ED-C30E2996@10.0.1.67
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1386536984
Expires: 180
Max-Forwards: 69
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 4519 2507 IN IP4 10.0.1.67
s=SIP Call
c=IN IP4 10.0.1.67
t=0 0
m=audio 29562 RTP/AVP 0 101
c=IN IP4 10.0.1.67
a=fmtp:101 0-16
a=ptime:20
Dec  8 21:09:44.339: //13818/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <5198079141>
CSeq: 101 INVITE
Content-Length: 0
Dec  8 21:09:44.347: //13819/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <5198079141>
CSeq: 101 INVITE
Dec  8 21:09:52.535: //13819/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <5198079141>;tag=as314346be
CSeq: 101 INVITE
Supported: replaces
Content-Length: 255
v=0
o=root 1961674502 1961674502 IN IP4 173.46.30.202
s=Rogers SIP
t=0 0
m=audio 37982 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Dec  8 21:09:52.539: //13818/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <5198079141>;tag=475A42CC-1387
CSeq: 101 INVITE
Supported: sdp-anat
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 7438 7415 IN IP4 10.0.250.4
s=SIP Call
c=IN IP4 10.0.250.4
t=0 0
m=audio 29560 RTP/AVP 0 101
c=IN IP4 10.0.250.4
a=fmtp:101 0-16
a=ptime:20
Dec  8 21:09:53.007: //13819/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Supported: replaces
Content-Length: 0
Dec  8 21:09:53.007: //13818/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Content-Length: 0
Dec  8 21:09:54.967: //13819/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 255
v=0
o=root 1961674502 1961674503 IN IP4 173.46.30.202
s=Rogers SIP
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Dec  8 21:09:54.967: //13818/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 241
v=0
s=SIP Call
c=IN IP4 10.0.250.4
t=0 0
c=IN IP4 10.0.250.4
a=fmtp:101 0-16
a=ptime:20
Sent:
Via: SIP/2.0/UDP 10.0.1.67:5060;branch=z9hG4bK274F1060
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Dec  8 21:09:54.979: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bK6b2876c28ab9
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 218
v=0
o=CiscoSystemsCCM-SIP 40276 1 IN IP4 10.0.6.30
s=SIP Call
c=IN IP4 10.0.6.30
t=0 0
a=ptime:20
a=inactive
a=fmtp:101 0-15
Dec  8 21:09:55.007: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bK6b2ada930eb
Max-Forwards: 70
CSeq: 102 UPDATE
Content-Length: 0
Dec  8 21:09:55.011: //13818/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sun, 08 Dec 2013 21:09:55 GMT
CSeq: 102 UPDATE
Supported: timer
Content-Length: 0
Dec  8 21:09:55.011: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bK6b2be82180d
Min-SE:  1800
CSeq: 103 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 0
Dec  8 21:09:55.011: //13819/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:5198079141@173.46.30.202:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.0.1.67:5060;branch=z9hG4bK275014C3
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1386536995
Expires: 180
Content-Length: 0
Sent:
SIP/2.0 100 Trying
CSeq: 103 INVITE
Content-Length: 0
Dec  8 21:09:55.019: //13819/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Dec  8 21:09:55.031: //13819/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 279
v=0
o=root 1961674502 1961674504 IN IP4 173.46.30.202
s=Rogers SIP
t=0 0
m=audio 37982 RTP/AVP 0 8 101
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Dec  8 21:09:55.035: //13818/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 241
v=0
s=SIP Call
c=IN IP4 10.0.250.4
t=0 0
c=IN IP4 10.0.250.4
a=fmtp:101 0-16
a=ptime:20
Dec  8 21:09:55.175: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bK6b2c8e71c96
Max-Forwards: 70
CSeq: 103 ACK
Content-Length: 232
v=0
o=CiscoSystemsCCM-SIP 40276 3 IN IP4 10.0.6.30
s=SIP Call
b=TIAS:64000
b=AS:64
t=0 0
m=audio 22546 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
Dec  8 21:09:55.179: //13819/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.0.1.67:5060;branch=z9hG4bK2751A88
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 4519 2508 IN IP4 10.0.1.67
s=SIP Call
c=IN IP4 10.0.1.67
t=0 0
c=IN IP4 10.0.1.67
a=fmtp:101 0-16
a=ptime:20
Dec  8 21:10:05.267: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 173.46.30.202:5060;branch=z9hG4bK3tuoo01070ag0lg7o5k0.1
Max-Forwards: 68
To: "Steve Dainard" <5195132407>;tag=475A22C4-26C5
CSeq: 102 INVITE
Supported: replaces
Content-Length: 255
v=0
o=root 1961674502 1961674505 IN IP4 173.46.30.202
s=Rogers SIP
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Dec  8 21:10:05.271: //13818/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:5195132407@10.0.6.30:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.0.250.4:5060;branch=z9hG4bK27523EA
To: "Steve Dainard" <5195132407>;tag=40276~d732e07f-799a-4d2b-9d6a-ae2aaf54507d-19727255
Date: Sun, 08 Dec 2013 21:10:05 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1386537005
Expires: 180
Content-Length: 241
v=0
s=SIP Call
c=IN IP4 10.0.250.4
t=0 0
c=IN IP4 10.0.250.4
a=fmtp:101 0-16
a=ptime:20
Dec  8 21:10:05.271: //13819/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
Dec  8 21:10:05.275: //13818/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Remote-Party-ID: "Steve Dainard" <450>;party=called;screen=yes;privacy=off
Content-Length: 232
v=0
s=SIP Call
b=TIAS:64000
b=AS:64
t=0 0
a=ptime:20
a=fmtp:101 0-15
Dec  8 21:10:05.279: //13819/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 238
v=0
s=SIP Call
c=IN IP4 10.0.1.67
t=0 0
c=IN IP4 10.0.1.67
a=fmtp:101 0-16
a=ptime:20
Dec  8 21:10:05.279: //13818/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:5195132407@10.0.6.30:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.0.250.4:5060;branch=z9hG4bK27531E8D
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Dec  8 21:10:05.295: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 173.46.30.202:5060;branch=z9hG4bK4d5qq910785h6ks9f3c0.1
Max-Forwards: 68
CSeq: 102 ACK
Content-Length: 0
Received:
Via: SIP/2.0/UDP 173.46.30.202:5060;branch=z9hG4bK4tbtsi10785h6jcp71g1.1
Max-Forwards: 68
CSeq: 103 BYE
Content-Length: 0
Dec  8 21:10:05.295: //13818/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 10.0.250.4:5060;branch=z9hG4bK275469C
Max-Forwards: 70
CSeq: 102 BYE
P-RTP-Stat: PS=511,OS=81760,PR=505,OR=80800,PL=0,JI=0,LA=0,DU=10
Content-Length: 0
Dec  8 21:10:05.299: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 BYE
P-RTP-Stat: PS=505,OS=80800,PR=634,OR=101440,PL=0,JI=0,LA=0,DU=10
Content-Length: 0
Dec  8 21:10:05.303: //13818/0E4761800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 BYE
Content-Length: 0
247
