Unified Presence Upgrade 6.x to 7.x
I need to upgrade a presence server on a new hardware from 6.x to 7.x.
I have 2 questions that I couldn't figure out from the upgrade guides :
1. Can I use the upgrade files downloaded from CCO ( UCSInstall_UCOS_7.0.2.10000-36.sgn.iso_part1of2 and UCSInstall_UCOS_7.0.2.10000-36.sgn.iso_part2of2) directly or do I have to have the DVD provided by Cisco ?
2. After the upgrade, how can I migrate the licences to the new server ?
1 ACCEPTED SOLUTION
Re: Unified Presence Upgrade 6.x to 7.x
Release  Date: 08/Oct/2008
Cisco  Unified Presence 7.0(2) - part 1 of 2 - For upgrade from 7.0(1)
The file info already answers your first question
As for moving the licenses get in touch with licensing at licensing@cisco.com so they can rehost them.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
204
