Unified SRST Issue
Maher Shaban
Hi all,
I've configured a unified SRST with MGCP fallback and I think everything is configured properly, but phones never try to register With the SRST,
so, when I issue the command debug ephone detail. nothing appears.
I'm using CUCM 8.6.2  >> 10.10.50.8
gateway MGCP 2951   >> 192.168.93.2
and by the way that SRST is in the Local location not the remote one.
your help is much really appreciated
11 Replies 11
ronpatel
Level 8
Level 8
Please send the config done in your CUCM. Have you given config about your SRST ip address in CUCM SRST config.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Amine Nouasri
Level 3
Level 3
Make sure the CME/SRST License is active. You can verify that by using the command show license detail cme-srst.
Hope this would help!
Hi Amine,
thank you so much for that.
here you are My license status t's active)
        Feature: cme-srst                          Version: 1.0
        License Type: EvalRightToUse
        License State: Active, In Use
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 2  days
            Period used: 1  day  2  hours
            Transition date: Sep 26 2013 12:09:25
        License Count: 95/0  (In-use/Violation)
        License Priority: Low
        Store Index: 7
        Store Name: Built-In License Storage
Maher Shaban
Hi Norak,
thanks for your keen interest, the configuration done on my CUCM is
and that SRST is assigned to the Device pool which is assigned to that site phones.
hi
Send us  sh telephony-service output.
Ronak Patel
Hi Ronak,
I'm not using CME SRST, I'm using unified SRST with MGCP Fallback.
the Telephony service isn't activated at all in unified SRST.
and here you are below my show call-manager-fallback result.
#sh call-manager-fallback
CONFIG (Version=9.0)
Version 9.0
Max phoneload sccp version 17
Max dspfarm sccp version 18
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
ip source-address 192.168.93.2 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
max-ephones 85
max-dn 85 dual-line
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
huntstop
no huntstop channel
huntstop channel 0
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
moh music-on-hold
time-format 12
date-format dd-mm-yy
timezone 0 Greenwich Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
cor incoming international 1 1001-1013
cor incoming international 2 1229,1257,1305,1280,1054,1077,12
cor incoming international 3 1304,1306,1130,1277,1101,2222,12
cor incoming longdistance 4 1103,1027,1029,1028,1031,1111,11
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
system message primary SRST Fallback
Limit number of DNs per phone:
  12SP: 76
  7902: 76
  7905: 76
  7906: 76
  7910: 76
  7911: 1
  7912: 76
  7920: 76
  7921: 76
  7925: 76
  7931: 76
  7935: 76
  7936: 76
  7937: 76
  7940: 76
  7941: 76
  7941GE: 76
  7942: 1
  7945: 76
  7960: 1
  7961: 76
  7961GE: 76
  7962: 1
  7965: 76
  7970: 1
  7971: 76
  7975: 76
  7985: 76
  anl: 76
  ata: 76
  bri: 76
  CIPC: 1
  vgc-phone: 76
  IP-STE: 76
  6921: 1
  6941: 76
  6961: 76
  6901: 76
  6911: 76
  7926: 76
  6945: 76
  8941: 76
  8945: 76
Log (table parameters):
     max-size: 150
     retain-timer: 15
transfer-system full-consult
transfer-digit-collect new-call
multicast moh 239.1.1.1 port 16384
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Appreciated
Sorry My mistake.. I just wanted that output. Instead of SRST i gave CME command.
Ronak Patel
Maher Shaban
No worries Ronak,
Have you found anything yet?
By the way, that SRST is configured as an mgcp gateway, and all the FXO ports are registered.
Sent from Cisco Technical Support Android App
Hi Gents,
there is something I'm suspecting in which is related to my license
when I do #show license detail, I got these results.
SUK-Router#sh license all
License Store: Primary License Storage
StoreIndex: 0   Feature: ipbasek9                          Version: 1.0
        License Type: Permanent
        License Count: Non-Counted
        License Priority: Medium
  • StoreIndex: 1   Feature: uck9                              Version: 1.0
License Store: Built-In License Storage
StoreIndex: 0   Feature: securityk9                        Version: 1.0
        License State: Not in Use, EULA not accepted
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        License Priority: None
        License State: Inactive
StoreIndex: 2   Feature: datak9                            Version: 1.0
StoreIndex: 3   Feature: gatekeeper                        Version: 1.0
StoreIndex: 4   Feature: SSL_VPN                           Version: 1.0
        License Count: 0/0  (In-use/Violation)
  • StoreIndex: 7   Feature: cme-srst                          Version: 1.0
            Period used: 1  day  3  hours
            Transition date: Sep 27 2013 03:12:31
        Store Index: 7
is it ok this way that I'm having SRST License now, or not, because I see it's just an evaluation, and I see also two indexes for uck9 feature one of them is permanent and the other is for evaluation.
what does that means? and is that might be causing my case?
hi
I feel the licensing is correct. Have you restarted the router after you have accepted EULA.
Send us the output of  debug ephone detail when the phones try to register to the SRST router.
Ronak Patel
Hi Ronak,
  I just resolved the Issue, by removing the ip source-address command and put it again.
Thanks for your help.
