Uninstall CCM 4.2(3)
Hi NetPro
I have a MCS 7815-l2 whit CCM 4.2(3) running and working, but I need the CCM version 4.0(2) for restore an backup other servers.
I don't have de hardware detection for this server (MCS 7815-l2), and want to know if is possibly uninstall de CCM 4.2(3) application of the server. For install CCM 4.0.2 without format the server.
Only have go to???
Start --> Settings --> Control Panel --> Add o remove programs --> Cisco Unified Call Manager?
fixie rider
Re: Uninstall CCM 4.2(3)
theoretically it should work, but the recommended way would be to reinstall from scratch
java
if this helps, please rate
java
www.cisco.com/go/pdi
I don't have the Hardware detection for this server :(
fixie rider
k, then i guess the best chance is as you mention un-install and install other version. let us know how it goes
java
java
Dosen't work! I can remove the CCM application from add/remove password.
Only can remove the service release
fixie rider
i would like to mension something here that i have CCM release 4.1 and i wannat format the server , and re-install it again .
Q.Is the best way going through add remove prgramms to start from scratch like a new installation ???
no, best way is to rebuild from scratch
wipe out the server, reinstall OS and reinstall CUCM
java
java
298
